xxx Posted January 10, 2017 Share Posted January 10, 2017 (edited) hi, im a little bit confused. the tia chip has 4 video outputs; 3 x luminace and a colour output. is it rgb? or YPbPr? or some other kind of split video signal? Edited January 10, 2017 by xxx Quote Link to comment Share on other sites More sharing options...
alex_79 Posted January 10, 2017 Share Posted January 10, 2017 (edited) The 3 luminance pins are digital outputs (representing a 3 bit number, which allows for 8 different values of luminance). They are combined through a "resistor ladder" to form the single analog luminance signal.With these outputs you can get composite or s-video out of the TIA with simple modifications.An RGB mod does exists, but it involves more than just a simple digital-to-analog conversion and amplification. The 2600RGB board sits between the CPU and the TIA and completely bypasses the TIA color generation to achieve that. Edited January 10, 2017 by alex_79 Quote Link to comment Share on other sites More sharing options...
