Can one times ein kleins program in asm write for the atari2600?
8 replies to this topic
#1 funkheld OFFLINE
funkheld
    Chopper Commander
  • 214 posts
Posted Wed Mar 22, 2017 4:03 PM
Hi good afternoon.
Can one times a small program in asm write for the atari2600 for the dasm ?
Thank you.
greeting
#2 CPUWIZ OFFLINE
CPUWIZ
    Commander
  • 33,178 posts
  • Rogue Bastard
Posted Wed Mar 22, 2017 4:08 PM
Versuch das nochmal in Deutsch. ;)
#3 SpiceWare ONLINE
SpiceWare
    Draconian
  • 11,797 posts
  • Medieval Mayhem
Posted Wed Mar 22, 2017 6:54 PM
Here's my tutorial for Collect, a 2K game written in assembly. If that's not small enough then take a look at CollectMini, found at the end of the tutorial, for an even smaller program.
http://atariage.com/...cat-188-collect
#4 funkheld OFFLINE
funkheld
    Chopper Commander
  • 214 posts
Posted Thu Mar 23, 2017 3:03 AM
Hallo, ich suche Demoprogramme in ASM die ich nur mit DASM compilieren muss und dann laufen .
Ich möchte es mal lernen ,  finde aber keinen  Ansatz , wie der Grundaufbau funktioniert damit es läuft.
Danke.
Gruss
Edited by funkheld, Thu Mar 23, 2017 3:04 AM.
#5 funkheld OFFLINE
funkheld
    Chopper Commander
  • 214 posts
Posted Thu Mar 23, 2017 3:28 AM
 Hallo, wenn ich das daraus compiliere kommt folgende Fehlermeldund (siehe Bild).
 Collect_20140703.zip
 Danke.
 Gruss
#6 SpiceWare ONLINE
SpiceWare
    Draconian
  • 11,797 posts
  • Medieval Mayhem
Posted Thu Mar 23, 2017 7:07 AM
readme.txt in that zip file explains how to use dasm to compile the code.  Basically use:
dasm collect.asm -f3 -v0 -scollect.sym -lcollect.lst -ocollect.bin
or at a minimum use this so you don't have to rename a.out (the default name for the generated program) to something else.
dasm collect.asm -f3 -ocollect.bin
Full contents of that readme.txt file:
Collect is a simple Atari 2600 game where the objective is
to collect randomly positioned boxes.
Use dasm to compile the program.  Dasm can be found here:
http://dasm-dillon.sourceforge.net
The command used to compile is:
the options after the source file are:
    -f3 sets output format to 3, RAW.
    -v0 sets verboseness.  Values are 0-4, see dasm documentation.
    -s requests a symbol dump, saved to specified file.  Stella uses the symbol
dump in order to show your variable names in Stella’s debugger.  The
*.sym filename must match the *.bin filename for this to work.
    -l requests a detailed listing, saved to specified file.
    -o specifies the output file.  If not specified, the output file will be a.out
Besides the source file, only option -f3 is required to build a Atari 2600 program.
#7 funkheld OFFLINE
funkheld
    Chopper Commander
  • 214 posts
Posted Thu Mar 23, 2017 10:37 AM
Why is the size 0 byte of the program .a26
greeting.
#8 SpiceWare ONLINE
SpiceWare
    Draconian
  • 11,797 posts
  • Medieval Mayhem
Posted Thu Mar 23, 2017 11:16 AM
Don't know. Try doing a compile, making sure you get a listing (the .lst file) then zip the entire directory of your project and post it.
#9 funkheld OFFLINE
funkheld
    Chopper Commander
  • 214 posts
Posted Thu Mar 23, 2017 11:41 AM
The path was not right.
greeting
