SIO Wifi modem with esp8266
521 replies to this topic
#1 mozzwald OFFLINE
mozzwald
    Combat Commando
  • 9 posts
Posted Tue Feb 21, 2017 4:20 PM
I recently started working on getting my Atari 400 connected to a bbs over telnet/wifi with an esp8266 and wanted to share. I didn't find much about using an esp8266 as a modem with the Atari 8-bits.
I don't have much atari hardware and no SIO cable so, I first made a SIO23v3 breakout. More info on the board at the OSHPark Project page. The idea came from the atari8warez Poor Man's SIO cable and is an edge connector that fits between the two SIO port pin rows. The Data In, Data Out and Command pins are level shifted with mosfets (based off the SparkFun Bi-Directional Level Shifter). This board could also be used for connecting to a Raspberry Pi or other lower voltage device. I'm planning to build another for use with my Zipit Z2 Handheld and sio2bsd.
I have an ESP-01 board that I'm using with this modem emulator. The code is built and uploaded to the esp8266 with the Arduino IDE. The esp8266 is powered by the Atari 5V through a regulator. The command pin is not used at the moment. The ESP-01 is very minimal with few pins but other esp8266 versions have more pins available (can add sd card socket).
The modem software uses AT commands for connecting to access points, speed dial, baud rate, saving settings, etc. I tested both bobterm and icet with the RS232.COM handler and was able to connect to a bbs. The modem also allows incoming connections over telnet which worked from my linux pc. This is the extent of my testing so far and only at 9600 baud.
A couple of other ideas I had (unsure of the feasibility):
  • add SIO2Arduino to load the term software and handler
  • add SIO2Arduino and sd card; use wifi/webserver on esp8266 to load floppies (plus modem emu?)
  • 850 emulation?
Anyhow, as a plain old telnet modem it seems to work well :-D
#2 Sikor OFFLINE
Sikor
  • 1,429 posts
Posted Tue Feb 21, 2017 4:42 PM
Interesting. Look here: http://www.atari.org...=227879#p227879- other SIO2WiFi project (in early stage).
#3 Kyle22 OFFLINE
Kyle22
  • 3,711 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Tue Feb 21, 2017 10:03 PM
If you had CD and a few handshake lines in there, it would work great for a BBS.
#4 mamejay OFFLINE
mamejay
    Chopper Commander
  • 160 posts
Posted Mon Feb 27, 2017 6:13 PM
Great project.  I have created a modem for a Commodore 64 using the same code as you are using.  I had the idea of creating a modem for the Atari but I never got around to it.
Glad your proof of concept works
#5 Dropcheck OFFLINE
Dropcheck
  • 1,349 posts
Posted Mon Feb 27, 2017 11:51 PM
Nice.....!
#6 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 630 posts
Posted Tue Feb 28, 2017 7:17 AM
Well I cant read the polish page... and the tech wiz guy I am cant figure out how to good translate this early in the morning.. so  when someone gets this project to the pre-order stage.. let me know!!! :)
James
#7 mozzwald OFFLINE
mozzwald
    Combat Commando
  • 9 posts
Posted Tue Feb 28, 2017 1:59 PM
 I'm guessing the handshaking would hafta be done through a joystick port?
The code was chosen because it has many features I was looking for in a modem. I searched for commodore modems since I couldn't find any Atari ones and this popped up. I tested ok on a PC so I figured it would work with with the RS232.COM handler (is it called bobverter or Rverter?)
Interesting. Look here: http://www.atari.org...227879#p227879-other SIO2WiFi project (in early stage).
James
Google Translation Here but it's still a difficult read :)
I did a little more testing with bobterm and occationally the system would "freeze" and keyboard input would stop working (pokey overloaded?) but after resetting the esp modem it would start working again. I will do some more testing at a slower baud rate when time permits.
#8 Kyle22 OFFLINE
Kyle22
  • 3,711 posts
Posted Tue Feb 28, 2017 2:21 PM
That's how I would do it.
#9 ricortes OFFLINE
ricortes
    Dragonstomper
  • 631 posts
Posted Wed Mar 1, 2017 10:52 AM
It would be possible to modify to ESP8266 for, well everything. There are several variations but all of them have unused I/O bits. There is no good reason why you couldn't use the I/O pins to do hand shaking for anything from CTS/RTS or for that matter, the Atari SIO COMMAND line. I mean you could really make it an Atari serial device just like a disk drive or modem. The built in MCU isn't enough to get me switched from the other micros, in particular the ARM series, but if there was no ARM the ESP would probably be my favorite.
The ESP is open source and has most of the features you could want like ability to interface with a SD memory card. The downsides are it is mainly a linux development system<I have't gotten around to setting up a SDK on a linux box yet> and not a great knowledge base available to draw from unless you speak Chinese. Still, most of the tools are sort'a available so you can work in Windows. I've bought a number of versions of the ESP and my current favorite incarnation is NodeMCU because it provides more pinouts, 5V to 3.3V regulator, and USB interface for <$10. The low cost ones are <$3 and have the same processor/WiFi but without the bells and whistles i.e. you need to bring your own USB to serial converter. I am currently using the Arduino SDK with the ESP libraries installed to test out features.
There is a Lua version of the chip available but gawd help me, I just can't learn yet another programming language. So much could be done with this little chip but the effort to do it right would kill an ordinary human being. I mean stuff like making it a combination hard drive, WiFi, et al interface on the Atari sio chain.
#10 TechCowboy OFFLINE
TechCowboy
    Space Invader
  • 25 posts
Posted Sun Apr 2, 2017 2:25 AM
I find this fascinating!
