Large Capital Letters in BASIC
35 replies to this topic
#1 Casey OFFLINE
Casey
    Moonsweeper
  • 341 posts
Posted Mon Jul 17, 2017 6:11 PM
Is it possible to access the large capital character definitions and use them in BASIC or Extended BASIC?  I could see some definite uses for making titles or instructions stand out, and replace the lower case character set with the large capitals from the title screen.  Anyone ever done that?
#2 chue OFFLINE
chue
    Moonsweeper
  • 374 posts
Posted Mon Jul 17, 2017 6:41 PM
In Extended Basic, you can use CHARPAT to store the character patterns in a string variable.
This example grabs all of the uppercase definitions and uses them to redefine the lowercase 'a' character:
10 DIM X$(25)
20 FOR I=0 TO 25
30 CALL CHARPAT(65+I,X$(I))
40 NEXT I
50 PRINT "aaaaaaaaaaaaaaaa"
60 FOR I=0 TO 25
70 CALL CHAR(97,X$(I))
80 NEXT I
90 GOTO 60
Edited by chue, Mon Jul 17, 2017 6:48 PM.
#3 Casey OFFLINE
Casey
    Moonsweeper
  • 341 posts
Posted Mon Jul 17, 2017 8:21 PM
Sorry, I may have not been clear in what I meant.  There are 2 sets of large capital letters built into the TI.  One is the set you see when you are in TI BASIC or most other modules.  The other is the set on the master title screen when you turn the computer on.  The initial screen in TI Invaders is an example of a game that uses both fonts at the same time.  It's that kind of thing I'd like to do in BASIC.
#4 chue OFFLINE
chue
    Moonsweeper
  • 374 posts
Posted Mon Jul 17, 2017 9:31 PM
Ah, I missed that.  No worries.
#5 Lee Stewart OFFLINE
Lee Stewart
  • 3,991 posts
Posted Mon Jul 17, 2017 11:20 PM
There are three character sets stored contiguously in GROM 0:
Character Set                                    Address   ASCII Codes   Bytes/Char
Standard (the large caps you seek),              04B0h     32 – 95        8
Small Capitals (capital letters used by Basic),  06B0h     32 – 95        7
Lowercase (actually, small caps),                0870h     96 – 126       7
It is easy enough to read these tables in Assembly Language.  I am not sure how you would do it in Basic.  They are listed in Heiner Martin’s TI Intern (available in the Development Resources sticky thread, post #1), pages 105 – 107 and 127 – 128.  The GROM address of the three tables is 04B0h – 0948h.
The first character set can be read as is because it has 8 bytes/char.  However, the other two sets are stored with only 7 bytes/char.  For those, you must insert a zero byte in front of each pattern.
...lee
#6 RXB OFFLINE
RXB
  • 3,603 posts
Posted Tue Jul 18, 2017 4:44 AM
Using RXB:
100 CALL CLEAR
110 PRINT "WORKING..."
120 A=1204! A is the address in decimal of Hex >04B4
130 FOR C=32 TO 95! This counts standard characters 32 to 95
140 CALL MOVES("G$",7,A,D$)! Moves 7 bytes from GROM address in A to STRING D$
150 FOR F=1 TO 7! Count to fix from HEX to Decimal
160 R=ASC(SEG$(D$,F,1))+32! R is adjusted value of HEX converted to Decimal
170 NEXT F! Counter of string position
180 E$=E$&"00"! Adds in null bytes to make a full character definition
190 A=A+7! Increments A to next character definition in GROM
200 CALL CHAR(C,E$)! Load new definition of character
210 PRINT CHR$(C);
220 NEXT C
230 END
#7 S1500 OFFLINE
S1500
  • 4,830 posts
Posted Tue Jul 18, 2017 7:14 AM
After all these years, how did I not notice that there's two sets of all-capitals fonts? Huh.
