YASH 1.30 for SIO2USB - XEX loader added
24 replies to this topic
#1 StefanD OFFLINE
StefanD
    Star Raider
  • 62 posts
Posted Sun Aug 14, 2016 10:38 AM
I added an XEX loader to the file manager YASH for the ABBUC-RAF device SIO2USB.
Simply press Shift-Return to start the selected XEX (this will also switch off ATARI BASIC and clear main RAM). Firmware 4.23 or higher is needed, e.g. FW042309.ATR.
If XEX loading stops and the screen color changes, this means:
- red: XEX is corrupt or tries to load in $700-$9ff
- yellow-brown: I/O error
- blue: XEX has returned from its RUN address
In this case you can press RESET to reboot.
#2 Marius OFFLINE
Marius
  • 4,833 posts
Posted Sun Aug 14, 2016 12:10 PM
This is amazing news!
I own several of these FABULOUS devices. I am thrilled to see this update of Yash, which is actually the best sio device control program ever created!
#3 spookt ONLINE
spookt
  • 1,815 posts
  • This is SPARTA(DOS)
Posted Sun Aug 14, 2016 12:24 PM
Fantastic - can't wait to try this out. Thanks.
#4 Marius OFFLINE
Marius
  • 4,833 posts
Posted Sun Aug 14, 2016 1:24 PM
It works! How great is this!
#5 Marius OFFLINE
Marius
  • 4,833 posts
Posted Sun Aug 14, 2016 1:30 PM
One weird thing though...
On XDOS it seems not want to autoboot when I rename it to AUTORUN.SYS... while version 1.20 does want to autoboot when renamed.
#6 Marius OFFLINE
Marius
  • 4,833 posts
Posted Sun Aug 14, 2016 1:41 PM
Ah it lacks a RUN $4000 command.
#7 spookt ONLINE
spookt
  • 1,815 posts
Posted Sun Aug 14, 2016 2:52 PM
Can anyone post a link to the lasses SIO2USB firmware? I'm running 4.21 currently.
EDIT: Nevermind, found it in this very forum!
Edited by spookt, Sun Aug 14, 2016 3:09 PM.
#8 rdea6 OFFLINE
rdea6
  • 2,836 posts
Posted Sun Aug 14, 2016 5:34 PM
Is there a way to set the SIO rate with this software..??
#9 mytek OFFLINE
mytek
  • 3,430 posts
Posted Sun Aug 14, 2016 5:58 PM
Just to be clear. Is this also usable with SIO2PC-USB?
- Michael
#10 rdea6 OFFLINE
rdea6
  • 2,836 posts
Posted Sun Aug 14, 2016 6:04 PM
- Michael
Not without a two way SIO connector.   This hardware only comes with one SIO plug.. and the Files are delivered to the Atari via a plug in USB thumb drive.
Also this hardware need the #2 pin connected also..
Edited by rdea6, Sun Aug 14, 2016 6:06 PM.
#11 Mathy OFFLINE
Mathy
  • 2,960 posts
Posted Mon Aug 15, 2016 10:05 AM
Hello Micheal
YASH is intended for this:
Sincerely
Mathy
#12 Brentarian OFFLINE
Brentarian
    Moonsweeper
  • 479 posts
Posted Mon Aug 15, 2016 11:44 AM
Is anyone selling these still?
#13 StefanD OFFLINE
StefanD
    Star Raider
  • 62 posts
Posted Mon Aug 15, 2016 1:11 PM
OK, as ProWizard wrote, I forgot to append a RUN address, which may cause starting problems with some DOS versions. Here's version 1.31:
Changes:
* Added RUN address
* Turn off unused sound channels while loading an XEX file
#14 StefanD OFFLINE
StefanD
    Star Raider
  • 62 posts
Posted Mon Aug 15, 2016 1:16 PM
No, it's only for use with the SIO2USB interface developed by the members of the ABBUC regional group called "RAF". With this device, USB sticks can be accessed from the ATARI. See the picture from Mathy above.
No, the SIO2USB interface doesn't support this. But it should be able to work with higher SIO rates than 56K. I told the SIO2USB developers about it at the Fujijama meeting. If they can adapt their firmware, I will raise the used SIO rate.
