The UAV Rev. D Video Upgrade Thread
874 replies to this topic
#776 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 320 posts
  • Mr Ziggy loves to extend the 1050 heatsink!
Posted Sun Apr 15, 2018 1:08 PM
i would like to order a basic UAV board
please let me know the total cost including shipping to the UK
many thanks
#777 Ruggers Customs OFFLINE
Ruggers Customs
    Space Invader
  • 46 posts
Posted Tue Apr 17, 2018 10:40 AM
Anyone seen Bryan?  Been trying to contact him for a couple of weeks with no response.  Just wondering if he's still alive? :)
#778 cypher007 OFFLINE
cypher007
    Space Invader
  • 17 posts
Posted Wed Apr 18, 2018 4:14 AM
quick question. can I use a common ground (like the cable shield) for the outputs?
so I can use a 4 core cable to do the chroma luma comp vid and audio then the shield as gnd?
#779 randyg OFFLINE
randyg
    Combat Commando
  • 3 posts
Posted Wed Apr 18, 2018 2:33 PM
apologies for being so late to the group...is this still available to purchase?
thank you
#780 manterola OFFLINE
manterola
    Moonsweeper
  • 251 posts
Posted Thu Apr 19, 2018 7:49 AM
Hi guys,
After many weeks yesterday I had the opportunity to give UAV rev.D another try. This time I connected the UAV composite output and ground directly to the video cable skipping the Atari PCB and din connections. I did that because I thought the Din connector I installed in my 600xl could have been not completely isolated.
It didn't work, I mean it worked for about one minute, then the same problem (check the video). If you turn the system off for about 30 seconds, and then turn it on again, the image looks great for about 10 or 5 seconds (just like the video).
Given this working "durations" it makes sense that there is something (a capacitor maybe) charging and discharging which is producing the problem. The output of the modulator is particularly noisy, I just mention this in case you think it may affect.
I already tried to supply power directly thru the designated pads without luck.
Bryan offer to send it back, but I want to know if you have ideas to give it a last try.
Thanks
#781 ckrtech OFFLINE
ckrtech
    Chopper Commander
  • 231 posts
Posted Thu Apr 19, 2018 5:05 PM
Despite the timing of it not working, are you sure your sync signal is soldered well?
Also - what happens if you remove chroma from the equation? Even if you don't use s-video, you could move your wire from composite video out to luma out and see if you get a nice black and white signal.
#782 manterola OFFLINE
manterola
    Moonsweeper
  • 251 posts
Posted Mon Apr 23, 2018 8:13 AM
I checked the sync signal from UAV to gtia and I am sure there is no problem there. I also tried your suggestion of feeding lumma to the composite, and also tried the same but also disconnecting the color-in signal to UAV. Still the same.
I still have to ideas to try: first one is to try UAV in other Atari computer. I don't have a socketed one, so I was thinking in holding UAV piggyback on top of the cd4050, just for few minutes to see if my noisy ground 600xl is the reason of the problem.
The other idea is a check a suspicious smt resistor that I might have moved while soldering the outputs.
Can someone send me a picture of the resistors that are close to the outputs side of the UAV rev D? The underneath side of the PCB.
It is the opposite side of the green terminal block, but close to it.
I want to compare and see if there is something fishy there...
Thank you so much,
M
Edited by manterola, Mon Apr 23, 2018 8:15 AM.
#783 Bryan OFFLINE
Bryan
  • 10,926 posts
  • Cruise Elroy = 4DB7
Posted Wed May 2, 2018 12:33 PM
Hi everyone.
I've been pulled away from my Atari projects for a little bit, so I've ordered a small run of UAV Rev D boards to keep them available until I have more time.
The available options are currently:
Basic $22
Plug-In $25
Kit $25
XEL $25
5200 low-profile build $25
I'm getting caught up with PMs as well so let me know if I've forgotten anyone.
#784 OldAtAtari OFFLINE
OldAtAtari
    Star Raider
  • 98 posts
Posted Wed May 16, 2018 6:41 AM
Bryan, I've PM'd you. Thank you!
#785 Jstick OFFLINE
Jstick
    Star Raider
  • 74 posts
Posted Fri May 25, 2018 8:50 AM
Looking for a Plug-In board, PM sent.
#786 hueyjones70 OFFLINE
hueyjones70
    Chopper Commander
  • 226 posts
Posted Tue May 29, 2018 4:52 PM
Hi guys,
Thanks
That appears to be a bad capacitor. I have seen similar problems.
https://youtu.be/wJiJemb6Jco
#787 seastalker OFFLINE
seastalker
    Chopper Commander
  • 198 posts
Posted Wed May 30, 2018 12:37 PM
Hi Bryan - sent PM a while back but know you are a busy individual. :)
#788 Zitruskeks OFFLINE
Zitruskeks
    Space Invader
  • 27 posts
Posted Thu Jun 7, 2018 4:42 AM
Sent a pm, too. :)
#789 80s_Atari_Guy OFFLINE
80s_Atari_Guy
    Chopper Commander
  • 228 posts
Posted Thu Jun 7, 2018 5:36 AM
many thanks
Hey Bryan, any chance you could answer this ? I would love a plug-in version, but fear the postage could cost more than the actual device.
