The UAV Rev. D Video Upgrade Thread
817 replies to this topic
#801 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 6,242 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Thu Jun 28, 2018 6:16 PM
Thanks CrossBow, that's a big help.  So you're saying even the basic UAV mod won't provide access to the 2 audio outputs channels?
I've read on numerous posts that the 2600 was originally planned to have stereo speakers build right into the console (hence the speaker grills on older units) and that a number of original games were actually programmed in stereo.
I can see how this wouldn't be of interest to a gamer, but as I mean to use my 2600 Jr primarily as a synthesizer module using the SynthCart, stereo audio outputs would come in very handy.
Thanks again, CrossBow!
Yes the 2600 TIA chip does in fact output 2 channels of audio with a separate output for each off the chip and I should have been more clear that I specifically meant the 8-bit computers. You can get stereo from the 8-bit computers if you mod in a second pokey to provide that additional output line.
#802 DrVenkman OFFLINE
DrVenkman
  • 3,372 posts
  • Back off, man! I'm a scientist.
Posted Thu Jun 28, 2018 6:25 PM
That's whole 'nuther ball of wax though. Very few titles on the 8-bit support stereo POKEY, though that didn't stop me from putting in the second POKEY on my 1088XEL build. :D Those that do sound great, however!
#803 AlexandreSouza OFFLINE
AlexandreSouza
    Combat Commando
  • 2 posts
Posted Sun Jul 15, 2018 4:54 PM
Any news of when new boards will be avaiable? Thanks!
#804 Arnuphis OFFLINE
Arnuphis
    Moonsweeper
  • 343 posts
  • Loading...Please Wait
Posted Wed Jul 18, 2018 9:08 AM
I sent a PM as well and would like to get a basic board once a new production run is done.
#805 TEBL OFFLINE
TEBL
    Space Invader
  • 13 posts
Posted Wed Jul 25, 2018 2:00 AM
Hmm... Finally got around to installing this in an 800XL with the Freddy chip (PAL region), seems that I've still got my original problems intact after installation (vertical bars, sort of zig-zay-y). Only using composite since that's what I have available, the good news ofcourse is that it didn't blow up on me. Ground pad on UAV cut, wire directly to pin 2 on monitor port.
Any ideas of where to go from here?
Oh, was I not supposed to keep the beads as part of the new circuit?
#806 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 694 posts
Posted Thu Jul 26, 2018 2:14 AM
You´re using the 800XLF mainboard. This one has three problematic points:
- Exchange the both 470 uF electrolytic capacitors found on the mainboard. One on the right side near the RAM chips, the other one in the lower left corner of the O.S. ROM. Although most Atari 8-Bit mainboards hasn´t issues with electrolytic caps, THIS mainboard has. For sure.
- The both inductors (upper left corner at your picture, L3 and L4). Remove them and use a little piece of wire each for replacement (or a 0R resistor).
- The missing smoothing cap for Freddie causes a lot of white noise at the CPU´s buss. Check out my mod in this thread.
#807 mellis OFFLINE
mellis
    Moonsweeper
  • 269 posts
Posted Thu Jul 26, 2018 7:12 AM
You might have identified the issue I am having too. I suspect my UAV equipped 800XL also has the 800XLF logic board (and similar image quality issues). I shall investigate.
Thanks!
#808 TEBL OFFLINE
TEBL
    Space Invader
  • 13 posts
Posted Thu Jul 26, 2018 2:22 PM
Thanks for the assist tf_hh though no luck so far, changed all electrolytics and added the changes you referenced (replacing l3/4 with wire and bypasd for freddy). Unfortunately I've still got the same thing so, leaning towards something with the pal side of things so ordered a new oscillator and a new inductor for that general area. Not for any other reason than running out of things to try replacing.
#809 _The Doctor__ OFFLINE
_The Doctor__
  • 4,827 posts
Posted Thu Jul 26, 2018 4:05 PM
double check all wires and cables including to the display, worst case defective uav?
#810 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 694 posts
Posted Fri Jul 27, 2018 11:04 AM
I take a 2nd look to your picture... please check this part:
You´ve to remove the right leg of the 100 pF capacitor and solder the wire to "COLOR" (at UAV PCB) to the free pad. Can´t see it really exact, but it looks like the cap is connected to both pads (on both sides). Then such a bad picture is normal.
2nd tipp: Exchange this coil (L6) also with a simple wire. The coil will reduce the +5 volt voltage used for the 4050 (where the UAV draws the power from) and the 1k resistors (pull-up for LUM0...3 and COLOR). At the UAV PCB is a voltage regulator from +5V to +4.5 volts. It´s a real good one, but if the input power is too low, then also such side-effects may happen.
#811 TEBL OFFLINE
TEBL
    Space Invader
  • 13 posts
Posted Fri Jul 27, 2018 4:25 PM
Thx, capacitor was lifted at some point though possibly not at the time of picture. Replaced L6 with wire as well. Tried the other UAV I had, no changes there either so back at looking for other things.
Installed UAV in the other non-freddy I got that have just a slight hint of bars, couldn't tell a difference before and after so removed it since it has a low shield so just not my luck. Think I just have to wait on random parts before I end up taking a hammer to the damn things :-)
Edited by TEBL, Fri Jul 27, 2018 4:27 PM.
#812 _The Doctor__ OFFLINE
_The Doctor__
  • 4,827 posts
Posted Fri Jul 27, 2018 5:49 PM
have tried it with the uav piggy backed on the 4050?
substitution of wires, removed the coils completely?
Edited by _The Doctor__, Fri Jul 27, 2018 5:50 PM.
#813 Shawn OFFLINE
Shawn
    The Kraken
  • 18,050 posts
Posted Sun Aug 12, 2018 5:03 PM
PM sent to buy a UAV for my 5200 :)
#814 tane OFFLINE
tane
    Star Raider
  • 57 posts
Posted Wed Aug 15, 2018 5:28 PM
Anyone interested: Bryan is receiving new orders for UAV Rev D.
#815 kheller2 OFFLINE
kheller2
  • 1,220 posts
Posted Sat Aug 18, 2018 11:39 AM
Bypassed Freddy?  You mean you added the cap to Freddy right?
#816 Nodak OFFLINE
Nodak
    Combat Commando
  • 9 posts
Posted Sun Aug 26, 2018 4:39 PM
I'm interested, pm sent to Bryan for 3 boards.
#817 adamchevy ONLINE
adamchevy
  • 1,439 posts
Posted Sun Aug 26, 2018 4:45 PM
I heard the UAV wasn’t working very well with the 5200?
#818 Stormbringer OFFLINE
Stormbringer
    Chopper Commander
  • 199 posts
Posted Wed Sep 5, 2018 6:15 PM
Ok, so I installed a couple of UAV C's in a 2600 and a 800 with mixed results.
The 2600 is what I would like to focus on. I've wired it on top of the existing 4050 and soldered the jumpers for the rev c 2600. I believe all my connections are correct. Anyone have any idea's of where I should start?
Edited by Stormbringer, Wed Sep 5, 2018 6:18 PM.
