The FinalGROM 99
568 replies to this topic
#1 ralphb OFFLINE
ralphb
    Dragonstomper
  • 599 posts
Posted Tue Jan 10, 2017 11:55 AM
*** UPDATE: Please see here for final FinalGROM 99! ***
Since fall I've been working on a successor cartridge to the FlashROM 99, and my prototype is finally in a state where I can present it:
As you can see, the look and feel of the FinalGROM 99 is very similar to the FlashROM (as are the videos :)). But the new cart also offers some substantial improvements:
  • supports both ROM and GROM images
  • has 512K of RAM for 64 banks or 56 banks + 5 GROMs
  • supports folders
  • can use raw cartridge dumps
  • fits regular cartridge shell (eventually)
Note that the reset button is not working yet, so I had to turn the console off and on again in the video.
At the heart of the FinalGROM 99 is a CPLD (complex programmable logic device), which replaces all of the 74 logic ICs found on the FlashROM.  CPLDs are similar to very, very small FPGAs, but predate those by quite a bit. The XC95144XL used here is probably the last "modern" chip that supports 5V signal levels.
Attached File  fg99-parts-save.jpg   287.17KB   55 downloads
The microcontroller still manages the SD card, loads images, and generates the menus. While the picture shows an ATmega 328, a 168 is actually sufficient.
The SRAM chip has 512K, which is the upper affordable limit for 3V parallel SRAM. This yields 64 banks, with GROMs residing in the upper 8 banks (although only 5 are used now).
Finally, the voltage converter transforms the 5V supplied by the TI into 3.3V used by all board components. That includes the CPLD, which can read 5V signals, but outputs 3.3V signals (which the TI99 can understand).
Probably the biggest downside of the FinalGROM 99 is the reliance on SMT technology, which is more difficult to solder by hand. But 5V tolerant CPLDs are not available in through-hole or PLCC format, the only exception being some Atmel CPLDs that could only be programmed by ridiculously expensive software.  :(
But please note that this is a prototype! This cart won't even fit the TI cartridge port, as my board layout has been exceptionally stupid. :dunce:  But thanks to the port expander, I could still use the board and even add a FlashROM for debugging purposes. At last I found the true purpose of a Widgit!
The final version of the FinalGROM 99 will replace the microcontroller and the voltage controller by SMD parts. I'm still undecided whether I should go full SMD or keep through-hole caps and resistors. Button and LED will definitely remain through-hole, so that people can mount those parts in a cart shell.
The next steps will be to design the final board and get new PCBs.  That done, I can send out some test boards. Note that updating the CPLD will require a JTAG cable, whereas the ATmega can be updated via SD card (at least that's the plan).
:?:  Do you have any reasonable suggestions for features? One thing that had already been suggested was write support. If the logic fits, I could add a DIP switch (or an SD config file) that would enable writing to select parts of the RAM. Are there any precedents for this? I know of Mini Memory and the Wiesbaden Supermodule -- are there any others?
Finally, please excuse the somewhat grandiose name of the cart. ;)  The natural name FlashGROM seemed just too close to FlashROM, so to avoid confusion I went with FinalGROM.
EDIT: added link to released cart
Edited by ralphb, Sun Jul 9, 2017 9:08 AM.
#2 arcadeshopper ONLINE
arcadeshopper
  • 4,073 posts
Posted Tue Jan 10, 2017 11:59 AM
Very nice!  I can't wait to see the finished product!
Greg
#3 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,502 posts
Posted Tue Jan 10, 2017 12:10 PM
Uh.. pardon my language and enthusiasm here but...
THAT IS SO FREAKING COOL!
#4 ti99iuc ONLINE
ti99iuc
  • 1,603 posts
IT's Fantastic !! I WANT ! !!  :lust:  :lust:  :lust:  :lust:
#5 F.G. Kaal OFFLINE
F.G. Kaal
    Space Invader
  • 44 posts
Posted Tue Jan 10, 2017 12:24 PM
Fantastic! I like the bigger RAM support.
Fred ;-)
#6 Lee Stewart ONLINE
Lee Stewart
  • 3,871 posts
Posted Tue Jan 10, 2017 12:26 PM
Will the ROM space be larger than 32KiB?
I may never go beyond that with fbForth, but I have certainly thought about it, considering that I am nearly maxed out at 32KiB.  For one thing, I could put the default font back in the ROM as well as some of the standard add-ons from FBLOCKS.
...lee
#7 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,502 posts
Posted Tue Jan 10, 2017 12:28 PM
Actually with the specifications, it may indeed be the very last cartridge ever designed for the TI.  And if I remember a comment Rasmus made a week or so ago I think the future of this cart is going to be amazing.
Now since there is probably going to be a boat load of people wanting them, I imagine the signup list is going to be rather long, so...
+1
before anyone else gets any ideas!
#8 retroclouds OFFLINE
retroclouds
  • 1,684 posts
Posted Tue Jan 10, 2017 1:10 PM
I want one! Seriously, get me two. Very well done!
#9 Shift838 OFFLINE
Shift838
  • 2,466 posts
  • SHIFT838
Posted Tue Jan 10, 2017 1:48 PM
Put me down for 2!!!
#10 eebuckeye OFFLINE
eebuckeye
  • 1,210 posts
Posted Tue Jan 10, 2017 1:49 PM
Wow!?! Nice work!!
Is there a max number of roms/groms supported on the SD card?  or per directory?
Edited by eebuckeye, Tue Jan 10, 2017 1:52 PM.
#11 Manic1975 OFFLINE
Manic1975
    Chopper Commander
  • 155 posts
Posted Tue Jan 10, 2017 3:16 PM
Maybe stupid question but... Will this module support RXB, USCD Pascal, XB 2.7, Plato? On demo there was Miner 49'er. Is this module working now or other module which are plug on side port?
