mattsoft Posted May 5, 2017 Share Posted May 5, 2017 Hi all - I just picked up a used ST and the floppy drive (with wide rhombus shaped eject button) has a minor issue I'd like to resolve. The floppy drive's default position is as if there is a disk inserted. If I pushed the eject button (no floppy in drive), the button goes in for a few seconds, and then it pops back out as if a disk has been inserted. This doesn't affect the performance really, it's just to use the floppy drive, I have to push the eject button, then quickly insert the disk. Is there a guide on these drives that explains the spring/load mechanism so I can troubleshoot? I've looked around a bit can't find much. Thanks! Quote Link to comment Share on other sites More sharing options...
zzip Posted May 5, 2017 Share Posted May 5, 2017 I have a few drives that behave like this.. Age I guess. The drive mechanisms are similar to PC drives, so if you can't find an ST-specific guide, look for generic 3.5 drive guides. Quote Link to comment Share on other sites More sharing options...
Nebulon Posted May 5, 2017 Share Posted May 5, 2017 That reminds me. I have a 1040 STe with a flakey internal disk drive. Can I just swap that drive out for a 720K PC drive? Quote Link to comment Share on other sites More sharing options...
zzip Posted May 5, 2017 Share Posted May 5, 2017 That reminds me. I have a 1040 STe with a flakey internal disk drive. Can I just swap that drive out for a 720K PC drive? It should work, but the bezel may require case modification. Quote Link to comment Share on other sites More sharing options...
mattsoft Posted May 5, 2017 Author Share Posted May 5, 2017 Hmm, OK, I guess I should first try to identify the mech in this drive and then find a suitable match. I was hoping there would be a spring that needs replacing, or a screw that needs adjusting or something easy. Quote Link to comment Share on other sites More sharing options...
