bB starfield effect
55 replies to this topic
#26 Yosikuma OFFLINE
Yosikuma
    Star Raider
  • 88 posts
Posted Fri Jan 6, 2017 11:16 AM
Well damn, and here I was hoping I could finally implement my Pitfall-esque rope mechanic.  Some day ..
#27 Karl G OFFLINE
Karl G
    Dragonstomper
  • 819 posts
Posted Sat Apr 29, 2017 4:59 PM
It looks like this effect doesn't work with the multisprite kernel, sadly.  Any chance that I'm mistaken?
#28 RevEng OFFLINE
RevEng
    Bit Player
  • 5,192 posts
Posted Sat Apr 29, 2017 11:43 PM
Sad but correct. The multisprite kernel does a bunch of mid-screen hmoves that reset the effect, messing it up.
#29 Karl G OFFLINE
Karl G
    Dragonstomper
  • 819 posts
Posted Mon May 1, 2017 12:27 PM
A couple more notes from my testing (and I'm happy to have any of these refuted):
 * This is only compatible with the standard kernel if NO_BLANK_LINES is enabled
 * There is no way to exploit this trick on the Flashback Portable (I guess this was too much for me to hope for given that it is based on a hardware bug.  It worked as expected in Stella, however).
#30 RevEng OFFLINE
RevEng
    Bit Player
  • 5,192 posts
Posted Mon May 1, 2017 1:01 PM
At work right now, but AFAIK it should work without NO_BLANK_LINES. Since the missile will be under kernel control, you'll need to position the missile vertically and set it's height. The effect should show up where the missle would normally be.
#31 Karl G OFFLINE
Karl G
    Dragonstomper
  • 819 posts
Posted Tue May 2, 2017 8:49 AM
Confirmed - thanks!
Hopefully this will be my last question, but it looks like this bug only applies to missile 0, and not missile 1?  I tried setting ENAM1=2 and positioning missile 1, but no luck.  My hope was to be able to use the other missile so that I could use a kernel option that took away missile 1 instead of missile 0 (player1colors) and still retain one working missile.
#32 RevEng OFFLINE
RevEng
    Bit Player
  • 5,192 posts
Posted Tue May 2, 2017 9:22 AM
The TIA bug applies to all positionable objects. To switch my example over to missile1, just change references in the vblank routine from HMM0 to HMM1. (And change any other missile0*/ENAM0 references to missile1*/ENAM1)
#33 Karl G OFFLINE
Karl G
    Dragonstomper
  • 819 posts
Posted Tue May 2, 2017 1:19 PM
Also confirmed - I had missed changing the assembly on my previous attempt.  Thanks again!
#34 RevEng OFFLINE
RevEng
    Bit Player
  • 5,192 posts
Posted Tue May 2, 2017 1:58 PM
Not a problem. You're welcome. :)
#35 Karl G OFFLINE
Karl G
    Dragonstomper
  • 819 posts
Posted Thu May 4, 2017 2:44 PM
Here's a slightly different example in case it is useful to anyone.  Use the joystick to appear to move the ship in 8 different directions.  I commented the code to show what needs to be changed to use a different missile or the ball instead in case anyone else could benefit from that.
Now I just need to dream up a space game where 8 directions of movement would be fun.   :)
#36 Buckaroo OFFLINE
Buckaroo
    Space Invader
  • 24 posts
Posted Mon May 15, 2017 7:35 PM
This example uses both missiles on the screen at the same time and with Fixed Point 8.8 variables which can create some nice Parallax effects.
I've made them as big as possible and duplicated each 3 times so they cover the majority of the screen,
Is it possible to glitch the ball or players in the same way? I've been fiddling around with the variables but cant make them repeat.
Controls:
Select which missile to edit     ↕ Adjust by big amount     ↔ Adjust by small amount
Reset: Picks new Preset      Difficulty Switches: Toggle missile visibility
#37 RevEng OFFLINE
RevEng
    Bit Player
  • 5,192 posts
Posted Mon May 15, 2017 7:46 PM
Well done - that is some trippy stuff!
It's technically possible, yes. I'm not sure what the issue is - I'll give it a shot in the next couple days, if you don't beat me to it.
#38 Buckaroo OFFLINE
Buckaroo
    Space Invader
  • 24 posts
Posted Wed May 17, 2017 10:10 AM
The problem I was having was putting all 5 objects in at the same time, I was able to put one or two in before.
This new example uses all 5 objects in the glitch player0,player1,ball,missile0 and missile1.
In Visual BB I was able to make it work by keeping all of the horizontal moves on one line and calling WSYNC once
You can adjust the direction/speed in the same way but are unable to turn them on or off as before.
#39 Karl G OFFLINE
Karl G
    Dragonstomper
  • 819 posts
Posted Sun Aug 13, 2017 11:39 AM
I've noticed that the starfield effect seems to somehow interfere with horizontal player movement, as shown in this example.  It happens regardless of whether the effect is done using either missile or the ball.  Any ideas on what is causing this, or how to work around it?
Attached File  vert.bas   1.63KB   77 downloads
Attached File  vert.bas.bin   8KB   93 downloads
#40 RevEng OFFLINE
RevEng
    Bit Player
  • 5,192 posts
Posted Sun Aug 13, 2017 1:08 PM
Yeah, looks the HMOVE for the player is getting retriggered. A fairly easy fix is to add this to the beginning of the vblank routine...
  sta HMCLR
  sta WSYNC
Thanks for the bug report! :thumbsup: I've already updated the previous examples in this thread.
