bradhig1 Posted November 22, 2016 Share Posted November 22, 2016 When I first turn on my heavy sixer it has the wrong colors however after 5 minutes the colors are normal. I don't have this problem with my four switch atari's. Quote Link to comment Share on other sites More sharing options...
zylon Posted November 22, 2016 Share Posted November 22, 2016 When I first turn on my heavy sixer it has the wrong colors however after 5 minutes the colors are normal. I don't have this problem with my four switch atari's. Either cracked solder joint at voltage regulator, or a faulty regulator. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted November 22, 2016 Author Share Posted November 22, 2016 The stupid color pot is on that small board under the metal shielding and I don't want to mess with that to fix the color and risk breaking it again. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted November 22, 2016 Author Share Posted November 22, 2016 Nah the color doesn't change at all it's just different from my four switchers. I checked it with pacman and et. I guess HAT game 3 just has odd colors. Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted November 22, 2016 Share Posted November 22, 2016 Try adjusting the color pot. Quote Link to comment Share on other sites More sharing options...
Hannacek Posted November 22, 2016 Share Posted November 22, 2016 It might be the 7805 regulator needs to be replaced. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted November 29, 2016 Author Share Posted November 29, 2016 It's the console. I had the tv on for 30 minutes before using it. I am not opening it up again. Cause if I do something will break. I have a bad track record with this console. I had it fixed back in January. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted November 29, 2016 Author Share Posted November 29, 2016 For one thing it's a pain to get the motherboard out of the top of the console without breaking a switch and the color pot is on the little board in the metal shielding box not easy to get to. Quote Link to comment Share on other sites More sharing options...
MaximRecoil Posted November 29, 2016 Share Posted November 29, 2016 I have a heavy sixer that had an issue where some colors would change. For example, when playing Missile Command, on the stage with the red ground, it would slowly change back and forth between red and light pink. I had already replaced the 7805 regulator, and it's outputting a rock-steady 5.02 VDC. I recently read a thread on this forum where someone fixed the same problem by replacing the TIA chip. I have 5 other Atari 2600s, so I could have replaced the chip in mine, but I wanted to try just reseating it first (I also reseated the other two socketed chips [RIOT and 6507]). That fixed the problem, for now at least. Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted December 1, 2016 Share Posted December 1, 2016 For one thing it's a pain to get the motherboard out of the top of the console without breaking a switch and the color pot is on the little board in the metal shielding box not easy to get to. There's actually a hole in the top of the shield so you can get at the color pot. All you need to do is get the top of the console off and that's all. 1 Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted December 8, 2016 Author Share Posted December 8, 2016 I adjusted the color pot and the color is still shifting after a minute. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted December 8, 2016 Author Share Posted December 8, 2016 I just checked it again and the color isn't shifting anymore. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted December 8, 2016 Author Share Posted December 8, 2016 When I run Haunted Adventure Trilogy the edges of the title are green. Is that normal for a heavy sixer? I am thinking of swapping the TIA chip with one from one of my four switchers. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted December 9, 2016 Author Share Posted December 9, 2016 I swapped the TIA chip with one from one of my four switchers. Same green edges. Seems none of atari's put out the same colors as the others. Quote Link to comment Share on other sites More sharing options...
Keatah Posted December 9, 2016 Share Posted December 9, 2016 I'm pretty sure each of the early VCS units were hand adjusted. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted December 10, 2016 Author Share Posted December 10, 2016 It had the wrong colors when I started it today. Noticed the starting room in Haunted Adventure Trilogy game 3 was blueish green at first and now it's normal color. Other then that California games won't work on this unit. Quote Link to comment Share on other sites More sharing options...
