Program for making floppy custom labels
lbaeza
Hi there
Please take a look at the label on the picture. Was this label printed using an Atari program? Which one? Note that some letters are printed on double width...Any ideas?
Kind regards,
Louis BQ
Well it is the fifth Disk...What does "JLM" mean?
Is/was it som sort of Magazin Disk or is it a private
Collection?
In case one you could try to contact the publisher.
No bad joke... I allready established some contacts to
(formerly)(german) publisher(s) / groups, and got some
usefull informations. Often they even remember the number
of printer ribbon used per month ;-) . Why not the programs
they used?
Lots of programs can do this. What kind of printer(s) do you have access to? Would you find it acceptable to print them on a modern Windows system, because it likely would be a lot easier to do?
-Larry
Hi Larry
Do you have the name for any of those label printing programs from back in the day? I have access to an Atari 1029, and a Seikosha GP500 printer.
Windows font is an option. I googled for some dot matrix fonts, found some but I was not able to locate on with the double width feature. Do you know any?
Kind regards,
Louis BQ
Edited by lbaeza
Hi there
Found this program called "Label Maker (19xx)(Jones, Matthew)(US)[bASIC].bas" on atarionline.pl:
http://atarionline.pl/v01/index.php?ct=utils&sub=1.%20Biuro&tg=Label%20Maker&PHPSESSID=ac69e155ba601253be600dd52e0154f4#Label%20Maker
I tried it on Altirra:
...but the printer output emulation is text only. Any ideas how to set up Altirra in order to correctly display the underlined and enlarged text?
Kind regards,
Louis BQ
OK some answers that hopefully will help...
1) Windows really is the way to go. If you can't find a font or fonts that please you, you haven't looked enough. The Avery software is great. I've used it for all kinds of labels. Using a laser printer would probably produce the best results, but inkjet is good, too.
2) You have a Seikosha GP500 printer, hopefully it is for an Atari or Centronics and not a Commodore since C= interface probably can't work with the A8. That means it is either (somewhat) Epson compatible or maybe C-Itoh.
3) If you really want to do this on the Seikosha, I recommend "Daisy Dots." This was probably the very best printer program for the Atari. You will find lots of PD fonts for Daisy Dots on the web. There were also some programs called "Epset" and "Proset" in Atari mags (Analog, IIRC). I've posted those here in this atr.
Also, look for a PM from me with some other ideas.
-Larry
Printer Utilities.atr
