Popeye Problem
5 replies to this topic
#1 ColecoJoe OFFLINE
ColecoJoe
    Chopper Commander
  • 108 posts
Posted Wed Apr 12, 2017 10:21 PM
Hey Guys,
I have 2 Popeye cartridges that load up on my CV but both won't play. The game starts fine and I am able to move around but Bluto never moves from his start spot and Olive's hearts rush out super fast and I die within a few seconds. I also have a AtariMax SD and the same thing happens when I try to play the ROM. The Rom plays fine on emulators. Could there be a problem with my CV?
#2 fiddlepaddle OFFLINE
fiddlepaddle
  • 2,426 posts
Posted Thu Apr 13, 2017 2:00 PM
Mine works fine with Atarimax SD. Could be a bad rom dump, but since it happens with carts too, it must be the main unit. I'm no hardware expert, but you might run memory diagnostics (isn't there a memory test rom somewhere?)... Also, possible it's the power supply or on/off switch needs to be cleaned.
#3 ColecoJoe OFFLINE
ColecoJoe
    Chopper Commander
  • 108 posts
Posted Thu Apr 13, 2017 5:29 PM
Ahh test roms! Yes, thanks ... I didn't think about that. I'll try this weekend.
#4 NIAD OFFLINE
NIAD
  • 5,909 posts
Posted Sat Apr 15, 2017 7:04 AM
Their is a Diagnostic Test supplied by AtariMax on their Ultimate SD Cart that will test the RAM in CV systems. Just let the test run continuously so that it cycles through the RAM locations a number of times.
#5 ColecoJoe OFFLINE
ColecoJoe
    Chopper Commander
  • 108 posts
Posted Thu Apr 20, 2017 11:21 PM
Ran the ram and vram test and all is fine. I am noticing a little flakiness in the power switch so maybe I need to clean it.
#6 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 26,902 posts
Posted Fri Apr 21, 2017 7:32 AM
Yeah that's a common problem.  Those Power Switches were a terrible design flaw.  You might also want to check for a dirty cartridge port as bad contacts can cause issues like this.
