Hi all,
I've been lurking a while to reading advice, but am a first time poster. I've just got my Atari 2600 and am so excited because I get to re-live all the memories I had as a child when I used to have one.
I've read many of the forums on connecting it up but not 100% sure on the solution so would like to check something before going ahead.
My problem comes with my TV. This particular TV does NOT have a F-type Coax input connector or component/composite input. It only has a non-screw coax out, HDMI, USB, SCART and the connection for the TV Aerial which I think you call RF input.
This is the TV http://direct.asda.c...default,pd.html
I have plugged the RCA from the Atari directly into the TV RF input. I get a good picture and it all works but I get no sound, just loud white noise. I understand that this is because the RF inputs can't handle both so I need another option.
Looking at Switchboxes etc they still seem to have the F-type screw in for the Coax input so that's no good.
So the only option I can think of is this: Can I plug the Atari RCA into a second hand VCR's aerial input and then use the scart from the VCR to the TV? Would that work?
There may be a gadget or something else you may suggest but I don't understand the RF Modulator/demodulator thing. Is that an option and if so can someone point me in the right direction to the right one to buy? I assume it would go from RCA to HDMI or does that not work?
Any advice would be more than welcome and hopefully once I am up and running I look forward to chatting about playing the Atari again for the first time in 30+ years.
Many thanks.
Tec.