For completeness, here are the added features in YASH 1.2:
- "Make ATR" can also create ATRs with 16 MB size (use "X" as size)
- RETURN displays the contents of the selected (text) file (if it is not an ATR/XEX)
#15 JD6502 OFFLINE
JD6502
    Star Raider
  • 71 posts
In the past they were built and sold by the Frankfurt chapter of the ABBUC on a pre-order basis. I've lost the link to their order page so I can't be sure they are still taking orders. You could try sending an email to sio2usb@abbuc-raf.de. Thomas Grasel was the guy handling sio2usb orders.
#16 Marius OFFLINE
Marius
  • 4,833 posts
Posted Mon Aug 15, 2016 1:37 PM
Last time was a few months ago, and then the ABBUC had them in their shop.
It's a fabulous device. Not compatible with all usb flash drives though (So I use MicroSD USB cartreaders (very small) which work excellent)
#17 Marius OFFLINE
Marius
  • 4,833 posts
Posted Mon Aug 15, 2016 1:45 PM
The Sio2USB from Abbuc has one serious downside, and that is that higher sector numbers in larger ATR files are slower. The higher you get, the slower it becomes.
I hope they will fix that one day too.
Yesterday I discussed this issue with one of my closest friends. He is a true a8 wiz and his idea was this:
The slow down is because of following the FAT chain from the start of the file for every cluster read. Perhaps the firmware/hardware doesn't cache the highest last-read cluster.
I am not an expert, but perhaps this is a clue how to fix this issue in Sio2USB?
#18 Bunsen OFFLINE
Bunsen
    Dragonstomper
  • 878 posts
Posted Mon Aug 15, 2016 2:55 PM
Two days ago I talked to Thomas. There are about 20 devices left. And ABBUC shop has some additional ones, but older editions
#19 olix OFFLINE
olix
    Space Invader
  • 46 posts
Posted Mon Aug 15, 2016 11:24 PM
I have one from the ABBUC Shop (Ser. #4003). Is this an older edition and what is the difference to the newer edition?
#20 Bunsen OFFLINE
Bunsen
    Dragonstomper
  • 878 posts
Posted Tue Aug 16, 2016 1:43 AM
Older firmware and lack of SIO jack (so SIO2USB is the end of the SIO chain).
#21 Stormtrooper of Death OFFLINE
    Moonsweeper
  • 455 posts
Posted Tue Aug 16, 2016 2:57 AM
What is the price of the newer SIO2USB version ?
#22 StefanD OFFLINE
StefanD
    Star Raider
  • 62 posts
Posted Tue Aug 16, 2016 10:58 AM
All devices have a serial number starting with 4001, so you have an old version. Newer versions have an 1 GB internal flash drive, older versions only 512 MB (in YASH go to the \INT directory and press Shift-S to display the free size).
There are no other differences. (OK, older versions have an old firmware, but the SIO2USB has an easy-to-use and safe firmware updater. You need only to start the FW042309.ATR with the newest firmware.)
As far as I know, all versions come by default without a SIO jack. Only if you sent Thomas Grasel a SIO jack, he built it in the device. (He hadn't enough jacks to build them in every device.)
Ask Thomas - see email address above ...
#23 Foster OFFLINE
Foster
    Chopper Commander
  • 126 posts
Posted Tue Aug 23, 2016 8:34 PM
Wow!  It's great to see active development for this incredible device!!  The SIO2USB is my favorite flash device for the 8bits although it is definitely the slowest.  YASH is a GREAT looking shell and is super versatile.  Thanks for the continued work on this.
#24 StefanD OFFLINE
StefanD
    Star Raider
  • 62 posts
Posted Sat Oct 1, 2016 11:56 AM
Update YASH 1.32
Changes:
* Removed possible crash if started without connected SIO2USB interface
* Receive checksum after received SIO data frame (hrmm...)
* Removed problem with some XEX doing a RESET at startup (Preppie, Flak)
* XEX with an EOF in the last segment header is accepted (Rally Speedway)
#25 Foster OFFLINE
Foster
    Chopper Commander
  • 126 posts
Posted Mon Oct 3, 2016 4:07 PM
Excellent!  Thanks Stefan!!
