Thoughts about this possible alternative internal colecovision PSU
colecovision internal psu
11 replies to this topic
#1 omf OFFLINE
omf
    Dragonstomper
  • 733 posts
Posted Tue Apr 25, 2017 4:04 PM
so i have been thinking about this and was looking as one does, and i came across this on ebay
http://www.ebay.co.u...pUAAOSweW5VeVqx
I did try and do something similar with a hefty heatsink and a load of voltage regulators and capacitors once but I got some image distortion during my tests so abandoned that idea, what I want to know if anyone can help is would this deliver power clean enough to run a Colecovision without any image distortion
it maybe worth getting one just to try at that price but wanted to see what others thought first
#2 omf OFFLINE
omf
    Dragonstomper
  • 733 posts
Posted Wed May 3, 2017 4:49 PM
i posted this in the hardware forum but it was moved here to be more on topic to see if anyone could help.
so what do you guys think??
#3 chart45 ONLINE
chart45
    Dragonstomper
  • 765 posts
Posted Wed May 3, 2017 6:14 PM
i use cfm40t it can be fit in the coleco and give you all the power you need +12 +5 -5 so you still can connect the roller controller behind the coleco
#4 Bmack36 OFFLINE
Bmack36
    Moonsweeper
  • 348 posts
Posted Wed May 3, 2017 9:20 PM
It isn't an internal mod, but something I have been working on. It runs on a stock cv with no mods and just uses an off the shelf 12V power supply.
#5 omf OFFLINE
omf
    Dragonstomper
  • 733 posts
Posted Sun May 7, 2017 3:25 AM
thanks for the part number, it gives me a place to start for a working power supply
i looked on ebay at http://www.ebay.co.uk/itm/Very-Handy-3-voltage-Poject-Power-Supply-Mains-input-with-12v-5v-3-3v-Output-/322479449518?hash=item4b1545e5ae:g:casAAOSwknJXyuj7 but this seems to be a variant of cfm40t, this is CFM40T-07 which doesnt have the -5 volts which isnt a major issue i suppose, it is the only one that appear after putting in cfm40t.
it looks a bit big for what is needed
#6 chart45 ONLINE
chart45
    Dragonstomper
  • 765 posts
Posted Sun May 7, 2017 4:25 AM
the -5v is for the vram if you use a f18a or had the vram mod you don need it... you can find the cfm40t here http://ca.mouser.com...2BO67El0yNmhQ==
#7 omf OFFLINE
omf
    Dragonstomper
  • 733 posts
Posted Mon May 15, 2017 1:00 AM
ok i picked up one of these power supplies i mentioned in post one during a much larger ebay parts order.
it works a treat.
it outputs 5v only so it only appears to work if you have a F18a installed
does anyone know the power requirements of the SGM, will that work on 5V only?
Edited by omf, Mon May 15, 2017 1:00 AM.
#8 SiLic0ne t0aD OFFLINE
SiLic0ne t0aD
  • 2,239 posts
  • Rock 'N Roller, Space Patroller
Posted Sat May 20, 2017 11:32 AM
You can use 5v with SGM, thats how my console is set up right now and everything works fine.
#9 Unstablewarpfield OFFLINE
Unstablewarpfield
    Space Invader
  • 49 posts
Posted Sat Jun 3, 2017 4:45 AM
Here is my album of how I modded my CV. Might be something useful for you in there.
#10 H454 OFFLINE
H454
    Moonsweeper
  • 395 posts
Posted Mon Jun 5, 2017 11:44 PM
Do you have a part # on the PSU?
Is it putting out 12v, 5v, -5v?
120v input?
Thanks
#11 Unstablewarpfield OFFLINE
Unstablewarpfield
    Space Invader
  • 49 posts
Posted Tue Jun 6, 2017 2:33 AM
The power supply I used is a Meanwell RS-15. I installed the F18a board so I don't require -5V anymore. If you don't put an F18 board in you could get one of the Meanwell powersupplies that delivers -5V, 5V and 12V. It takes anything from 100 to 240V input. I plan on making something like it for my Intellivision but the voltages on that one are a bit more difficult to obtain.
#12 H454 OFFLINE
H454
    Moonsweeper
  • 395 posts
Posted Tue Jun 6, 2017 2:08 PM
I figured it was a two out.
I've got a mean well three out, but was hoping someone found a small enclosed three out.
Will be trying out this external one in the future:
https://www.jameco.c...ly_2254151.html
Just uses a din 5 connector.
Looks like an AA member has had success with a ti computer.
https://atariage.com...t-power-supply/
Also tagged with one or more of these keywords: colecovision, internal, psu