#8 sometimes99er OFFLINE
sometimes99er
  • 4,231 posts
Posted Tue Jul 18, 2017 7:45 AM
Using RXB:
100 CALL CLEAR
210 PRINT CHR$(C);
220 NEXT C
230 END
It does not seem to work correctly. Since "the large caps" has 8 bytes and not 7 bytes, see Lee's post, that may be part of the problem.
In the case of working with 8 bytes (instead of 7), using CALL MOVE (instead of CALL MOVES) would probably make it much simpler, shorter and quite fast.
#9 senior_falcon OFFLINE
senior_falcon
  • 1,516 posts
Posted Tue Jul 18, 2017 8:58 AM
You can do this using XB256.  You need to be in screen2 with CALL LINK("SCRN2") and then CALL LINK("CHSETL") will replace the 7 pixel high font with the 8 pixel one.
I just discovered that the XB256 manual is incomplete.  There is another subprogram: CALL LINK("CHSETD") which will load a character set with true lower case letters that have descenders on the p, y, etc.
#10 RXB OFFLINE
RXB
  • 3,603 posts
Posted Tue Jul 18, 2017 9:23 AM
There is no CALL MOVE in RXB the only MOVE works in edit mode for lines and came from GK XB.
LOL now I see the problem!!!
My conversion from HEX to Dec failed.
Edited by RXB, Tue Jul 18, 2017 9:42 AM.
#11 sometimes99er OFFLINE
sometimes99er
  • 4,231 posts
Posted Tue Jul 18, 2017 9:39 AM
Hmmm. Okay. Guess the examples in the manual fooled me. :|
Anyways, a CALL MOVES (from GROM to VDP) should then be able to do the trick with "the large caps" in a sec or so. ;)
#12 sometimes99er OFFLINE
sometimes99er
  • 4,231 posts
Posted Tue Jul 18, 2017 9:52 AM
Here are plain BASIC programs that simply redefine the characters to "the large caps" using CALL CHAR. ;)
#13 Tursi OFFLINE
Tursi
  • 5,666 posts
  • HarmlessLion
Posted Tue Jul 18, 2017 12:26 PM
It's worth noting that the actual location of the characters in GROM can vary slightly -- when I did the loader for the multicarts I wrote code to look up the actual address by parsing the GROM branch vector. It was hacky but it worked. ;)
Also, completely unimportant, but the 99/4 actually has an even smaller small capitals character set than the 4A, stored only 6 bytes to a character IIRC. (I remember I had to deal with a difference in count). ;)
#14 Casey OFFLINE
Casey
    Moonsweeper
  • 341 posts
Posted Tue Jul 18, 2017 4:26 PM
Thanks all!  Good stuff.  I figured you'd need assembly language to actually access the character definitions, but a CALL CHAR program works just as well, if not a bit slow.
Since we're on the topic of character sets, the Extended BASIC addendum comes with a small program that creates "lowercase" capitals for the 99/4 from the uppercase character definitions.  They are... interesting. :)  The 99/8 had yet another font - I still don't think the new lowercase letters are attractive, but they are better than the short capitals the 99/4A has.
#15 senior_falcon OFFLINE
senior_falcon
  • 1,516 posts
Posted Tue Jul 18, 2017 7:47 PM
#16 sometimes99er OFFLINE
sometimes99er
  • 4,231 posts
Posted Wed Jul 19, 2017 12:22 AM
Okay. Here's what I meant for RXB. ;)
100 for c=32 to 95::print chr$(c); ::next c::print : :
110 call moves("GV",512,1204,1024)
120 input i$
#17 sometimes99er OFFLINE
sometimes99er
  • 4,231 posts
Posted Wed Jul 19, 2017 1:37 AM
Nice one. It's almost an okay small caps for the TI-99/4. The N should have been redefined as it looks like an M.
Works surprisingly well on the TI-99/4A, but off course you don't need it there. Almost a blueprint.
#18 RXB OFFLINE
RXB
  • 3,603 posts
Posted Wed Jul 19, 2017 2:32 AM
Good catch I should not be up all night writing docs.
