the_tubes Posted August 17, 2016 Share Posted August 17, 2016 (edited) I have an Atari 2800 (Sears Video Arcade II) and I get this annoying color artifacts on the screen where the blue and red is offset a little to the right and left causing distortion in the image. I have messed with the pots but all those do is adjust the color, sound signal, and channel signal. I have also replaced all the electrolytic and film caps in hopes that fixes my problem but still nothing so I am hoping someone knows what the deal is because everything looks fine on the board so I'm at a loss as to what the problem is. Images of what I am talking about. http://imgur.com/a/kWa5e Edited August 17, 2016 by the_tubes Quote Link to comment Share on other sites More sharing options...
Osgeld Posted August 17, 2016 Share Posted August 17, 2016 (edited) Tried a different cable? Edited August 17, 2016 by Osgeld Quote Link to comment Share on other sites More sharing options...
the_tubes Posted August 17, 2016 Author Share Posted August 17, 2016 I haven't, but other than the color bleed, the image and sound is crystal clear so I didn't think that would be the problem but I can try. What cable do you recommend me getting? Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted August 17, 2016 Share Posted August 17, 2016 If you turn the color down a bit you can reduce it but there is nothing wrong with your Television set or your Atari - you've got one of the better models that artifacts really well; some home computers like the CoCo could achieve high resolution color modes only through the use of artifacting. The Atari has so many colors programmers don't usually use artifact colors intentionally, but check out what happens when an Atari game is specifically designed for maximum artifacting: https://www.youtube.com/watch?v=aghqgf6qqRw Not all Atari models can artifact equally - this game should look great on your unmodded 2800! If you add a composite mod you are likely to lose all artifacting though there is no reason someone couldn't design such a mod to preserve or even enhance artifacting. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted August 17, 2016 Share Posted August 17, 2016 you will still get artifacting with composite, its the same signal minus the rf carrier Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted August 17, 2016 Share Posted August 17, 2016 you will still get artifacting with composite, its the same signal minus the rf carrier You may still get some artifacting with a composite mod but imo you need a lot of chroma to get artifacting that looks as good as this; the composite mod that RadioShack did for the Color Computer in the 80's initially did not support artifacting because it cleaned up the signal too much. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted August 18, 2016 Share Posted August 18, 2016 (edited) If done right it's the same amount of chroma you would get anyway... don't see where this is helping the op though... what does a trs 80 have to do with an Atari having a case of super extra bleed that is not common for the systen Focus please Edited August 18, 2016 by Osgeld Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted August 18, 2016 Share Posted August 18, 2016 If done right it's the same amount of chroma you would get anyway... don't see where this is helping the op though... what does a trs 80 have to do with an Atari having a case of super extra bleed that is not common for the systen Focus please It's common for some models of the VCS, there's alot of variability. My Jr doesn't bleed chroma much, just enough for moderate artifacting. My Vader on the other hand, looks alot like the OP's 2800. I find artifacting fascinating because you can multiply the bit-plane for free! I wrote games on the TRS-80 to leverage artifacting in the 80's and like using the technique today on the Atari to do things you would otherwise need an extra CPU to do; all Atari's aren't equal, you really need one like the OP's to experience the full range and magnitude of effects that are possible. StarBlitz playing on an Atari like the OP's with lots of chroma output: https://www.youtube.com/watch?v=IJukQwlaU9s StarBlitz on the Jr with less chroma still showing artifacting, but alot less: https://www.youtube.com/watch?v=RWHJrPY6bQY Curious which system display do you think is more fun? IMO it's cool to have them both because the same games have a different feel, so I think the OP should get a second Atari and not change this one! Quote Link to comment Share on other sites More sharing options...