#790 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 320 posts
Posted Thu Jun 7, 2018 9:09 AM
hi dude!
Bryan got back to me with the following:
"The cost for a Plug-In or Kit boards is $25 and a Basic board is $22.  Shipping is $15"
#791 80s_Atari_Guy OFFLINE
80s_Atari_Guy
    Chopper Commander
  • 228 posts
Posted Thu Jun 7, 2018 9:51 AM
hi dude!
Thanks, appreciate it. Did he have any available ?
#792 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 320 posts
Posted Thu Jun 7, 2018 10:49 AM
youll have to PM him, i dont know if this run of boards are allocated to people or if he has surplus?
best of luck!
#793 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 320 posts
Posted Fri Jun 22, 2018 3:22 PM
Just thought i'd post a pic of my UAV Rev. D in my 600XL
success!
#794 manterola OFFLINE
manterola
    Moonsweeper
  • 251 posts
Posted Fri Jun 22, 2018 7:24 PM
success!
I just feel like doing the same ;-)
#795 KillWill OFFLINE
KillWill
    Combat Commando
  • 3 posts
Posted Mon Jun 25, 2018 12:31 AM
HI everyone, I posted this is in the "All About Audio Companioin" thread, but that thread doesn't get a lot of action, so I thought I'd post it up on here with more people to possibly answer this (as Bryan is obviously a busy guy).
Hi Bryan (or anyone else who knows), I’m just curious why the audio companion only has one output?
I have a SynthCart which I believe is capable of splitting two separate audio signals to left and right outputs, so that I can capture the two signals separately into my computer audio interface or one of my hardware samplers for further processing.
I intend to install this on an Atari 2600 Jr for ideal portability, with either a single trrs output jack (with a trrs to 3 rca breakout cable) in place of the original 2600 Jr rca out, or possibly by adding two separate 1/4” audio output jacks, keeping the original rca for composite video output only. Stereo audio is my prime objective, but nice clean video would be a bonus.
I’ve PM’d Bryan, but as he’s busy, if anyone with info or suggestions could comment it’d be greatly appreciated. Thanks!
#796 -^CrožBow^- ONLINE
-^CrožBow^-
  • 6,745 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Mon Jun 25, 2018 9:36 AM
All I can tell you is that when Bryan sent me my last order for UAV boards about 3 weeks back, he advised me he didn't have any UACs available and he wasn't planning on offering them anymore as he stated they were a right PITA to make due to their small size. As for having a single output only, you have to keep in mind that none of the Atari 8-bit systems that I'm aware of actually provided stereo output on them. Yes there are multiple channels of audio that are output on the chips, but Atari never made left and right audio outputs for these older systems. So Bryan designed the UAC like his UAV to be minimal install with little to no modification of the actual system itself required.
I also believe he mentioned to me that he is hoping to incorporate the UAC into the UAV so it is an all in one solution. But I could be mistaken about that part...
Aside from this, I sent Bryan a PM I think middle of last week but haven't gotten a reply. I know he had an initial batch of UAVs made up to hopefully fill the demand until his next Revision, but he also mentioned to me that all the ones he had made were bad and he was having to send them back to be fixed. But I don't know the exact number he had made up or how many have or had been allocated.
#797 KillWill OFFLINE
KillWill
    Combat Commando
  • 3 posts
Posted Mon Jun 25, 2018 10:46 AM
Thanks CrossBow, that's a big help.  So you're saying even the basic UAV mod won't provide access to the 2 audio outputs channels?
I've read on numerous posts that the 2600 was originally planned to have stereo speakers build right into the console (hence the speaker grills on older units) and that a number of original games were actually programmed in stereo.
I can see how this wouldn't be of interest to a gamer, but as I mean to use my 2600 Jr primarily as a synthesizer module using the SynthCart, stereo audio outputs would come in very handy.
Thanks again, CrossBow!
#798 hueyjones70 OFFLINE
hueyjones70
    Chopper Commander
  • 226 posts
Posted Thu Jun 28, 2018 7:54 AM
Bryan messaged me on June 12th that he was out of boards and that he was hoping to begin working on a new revision soon.
#799 KillWill OFFLINE
KillWill
    Combat Commando
  • 3 posts
Posted Thu Jun 28, 2018 8:04 AM
Thanks huey.
I meant to post here that Bryan took the time to message me this update on June 25th:
"I am currently out of all boards and won't be doing another run until I get some renovations done on my house. I do expect to offer new versions of both the UAV and AC at that time."
#800 DrVenkman OFFLINE
DrVenkman
  • 3,641 posts
  • Back off, man! I'm a scientist.
Posted Thu Jun 28, 2018 10:28 AM
Perhaps someone could PM a moderator with this info so that the thread title could be edited to indicate no more boards are currently available?