#12 Asmusr OFFLINE
Asmusr
  • 3,003 posts
Posted Tue Jan 10, 2017 3:49 PM
Brilliant  :thumbsup:
#13 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,323 posts
Posted Tue Jan 10, 2017 4:33 PM
Are the RAM banks presented as ROM or RAM?  Your comment about write-support caught my attention ;)
Will the cartridge support ROM bank swapping as used by Extended BASIC or similar cartridges/applications?
If RAM is presented as RAM, will it bank-switch like the ROM cartridges (i.e., are they compatible) and if so, can the RAM be write protected?
#14 gfreige OFFLINE
gfreige
    Star Raider
  • 75 posts
Posted Tue Jan 10, 2017 4:59 PM
The FinalGROM cartridge, indeed!!  :)
#15 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,517 posts
  • Distracted at the Keyboard
Posted Tue Jan 10, 2017 5:58 PM
+1
Mee too! (is my text big enough? can you see it? I want one. :)
 WOW)
#16 Vorticon ONLINE
Vorticon
  • 3,495 posts
Posted Tue Jan 10, 2017 6:24 PM
Truly the ultimate device. Paired with a CF7+/NanoPEB, it will be all that will ever be needed by most users.
Nicely done indeed!!!
Please put me down on the waiting list. Or perhaps it will go up on sale eventually on arcadeshopper.com
#17 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,502 posts
Posted Tue Jan 10, 2017 6:43 PM
 Matt's sidecar unit would be good too... and of course an F18A.
#18 jedimatt42 OFFLINE
jedimatt42
  • 1,834 posts
Posted Tue Jan 10, 2017 7:01 PM
That's is awesome... As an aside, I'd love to hear about tooling for SMD.
Oh, wait... that wasn't expressive enough... That is completely awesome! I love the name of it too.
I thought the menu system in the FlashROM99 was excellent. And with GROM support, we can ditch those 32k grom conversions. ( We'll keep the native EA/5 apps converted though :) cause, I gotta push 32k cards :) )
My point: The menu might get large! It might need more navigation options than < and >. Maybe Something like 'S' jumps to titles starting with S. Just something around that would be nice.
I can imagine nearly everything but basic or forth disk software loading from this cart. And then if more basic is compiled, or the embedding of BASIC in a GROM is made convenient, then even more basic might live here.
-M@
#19 chouimat OFFLINE
chouimat
    Space Invader
  • 37 posts
Posted Tue Jan 10, 2017 7:27 PM
*drool* I want one ...
#20 gfreige OFFLINE
gfreige
    Star Raider
  • 75 posts
Posted Tue Jan 10, 2017 7:36 PM
-M@
it'll support folders, so I think the menu will be hierarchical too...
#21 gfreige OFFLINE
gfreige
    Star Raider
  • 75 posts
Posted Tue Jan 10, 2017 7:37 PM
And, BTW I WANT ONE TOO !!!!  :)  :)  :)
#22 ralphb OFFLINE
ralphb
    Dragonstomper
  • 599 posts
Posted Wed Jan 11, 2017 12:07 AM
Wow, thanks for your enthusiastic comments!  Time to get working again then ...
Yes, you'll have 512 KB of ROM, divided into 64 banks.
Yes, I kept the 171 images limit, but now it's per directory.  You could have 171 directories, and each one of that could have 171 programs, or maybe more directories.  Directories can be up to 127 chars deep, including /.  In fact, I recommend to have fewer games per folder, as it takes a bit longer to scan GROM images for building the menu.
GROM images are horrible.  Not only can the image name appear way down in GROM 6, but there are also autostarting GROMs without name at all.  Those are listed with their filename plus an asterisk (*).
Not yet, but I'll try to.  All of those only page the upper 4K, right?  Or is it the lower?
Note that the images were just everything I could find on WHTech in one particular folder.  I haven't tested all of them, but some aren't playing nice (Schach for the TI 99/4 (?) comes to mind).
That's still totally open.  Are there any cartridges (other than MM and WSM mentioned above) that had RAM in past?  I would imagine that if you make the RAM bankable, you'd do so independently of the ROM.
But I'd like to stress that there's not that much space left in the CPLD, so I cannot realize every good suggestion here,
I'll think about it.  Pressing S would, of course, start entry 'S'.  But maybe with a modifier ...
Thanks for all the feedback/suggestions!
#23 sometimes99er OFFLINE
sometimes99er
  • 4,191 posts
Posted Wed Jan 11, 2017 12:15 AM
A dream come true. Excellent.  :thumbsup:
#24 vectrexroli OFFLINE
vectrexroli
    Moonsweeper
  • 486 posts
Posted Wed Jan 11, 2017 1:10 AM
Definitely want one! :thumbsup:
#25 kl99 OFFLINE
kl99
    Dragonstomper
  • 858 posts
Posted Wed Jan 11, 2017 1:28 AM
This is another revolution! This looks like the multi-cartridge we have all waited for! Congrats to this milestone. It will be a pleasure to share the news tonight on the TI-99 Austrian group meeting.
Can you share a bit the history til this prototype stage? Was there a lot of private communication going on, or did you work on this all on your own?
How is the compatibility with QI (v2.2) consoles?
Feature wise:
- keep the hole in the final pcb design to allow easy 3d shell production
- possibility to use all 8 groms from the board, when the 3 groms from the mainboard are removed (jumper?)
here are some more Cartridges that might use write-enable:
- Austrian Gram Modul (from the 80s)
- Super Space I & II
- XB III+ (includes 32K of banked ram)
- GramKracker
- Super Cart (E/A grom with 8K ram)
- Hamburg Modul (from the 80s)
