repetto74 Posted May 23, 2017 Share Posted May 23, 2017 (edited) Hi guys, I cannot get a new blank disk to work with Altirra 2.81. I am emulating the 800 XL and would like to have a formatted new disk but each time I create a new disk I cannot save on it (always having ERROR 130). Any idea? EDIT : ok Guys I am really DUMB. I forgot to copy Dos files on it!!! EDIT 2 : Nope I did copy Dos files on the disk and checked they are there but still getting ERROR 130 when saving a progam (save"d1:test.bas") Edited May 23, 2017 by repetto74 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 23, 2017 Share Posted May 23, 2017 Have you booted DOS? Error 130 means "no such device", so perhaps there is no file system driver present. Quote Link to comment Share on other sites More sharing options...
repetto74 Posted May 23, 2017 Author Share Posted May 23, 2017 (edited) Hi flashjazzcat, What do you mean by booting DOS? What I want to do is to go to BASIC write down a program and then save it. If you mean booting directly the new formatted disk then yes disk will boot and I get to the DOS 2.5 menu. Exploring the new disk will give this : DOS.SYS DUP.SYS Edited May 23, 2017 by repetto74 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted May 23, 2017 Share Posted May 23, 2017 Hi flashjazzcat, What do you mean by booting DOS? What I want to do is to go to BASIC write down a program and then save it. If you mean booting directly the new formatted disk then yes disk will boot and I get to the DOS 2.5 menu. Exploring the new disk will give this : DOS.SYS DUP.SYS "Booting DOS" means put the disk image with DOS files into the D1: slot, then cold-boot the machine - you should hear drive sounds and it should take a few seconds longer to get the READY prompt as DOS.SYS is loaded into system memory. If you did it right, typing DOS at the READY prompt will get you to your DOS menu or command prompt. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted May 24, 2017 Share Posted May 24, 2017 Take the write protection off the floppy, atr, emulation setting.. Quote Link to comment Share on other sites More sharing options...
repetto74 Posted May 24, 2017 Author Share Posted May 24, 2017 DrVenkman thanks for your explanation and this is exactly what I have when booting the new disk (think I have choose the double sided format). I will check the writing protection, I recall maybe having already tried this but will try later. Which setting should I use ? R/W? Many thanks Quote Link to comment Share on other sites More sharing options...
1050 Posted May 24, 2017 Share Posted May 24, 2017 Yes, R/W is short for Read/Write. Double sided doesn't work with DOS 2.5 which is what you booted. Double Density doesn't work with DOS 2.5 either but they do have something called Dual Density which most prefer to call Enhanced Density because it is neither single nor double density and Dual just becomes confusing then. ED, short for Enhanced Density, does work with DOS 2.5 and is the very reason for the existence of 2.5 flavor in the first place. Quote Link to comment Share on other sites More sharing options...
repetto74 Posted May 24, 2017 Author Share Posted May 24, 2017 Hi 1050 I will try then to set up a new ED disk and check again if this will fix :-) Quote Link to comment Share on other sites More sharing options...
repetto74 Posted May 24, 2017 Author Share Posted May 24, 2017 (edited) I do not have this Enhanced Disk option in Altirra. This is crap no way I can get this damn disk to work and always getting this 130 Error. I just do what is necessary. Loading the DOS disk than format a new disk in single density 256 bytes and then writing DOS files in it. I do see they are there with the A command but then into basic always getting the error. I have noted that also creating a new disk already formatted with DOS is not working (boot error on cold start). I have attached the new disk formatted with DOS 2.5. It will boot to the DOS menu but cannot save on it. If someone may try it with Altirra and let me know? DOS TEST DISK.atr Edited May 24, 2017 by repetto74 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 24, 2017 Share Posted May 24, 2017 You need to write DOS to the new disk as well. Formatting alone (or creating a new formatted disk) does not make it bootable. You're rebooting with a formatted disk without DOS on it. 1 Quote Link to comment Share on other sites More sharing options...
repetto74 Posted May 25, 2017 Author Share Posted May 25, 2017 Hi Flashjazzcat, I am a little bit lost here. If you check the disk image in attachment all Dos files are in there. From the DOS 2.5 menu I start with the disk format option (I) and then I write DOS files on it (H). When calling back the directory (A) I do see a couple of files on the disk DOS.SYS DUP.SYS Is that good? Quote Link to comment Share on other sites More sharing options...
spookt Posted May 25, 2017 Share Posted May 25, 2017 (edited) Here's a quick screen capture of me doing what I think you're trying to do. Apologies if the text in Altirra's dialog boxes is hard to see. Edited May 25, 2017 by spookt 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 25, 2017 Share Posted May 25, 2017 Where you been hiding Spookt, Altirra is up to 2.90 beta 34 Or are you deliberately using an old version? Quote Link to comment Share on other sites More sharing options...
