KLund1 Posted July 16, 2017 Share Posted July 16, 2017 Hi all, I need some direction. I got a Model 1 with screen and expansion unit. This is my first try with one of these, since 1981. First thing, check power bricks with a meter. They seem to work. Ok power screen with nothing connected. Screen is white/blue/gray. cable out front seems a bit loose. Power keyboard only. Red LED lit. OK so far. Connect screen to keyboard. Power up. Same white/blue/gray screen. Play with controls, front and back of screen. no change. Not a good start. Oh, there was a din cable with white and yellow RCA connectors mixed with all cables. I connect this to a VCR, then to a commodore monitor what works with Atari 400/600XL RF. I get snow on channel 3, on channel 4 when I type the snow changes a bit then back to normal snow. I switched white and yellow. not much difference. I tried the din cable I use for Atari's no difference. So I think the keyboard works, but have not sure what to do next. I looked for active forums that I know must be out there but had little luck with google. I see that there is not a lot of activity here either. Suggestions on what to do next or where to go for some nube help? Thanks Quote Link to comment Share on other sites More sharing options...
