Very simple sound engine (With example)
7 replies to this topic
#1 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 8,942 posts
Posted Tue Dec 20, 2016 1:54 PM
I keep seeing questions about sound.  I've tried posting this before but got no feedback.  So, this is my attempt with a full working example :)
Basically, at the top of your main game loop you have a variable for a sound effect.  If its value is greater than 0 the sound plays.  The sound effect value gets decremented and gets its volume turned off at 0.
Using the same sound effect variable you can get different noises depending on the duration.  So, that saves on using extra variables.
 rem /** Declare the 2 variables for sound.  Putting higher values in changes the duration and sound **/
 dim sounda = a
 dim soundb = b
main
 rem /** if a sound variable is greater than 0 play sound effect and decrease its value.  Kill sound if 0 **/
 if sounda > 0 then sounda = sounda - 1 : AUDC0 = 8 : AUDV0 = 4 : AUDF0 = sounda else AUDV0 = 0
 if soundb > 0 then soundb = soundb - 1 : AUDC1 = 2 : AUDV1 = 4 : AUDF1 = soundb else AUDV1 = 0
 rem /** if FIRE or up is pressed start playback of sound effects by putting a value in the sound variables **/
 if joy0fire then sounda = 50
 if joy0up then soundb = 50
 rem /** Start main program loop again **/
 goto main
#2 Th0rn OFFLINE
Th0rn
    Space Invader
  • 10 posts
Posted Thu Dec 22, 2016 12:52 PM
Works great, thanks!   I was playing around with the Tinkernut program where he shows how to make an Atari game on YouTube and added sound to it.
https://www.youtube....her2zk_I&t=330s
#3 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,687 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Fri Dec 23, 2016 4:53 PM
The bB page has a Tinkernut version with sound effects:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#ex_tinkernut_world_deluxe
The bB page also has other sound effect/music examples:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#expro_sound
#4 Th0rn OFFLINE
Th0rn
    Space Invader
  • 10 posts
Posted Sat Dec 24, 2016 12:05 PM
Thanks for pointing that out.  I can play the Tinkernut game in Stella, but I can't load the 53k .bas file in Visual Batari Basic.  Visual Batari just says not responding.
#5 Random Terrain OFFLINE
Random Terrain
  • 28,687 posts
    Replay Value
    Nonlinear
Posted Sat Dec 24, 2016 2:12 PM
Do you have the latest version of VbB:
atariage.com/forums/topic/123849-visual-bb-10-a-new-ide-for-batari-basic/page-28#entry3537039
#6 Th0rn OFFLINE
Th0rn
    Space Invader
  • 10 posts
Posted Sat Dec 24, 2016 2:59 PM
I was using build 554, now thanks to your advice, I am using build 568.  I can view it and compile it now.
#7 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Star Raider
  • 73 posts
Posted Tue Oct 24, 2017 1:25 PM
Thanks for this and alot of other stuff I've used, I don't know if this can be helpful but I'll leave it here.
Attached File  simplesound2.bas   3.27KB   19 downloads
Edited by Lillapojkenpćön, Tue Oct 24, 2017 6:45 PM.
#8 Gemintronic OFFLINE
Gemintronic
  • 8,942 posts
Posted Wed Oct 25, 2017 11:16 AM
Yep.  There is definitely room for variation.  Glad it's been of some use Lillapojkenpåön :)
