New development: GTIA in CPLD
1022 replies to this topic
#1 Simius OFFLINE
Simius
    Dragonstomper
  • 550 posts
Posted Fri Nov 4, 2016 3:24 PM
The new CPLD solution is already working. Features:
  • Standard RGB output
  • Sharp, clean image
  • True 256 colors
  • 16 luminance levels available in all graphics modes.
  • Two colors in hi-resolution graphics
  • P/M colissions, trigger inputs and consol keys are supported by the old chip.
The tests takes some time. The decision on the mass production depends on the interest.
Edited by Simius, Fri Nov 4, 2016 3:30 PM.
#2 TXG/MNX OFFLINE
TXG/MNX
  • 3,637 posts
Posted Fri Nov 4, 2016 3:25 PM
I am interested in a few
#3 TXG/MNX OFFLINE
TXG/MNX
  • 3,637 posts
Posted Fri Nov 4, 2016 3:27 PM
Will gr.11 be fixed or are these the final specs?
#4 Brentarian OFFLINE
Brentarian
    Moonsweeper
  • 479 posts
Posted Fri Nov 4, 2016 3:30 PM
Interested depending on price.
#5 ndary ONLINE
ndary
    Dragonstomper
  • 525 posts
Posted Fri Nov 4, 2016 3:33 PM
I am Interested
#6 Firedawg ONLINE
Firedawg
    Dragonstomper
  • 530 posts
Posted Fri Nov 4, 2016 3:37 PM
I'm interested as well!
#7 Simius OFFLINE
Simius
    Dragonstomper
  • 550 posts
A lapse. GR.11 is ok, but it is one luminance graphics. One of 16.
#8 Simius OFFLINE
Simius
    Dragonstomper
  • 550 posts
Posted Fri Nov 4, 2016 3:41 PM
Are the typical TVs in the US equipped with the RGB inputs or the component (YPbPr) only?
#9 Brentarian OFFLINE
Brentarian
    Moonsweeper
  • 479 posts
Posted Fri Nov 4, 2016 3:52 PM
I'm sure there are some high end TV's that support RGB, but the most I've seen have HDMI, YPbPr, composite, and sometimes VGA.
#10 ApolloBoy OFFLINE
ApolloBoy
  • 5,750 posts
Posted Fri Nov 4, 2016 4:24 PM
There's also professional monitors like the Sony PVM and BVM series, and you also have upscalers like the Framemeister that can take RGB and output HDMI.
And let be known that I am *very* interested in this. If you want someone to test this in a 5200 that can be arranged...
Edited by ApolloBoy, Fri Nov 4, 2016 4:27 PM.
#11 mickcris OFFLINE
mickcris
    Moonsweeper
  • 485 posts
Posted Fri Nov 4, 2016 4:29 PM
I would be interested if it works in a 5200 also. :)
#12 MrFish ONLINE
MrFish
  • 5,474 posts
Posted Fri Nov 4, 2016 4:43 PM
Demo/video?
#13 Lilralphie OFFLINE
Lilralphie
    Space Invader
  • 25 posts
Posted Fri Nov 4, 2016 4:48 PM
Yes - I'm curious as well - would this work with a 5200?
#14 mytek OFFLINE
mytek
  • 3,430 posts
Posted Fri Nov 4, 2016 4:49 PM
Wow this sure came out of left field  :-o!!! Didn't see that one coming. Not a bad thing, but definitely a surprise.
So yes, how much will this cost?
- Michael
#15 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,132 posts
Posted Fri Nov 4, 2016 5:41 PM
"The decision on the mass production depends on the interest."
And interest depends on price...   ;-)
Besides, does Gr. 10 (normally 9 colours, 8 luminances) also have 16 luminances then?
#16 rdea6 OFFLINE
rdea6
  • 2,836 posts
Posted Fri Nov 4, 2016 5:47 PM
Interested for 800XL..
Maybe 130XE not sure..
#17 R6502A OFFLINE
R6502A
    Star Raider
  • 70 posts
Posted Fri Nov 4, 2016 6:37 PM
I'm interested.
#18 orange808 OFFLINE
orange808
    Star Raider
  • 62 posts
Posted Fri Nov 4, 2016 6:45 PM
Interested.
#19 David_P OFFLINE
David_P
    Dragonstomper
  • 939 posts
Posted Fri Nov 4, 2016 7:30 PM
Does it co-exist nicely with 130XE style banking?
#20 Stephen ONLINE
Stephen
  • 7,651 posts
  • A8 Gear Head
Posted Fri Nov 4, 2016 8:02 PM
Interested - very interested.
#21 Rybags OFFLINE
Rybags
    Gridrunner
  • 16,145 posts
Posted Fri Nov 4, 2016 8:08 PM
Nice - is the low bit capability for palettes selectable on/off like VBXE ?  Also I assume GTIA bugs and quirks are reproduced, e.g. persistent PM via size change trick and multicolour mode when PRIOR is changed from GTIA back to normal on a hires line.
I have to agree though, Component video would be way more desirably than RGB.  16 KHz RGB monitors are just a rarity where Component is almost universal on modern TVs.
Another nice addition would be the ability to half shift Gr. 10 pixels to the left so they match other modes.  This is one of those mystery things that is rumoured to be possible on normal hardware but not yet verified.
#22 Marius OFFLINE
Marius
  • 4,833 posts
Posted Sat Nov 5, 2016 2:29 AM
Will atari monitor output (comp video) also have benefit? IS there also comp.video output on pcb?
It sounds awesome.
#23 ApolloBoy OFFLINE
ApolloBoy
  • 5,750 posts
Posted Sat Nov 5, 2016 2:47 AM
That seems pointless considering most A8s already have composite video available on their monitor ports.
#24 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 218 posts
Posted Sat Nov 5, 2016 3:32 AM
Maybe a stupid question but will it work in SECAM computers ?
In any case, Im am nterested also for several ones
#25 Simius OFFLINE
Simius
    Dragonstomper
  • 550 posts
Posted Sat Nov 5, 2016 4:32 AM
@ApolloBoy, Mickcris, Lilralphie
There is no reason not work in 5200, since it is originally equipped with GTIA, but I'll try to remove the doubt.
@Mytekcontrols, CharlieChaplin
I'm not sure, but I suppose about US$50-60.
@CharlieChaplin
All color registers are eight-bit, so yes, GR.10 also have 16 luminances.
@David_P
Of course.
@Rybags
1. No, the least significant bit of luminance isn't on/off, athough could be if you can propose a proper, free bit in some GTIA register.
2. I don't know but if you can point some test program, I can check it out.
3. There is no problem with the positioning GTIA-mode pixels relative to hi-res graphics. As above - give a test.
@Ebigui
It isn't a stupid question. It will work, but the pinout of GTIA is different than FGTIA and there are significant differences in the TRIGs inputs handling, so different CPLD firmware and an adapter (or another PCB version) would be needed.
