Which IIgs accelerator..
8 replies to this topic
Poll: Which IIgs accelerator.. (3 member(s) have cast votes)
Which is the better IIgs speed-em-up card?
  1. A.E. Transwarp GS (1 votes [33.33%])
    Percentage of vote: 33.33%
  2. Zip GSX (2 votes [66.67%])
    Percentage of vote: 66.67%
Vote Guests cannot vote
#1 Keatah ONLINE
Keatah
    Missile Commander
  • 19,551 posts
Posted Fri May 5, 2017 1:03 PM
In purging some more of the Apple III stuff I came across 2 accelerator cards for the IIgs intermixed in the pile, Transwarp and Zip GSX.
If was going to re-setup my GS and trick it out, what would be better choice? Does one have any clear advantages over the other?
#2 Iamgroot OFFLINE
Iamgroot
    Chopper Commander
  • 134 posts
Posted Fri May 5, 2017 2:53 PM
Depends on what your system currently has.
The Transwarp will reach higher speeds, have seen stable at 15 Mhz and even one claim at 17.5 Mhz.
Disadvantage is it requires a higher power PSU and gives off a lot of heat, so heat sink and fan required.
Also overall a little more expensive to upgrade due to Transwarp parts, PSU and heatsink.
Zip GSX have seen stable up to 12.5 Mhz.  Only could get mine stable at 10 Mhz, but for me good enough.
Less heat, less expense and some will say at equal speeds, the Zip is a little faster.
More than likely will work with current PSU.
It also seems that the success rate for Zip is a little higher for upgrades done by amateurs.  Whereas those who know what to look for have about an equal success rate.
#3 Bloodnose OFFLINE
Bloodnose
    Star Raider
  • 50 posts
Posted Fri May 5, 2017 3:16 PM
I just noticed the Zip GSX has a socketed 65C816 which means you could chain multiple accelerators.  I wonder if anybody ever tried this?
#4 Keatah ONLINE
Keatah
    Missile Commander
  • 19,551 posts
Posted Fri May 5, 2017 4:01 PM
On the Transwarp GS, there is a connector at the top of the card, looks like and IDE connector. What is it for? I don't recall seeing anything in the manual about it.
Overall I'm not too interested in overclocking an accelerator. Whatever stock speed it comes with out of the box is fine, unless it's an official upgrade and within spec of its parts. No overvolting. Software emulation (II+,IIe) can run at hundreds of MHz if I ever need that.
Edited by Keatah, Fri May 5, 2017 4:38 PM.
#5 Bloodnose OFFLINE
Bloodnose
    Star Raider
  • 50 posts
Posted Fri May 5, 2017 4:47 PM
I had read somewhere (can't find it right away) that connector is for manufacturing use only.  If I come across it again and can find any more info I'll report back.
#6 Keatah ONLINE
Keatah
    Missile Commander
  • 19,551 posts
Posted Fri May 5, 2017 4:49 PM
It's a rather nice connector to be "wasted" on factory testing or anything like that. Factory testing usually has simple test points/pads and aren't populated. Even back then.
#7 Bloodnose OFFLINE
Bloodnose
    Star Raider
  • 50 posts
Posted Fri May 5, 2017 5:37 PM
I cannot dizisagree.
This is what I had found previously,
https://groups.googl...le2/M-cLVXpDL18
There is only speculation about the connector, and no known add-on that uses it.
#8 Polymorph OFFLINE
Polymorph
    Space Invader
  • 29 posts
Posted Sun May 7, 2017 10:01 PM
If you're referring to the right-hand 40 pin DIP socket marked as "Original" then this is just a place to "store" your original 65816 whilst the ZipGSX is installed - it is not electrically connected in anyway AFAIK. So no chaining is possible.
#9 Bloodnose OFFLINE
Bloodnose
    Star Raider
  • 50 posts
Posted Mon May 8, 2017 6:17 AM
I was just being snarky on a Friday afternoon.
But now looking at the manual for the ZIP GSX, it says, "You may park your original 65C816 in storage if you have the appropriate product."
Pretty cool.
http://www.whatisthe...PGSX_Manual.pdf
Reply to this topic
