+Larry Posted August 6, 2016 Share Posted August 6, 2016 Hi Jon- Yours looks very nicely done. How (in general) did you do it and what tools did you use? (In addition to patience...) For sake of argument, pretty sure that my XEGS blank cart opens/closes very easily, but I realize that wouldn't be the case for most folks. I bought several cheap "Necromancer" carts and took one of them apart, and yes, that was a pain. -Larry Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 6, 2016 Share Posted August 6, 2016 (edited) Yours looks very nicely done. How (in general) did you do it and what tools did you use? (In addition to patience...) Thanks. I made two of them so far and sold them both. Basically, once I got the shell open (see below), I took precise measurements of the PCB and carefully marked off the various cut points on the casing. I test-fitted and checked by eye wherever possible (measure twice, cut once, etc). I drilled holes along the edge of the header cable hole and then hacked the rest out with a craft knife. Same with the SD card slot: a row of 2mm or so drill holes, cleaned up with a knife. The button hole was drilled out with a 3mm bit and then countersunk using a chamfer bit. Next was the most important stage for a good finish: using flat files to straighten and smooth everything off. Once everything was square, I finished the cut surfaces with a fine emery board and then sealed them with acetone on a cotton bud. I then quadruple-checked the cart shell for internal clearance before snapping everything shut. For sake of argument, pretty sure that my XEGS blank cart opens/closes very easily, but I realize that wouldn't be the case for most folks. Both cart shells were challenging, but the second one was worse. I had to squeeze it in a Black and Decker workbench and nearly gave up: the thing didn't want to budge, but a final turn did the trick just when I thought the shell was going to shatter. There was no way I wanted to open up those bad boys a second time around. I shouldn't imagine the plastic tabs being agreeable to it either. Edited August 6, 2016 by flashjazzcat 1 Quote Link to comment Share on other sites More sharing options...
Fuji-Man Posted August 6, 2016 Share Posted August 6, 2016 Here is a picture of the PCB inside the shell This would be a great project for Thingverse. Quote Link to comment Share on other sites More sharing options...
Marco Miccoli Posted August 7, 2016 Share Posted August 7, 2016 yesss! I want one please. Quote Link to comment Share on other sites More sharing options...
ndary Posted August 7, 2016 Author Share Posted August 7, 2016 Here are some pictures of the Cartridges ROM images i tested on the Ultimate SD cart 4 Quote Link to comment Share on other sites More sharing options...
Lord Helmet Posted August 8, 2016 Share Posted August 8, 2016 I'm interested! Put me down for one please! Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted August 9, 2016 Share Posted August 9, 2016 Yes Alan. The only limitation is it doesn't load floppy disks images with multi-load software. In that case please put me down for one. Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted August 17, 2016 Share Posted August 17, 2016 hi, i would like to buy one please Quote Link to comment Share on other sites More sharing options...
santosp Posted August 18, 2016 Share Posted August 18, 2016 (edited) Hello to all. First some latest news about the construction. I decide to make one more redesign of this cartridge, as to fit on Atarimax plastic shell. So the end product will be on a Red or Green transparent plastic shell. A decal based on original design from Robin, will also included. So any buyer will receive a complete cartridge on a shell with a decal. I would like to also inform cause the firmware upgrade connector will be inside the cartridge, because it fit. So the owner who will need to use it for any future upgrade, can simply open the shell. --------------------------------------------------------------------------------------------------------- The final price for this complete construction must be at 85$ plus 7$ shipping anywhere in the world. Now I need to know in real if at least 20 people need it, as to proceed with those. I must ask for start to send me a prepayment -half the price- for this as to order parts etc. I will receive prepayments for one week starting from this moment. If the total of 20 people not completed, then all prepayment will be refunded back to their owners. For any question or my PayPal account sent me p.m. Many greetings to all, Panos. Edited August 18, 2016 by santosp 6 Quote Link to comment Share on other sites More sharing options...
+davidcalgary29 Posted August 18, 2016 Share Posted August 18, 2016 Add me to the list! Green, please. Quote Link to comment Share on other sites More sharing options...
santosp Posted August 18, 2016 Share Posted August 18, 2016 Add me to the list! Green, please. David the project is in prepayments status now. Quote Link to comment Share on other sites More sharing options...
+davidcalgary29 Posted August 18, 2016 Share Posted August 18, 2016 D'oh! Quote Link to comment Share on other sites More sharing options...
Zoyx Posted August 19, 2016 Share Posted August 19, 2016 I would like one please. Thanks. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted August 19, 2016 Share Posted August 19, 2016 I think a lot of people are missing how to ensure they get in on this run, post #34 in this thread has instructions for prepaying 50% to hold your cart. 20 orders required to make sure the run happens for ease of use click here http://atariage.com/forums/topic/255512-ultimate-sd-cart-another-possible-run/page-2?do=findComment&comment=3574141 1 Quote Link to comment Share on other sites More sharing options...
retrobits Posted August 19, 2016 Share Posted August 19, 2016 prepayment of $46 sent! Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted August 20, 2016 Share Posted August 20, 2016 hi, i would like to buy please let me know how to send prepayment thanks Quote Link to comment Share on other sites More sharing options...
santosp Posted August 20, 2016 Share Posted August 20, 2016 I think a lot of people are missing how to ensure they get in on this run, post #34 in this thread has instructions for prepaying 50% to hold your cart. 20 orders required to make sure the run happens for ease of use click here http://atariage.com/forums/topic/255512-ultimate-sd-cart-another-possible-run/page-2?do=findComment&comment=3574141 Guys send me P.M as to give my PayPal info, plus to archive on a list for everyone who has pay till now. Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 20, 2016 Share Posted August 20, 2016 Hi Panos- Would it be of any value to you if the purchasers (hopefully) would use their own Atarimax cart shells? I have several that I no longer use. OTOH, putting the PCB in the shell for mailing is probably the very best way to protect the PCB. Or maybe this requires additional grinding, etc. to get the PCB to fit in the shell? -Larry Quote Link to comment Share on other sites More sharing options...
Guest Posted August 20, 2016 Share Posted August 20, 2016 (edited) prepayment sent in reply to PM from Satos Edited August 20, 2016 by Guest Quote Link to comment Share on other sites More sharing options...
santosp Posted August 20, 2016 Share Posted August 20, 2016 Hi Panos- Would it be of any value to you if the purchasers (hopefully) would use their own Atarimax cart shells? I have several that I no longer use. OTOH, putting the PCB in the shell for mailing is probably the very best way to protect the PCB. Or maybe this requires additional grinding, etc. to get the PCB to fit in the shell? -Larry Hi Larry. Unfortunately, additional grinding for SD card socket and the reset button required. If you want to share this info, how many cartridges have you available, and what colors. I am just curious. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 21, 2016 Share Posted August 21, 2016 I would like one Sent from my LG-H811 using Tapatalk Quote Link to comment Share on other sites More sharing options...
santosp Posted August 21, 2016 Share Posted August 21, 2016 (edited) The list. Edited September 4, 2016 by santosp 2 Quote Link to comment Share on other sites More sharing options...
dl7ukk Posted August 21, 2016 Share Posted August 21, 2016 Hi, Are 2 pieces possible for me? Thanks andreas Quote Link to comment Share on other sites More sharing options...
the.golden.ax Posted August 21, 2016 Share Posted August 21, 2016 my kids want one xegs is one of their favorites Quote Link to comment Share on other sites More sharing options...
olix Posted August 22, 2016 Share Posted August 22, 2016 Hi, if possible i like to buy one. I live in Germany. What should I have to do for payment? Quote Link to comment Share on other sites More sharing options...
