Xebec Posted July 16, 2017 Share Posted July 16, 2017 Hey folks, I have a SIDE2 which boots correctly into SpartaDOS-X now on multiple 800XLs will not load completely on a 130XE I have. SD-X starts to load saying "Ultimate Clock Installed" then just hangs indefinitely. I've tried it with and without a CF card installed and various power off/reset button combinations. The 130XE appears to be fully functional -- I can play games on it without a problem.. The built in RAM test succeeds (let it run for several passes continuously).. Any suggestions? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted July 16, 2017 Share Posted July 16, 2017 Look up the memory test 'XRAM' - it was recently posted in another thread within the last couple of days. It'll test more thoroughly and accurately than the built-in test. Also, what are the contents of CONFIG.SYS on the SIDE2 cart? Quote Link to comment Share on other sites More sharing options...
Xebec Posted July 16, 2017 Author Share Posted July 16, 2017 Venkman - thanks for making me realize I can fix this myself . I updated the cart to SD-X 4.48 and now it works fine on the 130XE. If it wasn't working I would have gone through troubleshooting the boot process (I didn't realize until now CAR: shows the contents of the SIDE2). I will run XRAM on it anyway.. Thanks again! 1 Quote Link to comment Share on other sites More sharing options...