#11 w1k OFFLINE
w1k
  • 1,669 posts
Posted Sun Apr 2, 2017 11:04 AM
im interested.. wow
#12 jeffpiep OFFLINE
jeffpiep
    Space Invader
  • 32 posts
Posted Wed May 3, 2017 3:06 PM
Very nice! Does this look like R: to the Atari?  I see you are using Rverter.
I've been using NodeMCU dev1.0 boards (ESP-12-E core) with the Arduino platform for embedded projects. I just switched my IDE to platformio still using Arduino.
Edited by jeffpiep, Wed May 3, 2017 3:22 PM.
#13 dkerfoot OFFLINE
dkerfoot
    Chopper Commander
  • 111 posts
Posted Fri May 5, 2017 1:18 PM
Thanks for this!  I was just designing something similar for connecting a Raspberry Pi Zero W (including the Poor Man's SIO approach) when I stumbled onto this. Very nice that we can get 3 of the boards for under $6 shipped!
#14 gargoyle OFFLINE
gargoyle
    Chopper Commander
  • 185 posts
Posted Sat May 6, 2017 5:41 PM
Nice work, looks interesting.
#15 Greenious OFFLINE
Greenious
    Chopper Commander
  • 184 posts
  • -= Elite =-
Posted Thu May 11, 2017 4:49 PM
We got it working over at atari-forum with an ST, successfully surfing with an ESP8266 over the 19200bps serial port.
http://www.atari-for...hp?f=15&t=31586
Also, C64 adapted ones are now selling on ebay, ie working as a modem, connecting them to telnet BBS's.
#16 AtariGeezer ONLINE
AtariGeezer
  • 2,842 posts
Posted Fri May 12, 2017 12:20 PM
Ordered 2 each of these last night to play with:
eBay Auction -- Item Number: 112216067429
eBay Auction -- Item Number: 112386042966
#17 _The Doctor__ OFFLINE
_The Doctor__
  • 5,813 posts
Posted Fri May 12, 2017 1:35 PM
Just make sure to get the 5 volt versions...
#18 AtariGeezer ONLINE
AtariGeezer
  • 2,842 posts
Posted Fri May 12, 2017 3:08 PM
Yep, the adapter should take care of it,  but I just added 2 of the max3232 adapters as well...
#19 mozzwald OFFLINE
mozzwald
    Combat Commando
  • 9 posts
Posted Sun Jul 9, 2017 4:11 PM
Awesome, I'm glad it's useful for someone else too!
I haven't had much time to experiment with the ESP and A400 until recently. Today, I was able to get SIO2Arduino running on the ESP-01 and load an ATR image file from the ESP internal flash using SPIFFS. Writing to disk doesn't work, it's read only, but I tried several different disk images which loaded ok. The timing may be off a bit as it seems to pause a couple times during the disk load, but eventually does finish.
My plan for this is to use SIO2Arduino in conjunction with the modem firmware so I can plug this in and autorun bobterm or ice-t or whatever and telnet over wifi. Could probably be used to load disk images over wifi and/or save them to an sd card. Some sort of SDrive over wifi to download ATR's from a server would be cool. I need to get an esp12 that has more pins for sd card.
Attached is the modified SIO2Arduino code that can be flashed with the Arduino IDE and esp8266 core. Warning, I'm not a programmer, this is a hack job and unfinished, but it worked for me. My esp01 flash size is 512K with 128K SPIFFS which is just enough room for a disk image. This instructable shows how to upload files into SPIFFS from the Arduino IDE. GPIO2 on the esp01 is used for the COMMAND pin.
I'll update if/when I get any further :)
#20 Stefan Both OFFLINE
Stefan Both
    Moonsweeper
  • 439 posts
Posted Sun Aug 20, 2017 11:54 AM
Dear Geezer, what is the MAX2322 IC good for,
in conjunction with the ESP chip?
I thought, I'd need a levelshifter 5 to 3.3 Volt.
But the MAX chip is a 0/5 to 12/-12 Volt, isnt it ? ( :confused : )
Stefan
#21 AtariGeezer ONLINE
AtariGeezer
  • 2,842 posts
Posted Sun Aug 20, 2017 1:28 PM
Stefan
The MAX2322 chip runs on 3.3 volts protecting the other boards from a 5volt overload on TTL levels.
#22 Stefan Both OFFLINE
Stefan Both
    Moonsweeper
  • 439 posts
Posted Sun Aug 20, 2017 1:38 PM
So it's used as a level shifter ?
(even more confused)
Stefan
#23 AtariGeezer ONLINE
AtariGeezer
  • 2,842 posts
Posted Sun Aug 20, 2017 3:08 PM
Check out this page: https://www.chzsoft....o-the-internet/
#24 mytek OFFLINE
mytek
  • 3,088 posts
Posted Sun Aug 20, 2017 3:46 PM
Slight confusion on the part number, this is the one you would be interested in: MAX3232 Datasheet (same as used in that "Connecting the Atari ST to the Internet" project). A MAX2322 is an entirely different animal.
- Michael
#25 Stefan Both OFFLINE
Stefan Both
    Moonsweeper
  • 439 posts
I see...
The page you mentioned handles Atari 16 bit,
with a real RS232Serial port.
The question mark in my head was the relation between Atari 8bit and +- 12 V level.
I probably missed something.
Because of the 5 V level of the atari
in the first picture, I expected a level
shifter 3.3 <-> 5 V instead.
I ordered 5 ESPs yesterday. Its my hope to
bring my C64, the Amiga AND OF COURSE my
800xl online. While I know how to build it
for the opposite, I was searching for a
"how to" regarding the A8bits.
That is, why I was pointed to this thread.
Thank you for the clarification!
Stefan
