digdugnate Posted April 22, 2017 Share Posted April 22, 2017 (edited) Here in the last couple of days my Program Recorder has decided to stop working- the only thing I can think of that changed was that I added my PEB to my computer. My Adventure cassettes that I know are good do not make the trademark 'data noise' when being loaded from the module, and all of them say 'error - no data found'. Any thoughts/suggestions? Do I need to have the PEB off to use my cassettes? Edited to add: I have not changed the volume settings on my Program Recorder- they are still at the 'default' where the white lines are in the middle. Adjusting the volume seems to have no effect with it making the 'data noises'. Edited April 22, 2017 by digdugnate Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 22, 2017 Share Posted April 22, 2017 Not at all. Do you have all 3 wires plugged in to the cassette recorder? If so, try removing the "control" line and try again. Also check your cassette interface connection on the back of the TI. Make sure it is snug. Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 22, 2017 Author Share Posted April 22, 2017 how frustrating! I tried removing the 'control' line, nogo. i reseated the cassette interface connection, no go. The interface cable is 'brand new' as is the recorder, since both were in a sealed box when i purchased them. I was JUST playing Tunnels of Doom yesterday morning. Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted April 22, 2017 Share Posted April 22, 2017 You do have the data cable plugged into the back of the computer, not on the left side? Did you try playing the tape with the cable unplugged to make sure the recorder is still playing back audio? And you are plugging the 1/8 plugs into the proper jacks? Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 22, 2017 Author Share Posted April 22, 2017 You do have the data cable plugged into the back of the computer, not on the left side? Did you try playing the tape with the cable unplugged to make sure the recorder is still playing back audio? And you are plugging the 1/8 plugs into the proper jacks? Correct, I have the data cable plugged into the back of the computer and plugs in the proper color coded jacks. I was playing Tunnels of Doom just yesterday morning and it worked flawlessly. Strange that it isn't playing back the audio on the cassettes now. The only other thing I can think of that changed in my setup is I tried to record an EB program to a *blank* cassette last night, but how would this affect known good software tapes? I appreciate everyone's input, for sure! I haven't finished Mystery Fun House yet. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 22, 2017 Share Posted April 22, 2017 Try unplugging all the cables from the tape deck. Press play and see if the data audio comes through the speaker Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 22, 2017 Author Share Posted April 22, 2017 Try unplugging all the cables from the tape deck. Press play and see if the data audio comes through the speaker nope, no audio. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 22, 2017 Share Posted April 22, 2017 Hmmm... are the posts turning when you press play? Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 22, 2017 Author Share Posted April 22, 2017 they seem to be, i can see them turning when i press 'play' and i can hear the motors. when i look at the player without a tape, it looks pristine inside- no obvious markings or spots where it's worn or otherwise not working. Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted April 22, 2017 Share Posted April 22, 2017 Ok try this. Press in on the record protect switch on the inside of the recorder - it's the little switch on the back. Then press the recorder button through 10 or so cycles. Sometimes when released from record the switch doesn't come back to "play" mode. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 22, 2017 Share Posted April 22, 2017 That would be sad... hope you didn't record over your Mystery Fun House tape. Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted April 22, 2017 Share Posted April 22, 2017 Plus those switches can oxidize from age. If you feel able , you might crack the cases and spritz a little wd40 or de- ox on the switch to clean it. Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 22, 2017 Author Share Posted April 22, 2017 Ok try this. Press in on the record protect switch on the inside of the recorder - it's the little switch on the back. Then press the recorder button through 10 or so cycles. Sometimes when released from record the switch doesn't come back to "play" mode. argh, it still isn't working. did i do something to mess up my recorder? Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 22, 2017 Author Share Posted April 22, 2017 That would be sad... hope you didn't record over your Mystery Fun House tape. nah- my tapes are the 'original' tapes and write-protected from dummies like me. Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 22, 2017 Author Share Posted April 22, 2017 Plus those switches can oxidize from age. If you feel able , you might crack the cases and spritz a little wd40 or de- ox on the switch to clean it. thanks for all the super tips. it's nuts that it was working great one day, then pfffft, nothin the next. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 22, 2017 Share Posted April 22, 2017 So, no audio even with all lines disconnected... volume all the way up? Did you try rolling the volume and tone pots while play was pressed? Might have dirty pots... Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 22, 2017 Author Share Posted April 22, 2017 So, no audio even with all lines disconnected... volume all the way up? Did you try rolling the volume and tone pots while play was pressed? Might have dirty pots... nope, no audio even with lines disconnected and volume up, and i tried rolling the pots as well. it's nuts! Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 22, 2017 Author Share Posted April 22, 2017 while i'm working on my recorder dilemma i had a thought- does the TI *care* where it gets its sound from? could i use the cassette interface cable, plug it into my pc, and play a wav file and accomplish the same thing? 1 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 22, 2017 Share Posted April 22, 2017 Funny you should ask. Here is a video I made last year. 4 Quote Link to comment Share on other sites More sharing options...
BassGuitari Posted April 22, 2017 Share Posted April 22, 2017 Did the felts fall out of the cassettes by any chance? Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 22, 2017 Author Share Posted April 22, 2017 hmm, i'll look at this after dinner. Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 22, 2017 Author Share Posted April 22, 2017 Did the felts fall out of the cassettes by any chance? nope, still there Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 23, 2017 Author Share Posted April 23, 2017 i'm just too aggravated to mess with this anymore tonight, lol. for what it's worth, i WAS able to get Voodoo Castle and The Count to play the data back on the tape without the cable though. I am going to mess with Opry's video and see what i can do to hook my interface cable up to a line-out on the computer- from what i skimmed if i have .wav files of the programs the Program Recorder is just for show. Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted April 23, 2017 Share Posted April 23, 2017 One last thing the earplug jack is switched - meaning that when a plug is installed it cuts audio to the speaker and then restores it when removed. Maybe the switch is goofed. 2 Quote Link to comment Share on other sites More sharing options...
eightbit Posted April 23, 2017 Share Posted April 23, 2017 Funny you should ask. Here is a video I made last year. This is AMAZING! I am bookmarking this one. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
