Plot a Circle
5 replies to this topic
#1 boski OFFLINE
boski
    Space Invader
  • 26 posts
Posted Sat Mar 18, 2017 4:34 PM
I want my sprites to essentially orbit the center of the screen. That means I need to be able to plot a circle to calculate the sprite's x,y coordinates, which will be constantly changing. Does anyone know how to do this?
#2 bogax ONLINE
bogax
    Dragonstomper
  • 738 posts
Posted Mon Mar 20, 2017 6:55 PM
here's one that uses a sine table
  dim angle = a.c
  dim tangle = temp1
  angle = 0
  gosub su
loop
  temp3 = sine(angle)
  temp3 = scl(temp3)
  player0x = temp3 + 37
  temp3 = angle - 64
  temp3 = sine(temp3)
  temp3 = scl(temp3)
  player0y = temp3 + 7
  angle = angle + 1.0
  COLUP0 = $3A
  COLUP1 = $14
  drawscreen
  goto loop
  ;  multiply by .328125 so scales 255 -> 83
  function scl
  asm
  lda temp1
  lsr
  lsr
  adc temp1
  ror
  lsr
  adc temp1
  ror
  lsr
  rts
end
  function sine
  temp2 = tangle
  if tangle{6} then temp2 = temp2 ^ %00111111  ; if its an odd quadrant complement the angle in 64 (64 is one quadrant)
  temp2 = (temp2 & %00111111)                  ; scale to index table 0..63 /2 for 32 elements /4 for 16 elements
  temp2 = sinetbl[temp2]/2
  if tangle{7} then temp2 = 255 - temp2        ; if the angle is greater than 128 then complement the sine in 128
  temp2 = temp2 + 128                          ; add an offset so the sine is 0..255 no negatives
  return
 ;  data sinetbl
 ;    0,  50,  74,  98, 121, 142, 162, 181
 ;  198, 213, 226, 237, 245, 251, 255, 255
 ;end
 ;  data sinetbl
 ;    0,  25,  37,  50,  62,  74,  86,  98
 ;  109, 120, 131, 142, 152, 162, 171, 180
 ;  189, 197, 205, 212, 219, 225, 231, 236
 ;  240, 244, 247, 250, 252, 254, 255, 255
 ;end
  data sinetbl
    0,  13,  19,  25,  31,  38,  44,  50
   56,  62,  68,  74,  80,  86,  92,  98
  104, 109, 115, 121, 126, 132, 137, 142
  147, 152, 157, 162, 167, 172, 177, 181
  185, 190, 194, 198, 202, 206, 209, 213
  216, 220, 223, 226, 229, 231, 234, 237
  238, 241, 243, 245, 247, 248, 250, 251
  252, 253, 254, 255, 255, 255, 255, 255
end
su
  player0:
  %00000000
  %00000000
  %00011000
  %00111100
  %00111100
  %00011000
  %00000000
  %00000000
end
  player1:
  %00111100
  %01111110
  %11111111
  %11111111
  %11111111
  %11111111
  %01111110
  %00111100
end
  COLUPF = $48
  player1x = 80
  player1y = 48
  return
here's one that uses a smaller sine table to form a circle from a set of line segments
  dim angle = a.c
  dim tangle = temp1
  angle = 0
  gosub su
loop
  temp3 = sine(angle)
  x = x + temp3
  player0x = scl(x)
  player0x = player0x + 39
  temp3 = angle + 64
  temp3 = sine(temp3)
  y = y + temp3
  player0y = scl(y)
  player0y = player0y + 6
  angle = angle + 1.0
  COLUP0 = $3A
  COLUP1 = $14
  drawscreen
  goto loop
  function scl
  asm
  lda temp1
  lsr
  lsr
  adc temp1
  ror
  lsr
  adc temp1
  ror
  lsr
  rts
end
  function sine
  temp2 = tangle & %00111111
  if tangle{6} then temp2 = 64 - temp2         ; if its an odd quadrant complement the angle in 64 (64 is one quadrant)
  temp2 = (temp2 & %00111111)/8                ; scale to index table 0..63 -> 0..7
  if tangle{7} then temp2 = 0 - temp2          ; if the angle is greater than 128 then negate
  temp2 = temp2
  return
  data sinetbl
    0,   1,  1,  2,  2,  3,  3,  3
end
su
  player0:
  %00000000
  %00000000
  %00011000
  %00111100
  %00111100
  %00011000
  %00000000
  %00000000
end
  player1:
  %00111100
  %01111110
  %11111111
  %11111111
  %11111111
  %11111111
  %01111110
  %00111100
end
  COLUPF = $48
  x = 0 : y = 128 : angle = 0
  player1x = 80
  player1y = 48
  return
here's one that uses a parabolic aproximation of sines-cosines
if you look closely you'll see it's actually sort of elliptical
  dim dx = v
  dim dy = w
  gosub su
loop
  c = c + 1
  if c & 7 then skip
  if x{7} then dx = dx - 1 else dx = dx + 1
  x = x + dx
   player0x = scl(x)
   player0x = player0x + 34
  if y{7} then dy = dy - 1 else dy = dy + 1
  y = y + dy
  player0y = scl(y)
  player0y = player0y + 2
skip
  COLUP0 = $3A
  COLUP1 = $14
  drawscreen
  goto loop
  ;  multiply by .34375 so scales 247 -> 84
  function scl
  asm
  lda temp1
  lsr
  adc temp1
  ror
  lsr
  adc temp1
  ror
  lsr
  rts
end
su
  player0:
  %00000000
  %00000000
  %00011000
  %00111100
  %00111100
  %00011000
  %00000000
  %00000000
end
  player1:
  %00111100
  %01111110
  %11111111
  %11111111
  %11111111
  %11111111
  %01111110
  %00111100
end
  COLUPF = $48
  dx = $0E : x = $7F
  dy = $00 : y = $F7
  player1x = 80
  player1y = 46
  return
#3 bogax ONLINE
bogax
    Dragonstomper
  • 738 posts
Posted Tue Mar 21, 2017 6:22 PM
I forgot to mention that in the case of the line segment circle
the table is matched to the number of steps in the circle so if you change the number of steps
the circle changes
it will get larger or smaller and if things don't add up just right it will probably wobble
#4 boski OFFLINE
boski
    Space Invader
  • 26 posts
Posted Tue Mar 21, 2017 7:05 PM
Thank you very much for your help! I've already learned a lot just playing around with the code. I'm sure this will help a lot of other people too. Just one more question - how can I change the radius in circle one? It seems like I'd need to change the code in more than one spot to keep it even.