#41 Karl G OFFLINE
Karl G
    Dragonstomper
  • 819 posts
Posted Sun Aug 13, 2017 2:07 PM
That fixed it - thanks!
#42 Mountain King OFFLINE
Mountain King
    Dragonstomper
  • 691 posts
Posted Wed Dec 27, 2017 5:06 AM
I'm trying to use missile1 instead of missile0 for the starfield.
This seems like it would be a simple change in the DPC+ kernal. Change all instances of missile 0 to missile 1 and hmm0 to hmm1.
But I can't seem to get it to work. Am I missing something?
#43 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,749 posts
  • Medieval Mayhem
Posted Wed Dec 27, 2017 9:14 AM
HMOVE cancels out the starfield effect.
  1. Load the ROM in Stella.
  2. hit ` to enter the debugger
  3. make sure the Prompt is active
  4. type trapwrite HMOVE
  5. watch the scanline count as you keep hitting ` to exit debugger
you'll notice that bB's DPC+ Kernel hits HMOVE every-other-scanline.
#44 RevEng OFFLINE
RevEng
    Bit Player
  • 5,192 posts
Posted Wed Dec 27, 2017 9:51 AM
Your attachment works perfectly for me, when I compile it myself. Make sure you're using the latest bB and remove all *.asm files from your build directory - the first version of the bB starfield effect that I released used a custom assembly file, but I incorporated the changes required into my bB dist. When I did that, I recall cleaning the fix up a bit.
Indeed it does. But if you're already hitting HMOVE continuously, you can move some object(s) in large amounts each time, and get pretty much the same visual result as the starfield effect.
It's technically not the starfield effect, since it doesn't utilize the TIA bug, but I think the TIA bug version amounts to the same thing - the object keeps getting (automatically) shifted large amounts each scanline.
As a bonus, the "hit HMOVE every scanline" version of the effect should be universal and consistent between TIA versions, unlike the TIA bug version.
I have a bB DPC+ example near the top of this thread, which includes a binary.
#45 Mountain King OFFLINE
Mountain King
    Dragonstomper
  • 691 posts
Posted Wed Dec 27, 2017 11:45 PM
I updated to the latest bb. That did it. Thank you.
#46 Captain Spazer OFFLINE
Captain Spazer
    Chopper Commander
  • 110 posts
Posted Sat Jan 26, 2019 1:59 PM
How do I change missile to ball?
#47 Karl G OFFLINE
Karl G
    Dragonstomper
  • 819 posts
Posted Sat Jan 26, 2019 3:14 PM
Change missile0x to ballx in the bB code, and change HMM0 to HMBL in the assembly portion.
#48 Captain Spazer OFFLINE
Captain Spazer
    Chopper Commander
  • 110 posts
Posted Sat Jan 26, 2019 4:52 PM
Hm, I did as you said, and I put it in bank 2, all I get is a red line in the top of the screen following player0, what did I do wrong?
 dim frame=m
 dim effect=n
main
 gosub __Snowbank bank2
drawscreen
 goto main
 bank 2
__Snowbank
  frame=frame+1
  if frame=0 then effect=effect+1
  if effect>6 then effect=0
  ENAM0=2 : rem ** set ENAM0=0 when you want the stars to be gone
  rem ** no adjustment leaves the stars in place
  if effect=0 then score=0
  rem ** Adjusting missile0x by +1 or -1 moves the stars right or left
  if effect=1 then ballx=ballx-1:score=1
  rem ** +8 or -8 moves the stars diagonally, and displays them closer together
  if effect=2 then ballx=ballx-8:score=8
  rem ** +16 or -16 moves them diagonally, and displays them farther apart
  if effect=3 then ballx=ballx+16:score=16
  rem ** +12 or -12 is quick and nearly vertical
  if effect=4 then ballx=ballx-12:score=12
  rem ** +48 or -48 is a slow diagonal effect
  if effect=5 then ballx=ballx-48:score=48
  if effect=6 then ballx=ballx+32:score=32
  rem ** You need to ensure the missile0x position ranges from 0-159.
  rem ** If missile0x is 0 and decreases, then set it to 159.
  rem ** If missile0x is 159 and increases, set it to 0.
  if ballx>200 then ballx=ballx+160
  if ballx>159 then ballx=ballx-160
  vblank
  rem ** Enable the TIA bug that causes missile0 to be repeated
  asm
 sta HMCLR
 sta WSYNC
 lda #$ff
 sta HMBL
 lda #$c0
 sta WSYNC
 sta HMOVE
 sleep 5
 sta HMBL
end
  return
 drawscreen
 return
#49 Karl G OFFLINE
Karl G
    Dragonstomper
  • 819 posts
Posted Sat Jan 26, 2019 5:38 PM
Try adding ballheight = 255
#50 Captain Spazer OFFLINE
Captain Spazer
    Chopper Commander
  • 110 posts
Posted Sun Jan 27, 2019 6:39 AM
It worked, thank you
1 user(s) are browsing this forum
1 members, 0 guests, 0 anonymous users
