icemanxp300 Posted August 20, 2016 Share Posted August 20, 2016 So I got a few Saturns today and as it usually is when someone has two it is likely because 1 is bad... and 1 is lol. I would like to eliminate the laser right now as regardless if it works that is not the problem as I do not get any video or audio. I should get the language and date menu as I do w/the other system even w/no cd, but I get nothing. There is def. no audio as if it was just a pure video problem I would still hear dinging from moving the controller around the language menu. Theoretically I could have audio but if the menu's never boot I would not get a chance for audio to kick in. The caps look fine, solder joints look fine. I suppose the caps may be the problem and honestly that's about the only solution I have been able to research that relates to this issue. It gets power, as it loads a blank screen. When a cd is inside it spins slowly for 5-10 seconds then just stops completely. Any ideas? Just an update I swapped power supplies w/the working unit and the working unit works fine w/either power supply so that can be eliminated. So basically has to be bad caps or a bad chip/connection. Quote Link to comment Share on other sites More sharing options...
X5900 Posted September 26, 2016 Share Posted September 26, 2016 Hey ho, could you post the first four letters/numbers of your serial number on the back? Quote Link to comment Share on other sites More sharing options...
icemanxp300 Posted September 26, 2016 Author Share Posted September 26, 2016 067099901 Quote Link to comment Share on other sites More sharing options...
Professor Gull Posted September 27, 2016 Share Posted September 27, 2016 I think I have come across this before as well with a model 1 Saturn NTSC. The serial on your looks like a model 2 though round buttons on the top. I would guess you used multiple cables to try out for the video as well but have you tried one with s-video? I had a model 1 that would not provide video nor audio till I used a s-video cord. the standard pack in composite would do nothing and I tested the composite cord on a model 2 and it worked fine. Could be a bad video/audio port. Quote Link to comment Share on other sites More sharing options...
icemanxp300 Posted September 27, 2016 Author Share Posted September 27, 2016 It is a model 2 and I don't have an s-video... I don't think. The cables I used are fine as they work fine with another model 2 system that works. Possible problems I have come up with is bad caps, bad bios. and could be a bad video/audio out. Quote Link to comment Share on other sites More sharing options...
Professor Gull Posted September 27, 2016 Share Posted September 27, 2016 Hmm definitely a strange issue. I wonder if you could try a memory cart or action replay to bypass the automatic load. I am just throwing out thoughts now but that might be worth trying. Quote Link to comment Share on other sites More sharing options...
