7800fan Posted December 21, 2016 Share Posted December 21, 2016 Assuming the AtariMax SD cart works, is there a ROM out there I can use to test SGM to ensure it's working and the connector didn't crap out. The front connector tended to be bad due to oxidation as it didn't get used much compared to the main cart slot. Quote Link to comment Share on other sites More sharing options...
chart45 Posted December 21, 2016 Share Posted December 21, 2016 Assuming the AtariMax SD cart works, is there a ROM out there I can use to test SGM to ensure it's working and the connector didn't crap out. The front connector tended to be bad due to oxidation as it didn't get used much compared to the main cart slot. http://atariage.com/forums/index.php?app=core&module=attach§ion=attach&attach_id=289301 1 Quote Link to comment Share on other sites More sharing options...
7800fan Posted December 22, 2016 Author Share Posted December 22, 2016 TYVM. Quote Link to comment Share on other sites More sharing options...
7800fan Posted December 23, 2016 Author Share Posted December 23, 2016 I could use some help troubleshooting this. When I power the CV on without the cart, half of the time I get error message telling me to turn off the system before inserting a cart or expansion module. Other half of the time I get solid black screen. When I power on with the SD cart, usually I get the menu but sometimes I can't get to SGM test ROM as it either leads to black screen or "No SGM detected". I noticed the red power LED were flickering or dim when I get solid black screen. Once I got something different: I can't tell if this can be caused by bad expansion slot or something else. I don't have any working 2600 module to test with. PS instruction book mentions 90 days from date of purchase like old time but considering I bought this back in March and just got it a few days ago, I'd assume it meant 90 days from date of shipment in this recently completed SGM wave. Quote Link to comment Share on other sites More sharing options...
Bmack36 Posted December 23, 2016 Share Posted December 23, 2016 Make sure to get some DeOxit or Electrical contact cleaner to clean off the oxidation on expansion port connector. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted December 23, 2016 Share Posted December 23, 2016 I suspect your Colecovision is faulty, the SRAM or the Z80, don't worry, it's normal because the Z80 has zero protection from the cartridge port. Test other game cartridges like Pepper II. I'm the test developer and I'm still far away of seeing the day one single SGM is faulty because Eduardo tests each one before sending it. 2 Quote Link to comment Share on other sites More sharing options...
7800fan Posted December 24, 2016 Author Share Posted December 24, 2016 So probably the front connector. I have Pepper II, Smurf's Rescue, and Ladybug cart and they played fine when SGM isn't plugged in. I'll pick up contact cleaner. If it comes to it, I'll take apart my CV system and really clean the connector. My system does have a brand new cart connector and RAM mod to eliminate the old RAM chip that required negative voltage and is prone to blowing out. And BIOS chip swap, the one I have allows me to skip the splash screen by pressing fire button. Quote Link to comment Share on other sites More sharing options...
SiLic0ne t0aD Posted December 24, 2016 Share Posted December 24, 2016 Take a pencil eraser to the gold fingers/contacts on the expansion port. You should be able to sneak one in there without having to take apart the shell again to clean them. Definitely invest in a can of DeOxit D5 though, it goes a long way along with good 'ol fashion isopropyl alcohol and some Qtips. Hopefully it's just a dirty connector and not a more serious problem. Quote Link to comment Share on other sites More sharing options...
opcode Posted December 24, 2016 Share Posted December 24, 2016 Assuming the AtariMax SD cart works, is there a ROM out there I can use to test SGM to ensure it's working and the connector didn't crap out. The front connector tended to be bad due to oxidation as it didn't get used much compared to the main cart slot. Very unusual. Have you tried any actual SGM games? Quote Link to comment Share on other sites More sharing options...
Kiwi Posted December 26, 2016 Share Posted December 26, 2016 It did give me a few tries to boot up a SGM game from cold boot until it finally recognize the 24KB RAM and boot the game when I first got the unit. The RED LED is great indicator that it is receiving power from the power adapter. The power adapter I have that came with the unit eventually drove me crazy because with the modded controller with passthrough, SGM, and SD cartridge. Plus, touching/moving the wire or touching the plug that goes into the Colecovision will definitely corrupt the VRAM data. It was drawing a lot more power, so and started to undervolt(I think) the video chip. So sprites would be somewhat mirrored if x position is more than 128. So I got tired of messing around with that power adapter to get it to work, I went ahead and brought the Canadian power supply, and the problems went away. Quote Link to comment Share on other sites More sharing options...
