zetastrike Posted April 2, 2017 Share Posted April 2, 2017 I got a s-video modded Genesis 3 in the mail today. The seller included an AC adapter. I went ahead and used it not knowing any better and it looked different from any of the 2103s and 1602s I have. It turns out it's a 2103. Once I realized this, I stopped using it and dug out a 1479 I had stuck away from years ago. Here's the info on them. Do you think I damaged the Genesis 3 by using the 2103? I just replaced it with the 1479 and it worked like nothing had happened. I'm kind of upset with the seller. http://www.gametrog.com/GAMETROG/How_which_do_i_need_SEGA_AC_Power_Supply_Information_Specs_Model_mk-3025_mk-1602_mk-2103_mk-1479_mk-4122_aa-s95j.html Quote Link to comment Share on other sites More sharing options...
+thegoldenband Posted April 2, 2017 Share Posted April 2, 2017 I don't think it should be a problem. The specs all match except that the amps are higher, which won't do any harm: it essentially means that the Genesis 2 adapter can handle a heavier load. It's the opposite scenario -- using a PSU that can't supply enough amps to satisfy the power draw of the system -- that can lead to fried adapters and systems. Quote Link to comment Share on other sites More sharing options...
H454 Posted April 2, 2017 Share Posted April 2, 2017 The sega will only use as much power as it needs. I would use the gen. 2 power because you may need slightly more power with the s video mod. Quote Link to comment Share on other sites More sharing options...
zetastrike Posted April 2, 2017 Author Share Posted April 2, 2017 Ok, that's good to hear. Thanks guys. Quote Link to comment Share on other sites More sharing options...