#5 bogax ONLINE
bogax
    Dragonstomper
  • 738 posts
Posted Sat Mar 25, 2017 11:33 AM
the sine table is built on the (possibly) spurious theory
that it's good to start with the best accuracy and then
throw away what you don't need
so the sines are 0..255 and which would give you
sines -255..255
the sine function immediately throws some of that away and
returns sines that range 0..255
those values are scaled to fit by multiplying by the
reciprocal of the scale factor
that's what the scl function does
if you just want a different radius that can be baked into
the sine table
  dim angle = a.c
  dim tangle = temp1
  angle = 0
  gosub su
loop
  temp1 = angle/4
  player0x = sinetbl[temp1] + 42
  temp1 = (angle - 64)/4
  player0y = sinetbl[temp1] + 7
  angle = angle + 0.5
  COLUP0 = $3A
  COLUP1 = $14
  drawscreen
  goto loop
   data sinetbl
   38,  42,  45,  49,  53,  56,  59,  62
   65,  67,  70,  72,  73,  74,  75,  76
   76,  76,  75,  74,  73,  72,  70,  67
   65,  62,  59,  56,  53,  49,  45,  42
   38,  34,  31,  27,  23,  20,  17,  14
   11,   9,   6,   4,   3,   2,   1,   0
    0,   0,   1,   2,   3,   4,   6,   9
   11,  14,  17,  20,  23,  27,  31,  34
end
su
  player0:
  %00000000
  %00000000
  %00011000
  %00111100
  %00111100
  %00011000
  %00000000
  %00000000
end
  player1:
  %00111100
  %01111110
  %11111111
  %11111111
  %11111111
  %11111111
  %01111110
  %00111100
end
  COLUPF = $48
  player1x = 80
  player1y = 48
  return
if you want to vary the radius on the fly probably the easiest way is to
scale the sines to suit
here the sines are scaled using an approximate reciprocal calulated from
the radius
you can vary the radius from 4..40 using joy0 up-down
none of it is very accurate
the sine table is not very accurate
the scl function is not very accurate
and the reciprocal approximation is not very accurate
  dim angle = a.c
  dim tangle = temp1
  angle = 0
  gosub su
  dim num = temp1
  dim mul = temp2
  r = 20
loop
  f = (SWCHA ^ $FF) & f
  if f{4} then r = r + 1 : if r > 40 then r =  4
  if f{5} then r = r - 1 : if r <  4 then r = 40
  f = SWCHA
  temp1 = angle/4
  temp1 = sinetbl[temp1]
  temp2 = r * 2
  temp1 = scl(temp1,temp2)
  player0x = temp1 + 80 - r
  temp2 = r * 2
  player0y = temp1 + 48 - r
  angle = angle + 0.5
  COLUP0 = $3A
  COLUP1 = $14
  drawscreen
  goto loop
  function scl
  asm
  lda #$00
  sec
  ror mul
loop
  bcc shift
  adc num
shift
  ror
enter
  lsr mul
  bne loop
  rts
end
   data sinetbl
  127, 139, 151, 163, 175, 186, 197, 207
  216, 225, 232, 239, 244, 248, 251, 253
  253, 253, 251, 248, 244, 239, 232, 225
  216, 207, 197, 186, 175, 163, 151, 139
  126, 114, 102,  90,  78,  67,  56,  46
   37,  28,  21,  14,   9,   5,   2,   0
    0,   0,   2,   5,   9,  14,  21,  28
   37,  46,  56,  67,  78,  90, 102, 114
end
su
  player0:
  %00000000
  %00000000
  %00011000
  %00111100
  %00111100
  %00011000
  %00000000
  %00000000
end
  player1:
  %00111100
  %01111110
  %11111111
  %11111111
  %11111111
  %11111111
  %01111110
  %00111100
end
  COLUPF = $48
  player1x = 80
  player1y = 48
  return
Edited by bogax, Sat Mar 25, 2017 11:35 AM.
#6 boski OFFLINE
boski
    Space Invader
  • 26 posts
Posted Sun Mar 26, 2017 6:33 PM
Thank you very much! This will keep me busy for a while!