repetto74 Posted May 25, 2017 Author Share Posted May 25, 2017 Hi Spookt, I am doing all good as you do since the time you put the formatted disk with DOS into D1 and do a cold start. I do not select the B option "run cartridge" but I do go straight to Basic prompt where saving is not allowed (Error 130). You are using a LIST command for saving your 2 lines of basic and I do not know why you are doing that. I was trying to save with a SAVE "D1:tetst.bas" command Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 25, 2017 Share Posted May 25, 2017 Is that good? OK: I downloaded your ATR and it works just fine. Make sure you're typing "D1:" or "D:" in uppercase... that's about all I can suggest. Quote Link to comment Share on other sites More sharing options...
repetto74 Posted May 25, 2017 Author Share Posted May 25, 2017 Hi Flashjazzcat Ok thanks for confirming!! Yes I do type the command in uppercase but error all the time. I may think something is wrong with altirra (I am using it on a mac through Wine). Can you confirm what are your emulator settings ? Hardware and memory ? Quote Link to comment Share on other sites More sharing options...
spookt Posted May 25, 2017 Share Posted May 25, 2017 After creating your new blank disk and formatted it did you select 'Save disk' in the disk drives dialog? I guess so since you can then load it into D1. I used the LIST command which is just a different way of saving. LIST creates a listed text file, SAVE creates a tokenised BASIC file I think. To be honest it's been a while. Shouldn't make any difference. Make sure you have it set to R/W in the drives dialog (not virtRW). 1 Quote Link to comment Share on other sites More sharing options...
darwinmac Posted May 26, 2017 Share Posted May 26, 2017 Hi Flashjazzcat Ok thanks for confirming!! Yes I do type the command in uppercase but error all the time. I may think something is wrong with altirra (I am using it on a mac through Wine). Can you confirm what are your emulator settings ? Hardware and memory ? I was able to use your ATR image in Altirra without a problem. I am also using Altirra on a Mac (macOS 10.12.5) using WINE. I have my Altirra set up as a 64K NTSC XEGS which matches my real hardware. Can you type "DOS" from BASIC and see the DOS 2.5 menu? I am just wondering if DOS has been loaded. When using your ATR, I typed in a simple program and then typed 'Save "D1:TEST.BAS"' and it worked fine. I did do the Save Disk from Altirra to actually save the data to the ATR. However, not doing that would not give you a 130 error. I think your BASIC program would not have been saved if you did not do this. However, I will defer to more advanced Altirra users on that. Bob C 1 Quote Link to comment Share on other sites More sharing options...
repetto74 Posted May 26, 2017 Author Share Posted May 26, 2017 (edited) Hi Spookt, the disk has been saved with R/W option yes and it is working on your side so it should do with me. Noted for the list command. I think really something is wrong with Altirra itself. I will restart an emulator from scratch and see. Darwinmac the disk is working on your side also thanks for checking. Mystery of computing really o-O. I will check as you suggested and revert. Thanks guys :-) Edited May 26, 2017 by repetto74 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 26, 2017 Share Posted May 26, 2017 SAVE "D1:TEST.ME" make sure it is in capitol letters and make sure there is a space between SAVE and the " Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 26, 2017 Share Posted May 26, 2017 If you are following what Spookt did be it list or save it should work, for me that suggests you settings have become corrupt or for some reason you have a corrupt rom, firstly I'd suggest leaving that age old version behind, the newest version has so much added and emulation tweaked better it seems a shame not to use it, secondly I'd reset your settings, its the only other things I can imagine to do because you say you are doing exactly like the video (bar save instead of list) so its worth a try, in that version go to a command prompt and type Altirra /resetall That will clear the registry settings and I expect an ini file if you made it use one. Then if you want find the roms, a copy of Xformer has them in and that on Pigwa. Quote Link to comment Share on other sites More sharing options...
repetto74 Posted May 26, 2017 Author Share Posted May 26, 2017 Hi Maclaneinc. Thanks for your suggestions. I will grab the Altirra 2.90, redo from scratch and see. Have to test the SAVE command with a space yet as a last try. :-) Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 26, 2017 Share Posted May 26, 2017 You don't need a space. Quote Link to comment Share on other sites More sharing options...
repetto74 Posted May 26, 2017 Author Share Posted May 26, 2017 I am trying Altirra 2.90 but things are worst. I can even get the Atari XL emulation to boot and all paths to roms are correctly set Also I noticed that settings of the 2.80 version are also set by default. How do you reset all with WINE and a MacOsX? Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 26, 2017 Share Posted May 26, 2017 To get the roms sorted go to System, firmware, Firmware images and san, point to where the roms are and they will be auto recognised for the system. On version 2.90 last few beta's (maybe more) you can go to Tools, Options then settings and reset from within Altirra.. Quote Link to comment Share on other sites More sharing options...
