Dennis90 Posted August 30, 2016 Share Posted August 30, 2016 When i press down on player one's joystick on my PAL 7800 it acts like im pressing both down and fire at the exact same time! It is the same problem with both 7800 and 2600 games, anyone has an idea what might be wrong? I tried diffrent controllers but it's the same problem Hope someone can help! Quote Link to comment Share on other sites More sharing options...
0078265317 Posted August 30, 2016 Share Posted August 30, 2016 Which controllers have you tried? Quote Link to comment Share on other sites More sharing options...
Dennis90 Posted August 30, 2016 Author Share Posted August 30, 2016 Both original 2600 joysticks and 7800 controllers, does not matter what controller i use it seems :/ Quote Link to comment Share on other sites More sharing options...
0078265317 Posted August 30, 2016 Share Posted August 30, 2016 2600 cx40s and 10s only have 1 button. If you are using cx24 or cx78s then it may be your 7800 system. If using a genesis controller then you need an adapter like the seagull78 to make both buttons work. Quote Link to comment Share on other sites More sharing options...
Dennis90 Posted September 3, 2016 Author Share Posted September 3, 2016 I figured out what the problem is now! After taking a closer look I saw that one of the pins in the controller port was pushed back a little bit so that it touched one of the other pins and making it act like two buttons was pushed down! So i took some small pliers and pulled out the pin a bit so it's fine now! Guess some problems are very simple sometimes, LOL, I thought it was some chip or something that had gone bad at first... XD Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 4, 2016 Share Posted September 4, 2016 Nice job. Quote Link to comment Share on other sites More sharing options...
