NoteTaker download
1 reply to this topic
#1 Iamgroot OFFLINE
Iamgroot
    Chopper Commander
  • 134 posts
Posted Mon Apr 10, 2017 1:03 PM
There has been a few requests for an easy to use text editor that can be used from the applesoft prompt.
So here it is again.
Attached File  NoteTaker.zip   12.47KB   14 downloads
#2 Iamgroot OFFLINE
Iamgroot
    Chopper Commander
  • 134 posts
Posted Wed Apr 12, 2017 2:38 PM
For anyone playing around with it, just a couple of notes.
It is an 80-col editor so does require to be in 80-col mode.
BUT, and this is a big BUT, the PR#3 command for initializing the 80-col screen was left out on purpose.  The PR#3 command clears the text screen and this was not wanted for the reason why I wrote the program in the first place.
And that reason is, a lot of applesoft programs embed the instructions into the program.  To make the program a lot smaller, I wanted the instructions as a separate text file that could be read with a command such as "TYPE game.instructs".
Notetaker will do that.  It will save the text that is on the 80-col screen, without clearing it, when the program is first RUN.
With this in mind, here are some other ideas.  CATALOG a volume, then run Notetaker to save the catalog to a text file.
Run a basic program in 80-col mode, display the instructions, type Ctrl-C to break out of basic program, run Notetaker to save instructions on screen to a text file.
List a basic program, then run Notetaker to save the part of the listing that is on the screen to a text file.
Go into the monitor and do a hex dump or ML listing, exit to applesoft prompt, use Notetaker to capture hex dump to a text file.
etc, etc.
One last note:
I don't know if the instructions are clear on special command mode, but, inserting or removing a line of text works.  And, insert space and backspace delete are still a couple of lines of code away from being a reality.
Reply to this topic
