TurboBasic XL v1.5 MADS source (disassembly)
TURBO-BASIC TURBO-BASIC XL Source Code disassembly
34 replies to this topic
#26 JAC! OFFLINE
JAC!
  • 1,815 posts
  • Always looking for GFX and MSX for my demos
Posted Thu Jun 15, 2017 4:04 AM
Wow! Tested it with 1.4. also and you're right.
I was 100% sure I had that problem and programmed "around it" for years.
And I always wondered why still most program run (well, hard program use the feature to return values from ML).
It is even mentioned in the 2nd revision of the "Turbo Basic Handbuch" (German, ABBUC).
I'll make sure it'll be removed from the 3rd revision, in case one is released.
#27 flashjazzcat ONLINE
flashjazzcat
  • 14,334 posts
Posted Thu Jun 15, 2017 4:51 AM
I found that returning values via USR worked in the interpreter, but was broken in compiled programs.
#28 pirx OFFLINE
pirx
    Moonsweeper
  • 448 posts
Posted Fri Jun 16, 2017 4:36 AM
ditto
#29 erichenneke OFFLINE
erichenneke
    Moonsweeper
  • 407 posts
Posted Fri Jun 16, 2017 10:08 PM
yep, exactly.
#30 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Sat Jun 17, 2017 3:50 PM
It will be an issue with the compiler and that run time program. Turbo Basic Interpreter is what I have the source for.
#31 Kyle22 ONLINE
Kyle22
  • 3,837 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Mon Jun 19, 2017 7:58 PM
I ran into that one as well.  Is the bug in the compiler, runtime or both?
#32 mechanerd OFFLINE
mechanerd
    Star Raider
  • 96 posts
Posted Sat Dec 16, 2017 4:18 AM
Is there a version of Turbo Basic XL with the fixes compiled and ready to run?  I could use the runtime for the old copy of the Action Annex BBS written in BASIC XL. I really want to run the actual hardware and not the emulator.  Eventually I want to migrate to Altirra.
I came across a Happy Computer 1.5 Turbo Basic by Ostrowski but it dumps the BBS code .  I don't have the actual cartridge anymore for plain Turbo Basic XL or Basic XL.
It's been a very long time since I compiled 6502 ASM. I could dust off the Macro Assembler.
I'll trade you the Midi Music System source code I came across. I need to contact the author and see if it's freeware or abandonware, or ??
Edited by mechanerd, Sat Dec 16, 2017 4:19 AM.
#33 dmsc ONLINE
dmsc
    Moonsweeper
  • 478 posts
Posted Sat Dec 16, 2017 7:43 AM
Hi!
Current version of the disassembled sources is at https://github.com/dmsc/turbo-dis
Attached is the resulting ATR with original and bugfixed interpreters.
#34 mechanerd OFFLINE
mechanerd
    Star Raider
  • 96 posts
Posted Sat Dec 16, 2017 4:02 PM
Hi!
Thanks! Will let you know if this fixes the issue,,,
#35 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Sat Dec 16, 2017 7:13 PM
I looked over what people are considering a bug in Turbo Basic, and I quickly noticed that that those pieces of source code is something most people will not do when making a basic program. However I do recall there was an issue with a compile program not handling variable arrays properly.  I had not a chance to mess around with this since the summer. Have other major priorities going on. It would be difficult to optimize anything further without sacrificing speed.
My ideal to get around the SpartaDos compatibility issue is to use the first extended memory bank on a 130XE, but others came out and said, why don't we use the other 48K to store the program. Something I myself will not mess around with.
Also tagged with one or more of these keywords: TURBO-BASIC, TURBO-BASIC XL, Source Code, disassembly