#19 sometimes99er OFFLINE
sometimes99er
  • 4,231 posts
Posted Wed Jul 19, 2017 3:01 AM
It's funny how the lowercase small caps in the TI-99/4A takes up 7 bytes per character, when only 5 bytes are needed (per character). I suspect true lowercase was planned and space allocated. And then maybe Marketing found true lowercase to be too professional.
GfxRip:
#20 mizapf OFFLINE
mizapf
  • 3,674 posts
Posted Wed Jul 19, 2017 3:46 AM
The small caps have the advantage that they look like the standard font of the TI, but smaller, so this could be useful in games (like Parsec); on the other hand, maybe they did not want to encourage people to use lower-case, since everything in the TI world seems to be uppercase (up to the assembler language).
#21 sometimes99er OFFLINE
sometimes99er
  • 4,231 posts
Posted Wed Jul 19, 2017 10:33 AM
The TI-99/8 font is very similar to the TI-99/4.  ;)
#22 Casey OFFLINE
Casey
    Moonsweeper
  • 341 posts
Posted Wed Jul 19, 2017 3:32 PM
Wow you are right there.  I didn't realize just how similar they were!  A rather curious choice indeed!
#23 Tursi OFFLINE
Tursi
  • 5,666 posts
  • HarmlessLion
Posted Thu Jul 20, 2017 1:41 AM
What they chose to change there is interesting...!
#24 TheBF OFFLINE
TheBF
  • 1,046 posts
Posted Thu Aug 10, 2017 1:17 PM
...lee
I had never played with GROMs before so I tried making a CHARSET word by reading the GROMs.
I found a neat trick in the SPECTRA.a99 file that moves directly from GROM to VDP.
I could simplify it a bit because my kernel has a sub-routine to set VDP write mode, so I did the same for GROM address,
It's a cool hack using 2 auto-incrementing devices.
Van Haartelijke dank Filip Van Doren  ;-)   (big Dutch thank you)
CROSS-ASSEMBLING
l: GRMWA!
        R0 GRMWA @@ MOVB,     \ Set GROM source address
        R0 SWPB,
        R0 GRMWA @@ MOVB,
        RT,
CODE: GVMOVE ( grom_addr vdp_addr cnt -- ) \ GROM->VDP direct move
        R0 POP,
        WMODE @@ BL,             \ Set VDP target address
        R0 POP,
        GRMWA! @@ BL,            \ Set GROM source address
@@1:    GRMRD @@ VDPWD @@ MOVB,  \ Copy from GROM to VDP
        TOS DEC,                 \ count in TOS register (R4)
        @@1 JNE,
        TOS POP,
        NEXT,
        END-CODE
Then in Forth  I just had to do
HEX
: BIGCAPS  ( -- ) 4B0 PDT  200 GVMOVE  ;
But when I tried it my letters were scrambled. ?
I found the address for the start of the Font in GROM,  in Classic99, is >04B4.
And with that it works great.
Is there a way to find where the Font data resides in the system?
BF
#25 Lee Stewart OFFLINE
Lee Stewart
  • 3,991 posts
Posted Thu Aug 10, 2017 5:08 PM
BF
Well, the GPL jump table starts at >0010 in GROM 0. The “Load Standard Character Set” routine vector is at >0016. All of these vectors are “BR @address” GPL instructions, which will be >4000 + GROM address.  If you extract that address and add 5 to it, the next 2 bytes will be the address of the Standard Character Set table. From Heiner Martin’s book:
Addr  Code  Source Instructions
0016  4393  BR   GROM@>0393
0393    31  MOVE >0200 TO VDP*>834A FROM GROM@>04B0
0394  0200
0396  B04A
0398  04B0
For Classic99 and my TI-99/4A (I think):
0016  4396  BR   GROM@>0396
0396    31  MOVE >0200 TO VDP*>834A FROM GROM@>04B4
0397  0200
0399  B04A
039B  04B4
Of course, this presumes that the jump table always starts at >0010 in GROM 0.  All I know for sure is that it does so in the above two instances.
...lee
