Wally1 Posted May 31, 2016 Share Posted May 31, 2016 hi i am using DOS XE and i am trying to access dos 2.5 disk under its use. i have tried option 'A' - allow dos 2.x access and it loads. but i dont know how to actually do a directory (files listing) or anything. i know about using disk as A: but cant really figure it out! somebody please help me thanks walter i keep getting error 168 and error 172 bad disk etc.! Quote Link to comment Share on other sites More sharing options...
pajero_pn Posted May 31, 2016 Share Posted May 31, 2016 It may be useful DosXE extractor v1.2 beta.zip 1 Quote Link to comment Share on other sites More sharing options...
+Allan Posted May 31, 2016 Share Posted May 31, 2016 The manual is here. http://www.atarimania.com/utility-atari-400-800-xl-xe-dos-xe_17591.html Allan Quote Link to comment Share on other sites More sharing options...
Wally1 Posted May 31, 2016 Author Share Posted May 31, 2016 thanks guys but i have the original manual pajero, what does the extractor do? thank you Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted June 2, 2016 Share Posted June 2, 2016 (edited) It's been some time since I've used DOS XE I know it's easier using 2 disk drives with 2.x access, check this out. http://atariage.com/forums/topic/107116-allow-dos-2x-access/?hl=%2Bdos+%2Bxe&do=findComment&comment=1298213 Edited June 2, 2016 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
Wally1 Posted June 2, 2016 Author Share Posted June 2, 2016 (edited) thanks Walter but i have only one disk drive still cant get it to work any ideas (i tried the A2:*.*) that the thread said i tried A:, A1: no go Edited June 2, 2016 by Wally1 Quote Link to comment Share on other sites More sharing options...
russg Posted June 2, 2016 Share Posted June 2, 2016 (edited) hi i am using DOS XE and i am trying to access dos 2.5 disk under its use. i have tried option 'A' - allow dos 2.x access and it loads. but i dont know how to actually do a directory (files listing) or anything. i know about using disk as A: but cant really figure it out! somebody please help me thanks walter i keep getting error 168 and error 172 bad disk etc.! I don't recommend DOSXE. Here's what I did to get a directory from a DOS 2.0/2.5 disk in drive 2. goto 'SYSTEM FUNCTION' menu, like you say (A choice). Then, like you say, do A.Allow DOS 2.x access. Then to get the directory of a DOS 2.x disk in drive 2: hit 'F' Then give A2:*.* for the drive specification and 'S:' for the destination. Don't omit the colon after A2. or S: the asterisk is a wild card. You could do A2:A*.* for all A named files. Also, don't do the single quotes for the S: If you only have one drive and stick a DOS 2.x disk in drive one, then the filespec would be A:*.* You can stop scrolling of the directory list with a CNTRL 1 Edited June 2, 2016 by russg Quote Link to comment Share on other sites More sharing options...
Wally1 Posted June 2, 2016 Author Share Posted June 2, 2016 thanks Russ! I got it to work! you have to erase the extra ":" that DOS XE prints in the prompt, specifically for F iles listing. then type A:*.* and you cannot change the W orking directory to A:, either thanks a multi-million, guys! Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted June 2, 2016 Share Posted June 2, 2016 thanks Walter but i have only one disk drive still cant get it to work any ideas (i tried the A2:*.*) that the thread said i tried A:, A1: no go You can't use any wildcards with DOS 2.x access, you have use the full file name when copying files. When trying to get the directory of DOS 2.XX you need to be on the system function menu screen. When you see the prompt "list what files? :*.*" you have to change :*.* to A:*.* then hit return then you should see "List to where?" just hit return then you should get the directory of your DOS 2.xx disk. Quote Link to comment Share on other sites More sharing options...
Wally1 Posted June 2, 2016 Author Share Posted June 2, 2016 yeah Walter youre right thats what I meant, change ":*.*" to "A:*.*" and you have to copy a file one at a time. okay Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted June 2, 2016 Share Posted June 2, 2016 (edited) Oh, my bad it didn't see you got it working. Oh one more thing if you pack your files that does help when moving files from 2.xx to DOSXE. If a file needs a Translater it's not going to work, DOSXE just lockups but there is a work around you'll need your XL/XE OS patched with the OS B fix. Edited June 2, 2016 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
