Paul Westphal Posted December 1, 2016 Share Posted December 1, 2016 Hi guys, I picked this 800 off a guy who worked at Atari. I hit it with a SALT cart and got: OS : High checksum 5A02 Low checksum EC9F Math checksum calculated : D8A7 Math checksum found : 42FA PLUS : it has a weird ram card in second slot. Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted December 1, 2016 Author Share Posted December 1, 2016 It appears the OS has a EEPROM. Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted December 1, 2016 Author Share Posted December 1, 2016 I tried Mario bro's. XE, thinking it might be 64k, no dice. Ballblazer works. Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted December 1, 2016 Share Posted December 1, 2016 Ram card looks like it may have ram expansion like Axlon . Try booting superdos or SDX on it. James Quote Link to comment Share on other sites More sharing options...
DavidMil Posted December 2, 2016 Share Posted December 2, 2016 If those are 256K RAM chips, that is the Axlon RAMDISK MOD. I believe that David Byrd did that one. Along with modifications to the RAM card there were some changes to the ROM card too. On the lower right corner of the RAM card are there a couple of traces cut by C518? If so, this is the Axlon 256K RAMDISK Modification. This Mod was designed to give you a very fast virtual double density disk drive, so that DUP.sys and MEM.sav could be made resident and switching between programs and DOS would be almost instantaneous. It was designed to run with GENEEMDE (by H. V, Stacey) under DOS II (2.0S). If anybody has that program (not DOS 2.0S) I would like a copy of it too. Thanks, David Milsop 1 Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted December 2, 2016 Author Share Posted December 2, 2016 Yeah those are 256k ram chips. If this is the ramdisk mod, then most likely other programs may not see the extra ram, but I will try some demos. Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted December 2, 2016 Author Share Posted December 2, 2016 I tried super dos. After initializing, detected the high speed on my SIO to SD, then loaded fast. It's an interesting DOS. Quote Link to comment Share on other sites More sharing options...
DavidMil Posted December 2, 2016 Share Posted December 2, 2016 The EPROM in the 2K math socket (402) is unknown to me. I have a Fast Math chip in my 800 but the checksum is 5B68. This one may stump a lot of people. If you find out what it is, would you mind posting the info? Thanks, DavidMil By the way, if I had looked at your picture I would have seen the two traces cut by C518. David Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted December 2, 2016 Share Posted December 2, 2016 I tried super dos. After initializing, detected the high speed on my SIO to SD, then loaded fast. It's an interesting DOS. Superdos should show a density in 5+.that is ramdisk. pressing 5 should give a directory listing of the ramdisk. If using superdos, you can save the rom out to a file for others to look at. Superdos is designed to be a direct replacement for dos 2. James James Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted December 2, 2016 Share Posted December 2, 2016 The rom board is a puzzle. it has an extra decoder chip and 2 wires going through the hole 2 the back side. a pic of the back side may help. It also has REV B ntsc os. James Quote Link to comment Share on other sites More sharing options...
1050 Posted December 2, 2016 Share Posted December 2, 2016 Connection to pin 7 of the piggybacked 74LS138 on the OS board may mean it's like a couple of custom AXLON type upgrades I have with the difference that instead of 0xCFFF, it banks with access to 0xD700. Change your software to bank there and it will work if this is the case. Mine were not built like this one, pin 7 is normally not used so no need to piggyback another chip there. I suspect it may have other talents unknown at this time. Such as software on/off where mine had a hard wired switch. Quote Link to comment Share on other sites More sharing options...
