Keyboard 'B' Key Stopped Working
10 replies to this topic
#1 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,024 posts
Posted Sat Jul 29, 2017 5:41 PM
Just today the B key on my keyboard stopped working.  Any idea why this might be and how to fix it?  It's a later beige model keyboard if that matters.
I don't think it's dirty, because no matte how many times I hit it it never works.
#2 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,024 posts
Posted Sat Jul 29, 2017 6:04 PM
I just noticed that one of the wires from the keyboard has detached from the clip thing on the motherboard they go into.  I can't exactly tell what that thing is, but it looks more like a wire 'clip' or something rather than something they're soldered into.  Are they actually soldered into that thing or do they just somehow clip in?
#3 arcadeshopper OFFLINE
arcadeshopper
  • 3,408 posts
Posted Sat Jul 29, 2017 8:35 PM
likely a wire is loose/broken or the mylar is stuck, which keyboard do you have? look at my faq post pinned at the top of the forum for the types..
they usually clip in to the connector..
#4 helocast OFFLINE
helocast
    Chopper Commander
  • 165 posts
Posted Sat Jul 29, 2017 9:22 PM
Attached File  keyboard.JPG   237.56KB   2 downloads
It's great you got the troubleshooting down to a connector wire. Frankly I would have expected more based on common scan column and row.
#5 apersson850 OFFLINE
apersson850
    Moonsweeper
  • 491 posts
Posted Sun Jul 30, 2017 1:09 PM
When a key on my beige boards stop working, it's usually the key itself. Hammering on it frantically restores functionality.
#6 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,024 posts
Posted Sun Jul 30, 2017 2:24 PM
Now the system won't power on.  I have no idea what I did to it, but I'm getting nothing.  I wonder if I'm not better off just buying a new one?
#7 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,024 posts
Posted Sun Jul 30, 2017 4:34 PM
Update:  My power supply went bad, so I need to fix that before I can fix the B key.
My keyboard mech is an ALPS one (green circuit board).  I can pop the key cap off and see a little key mech underneath, but I have no idea what to do from there to fix it.  It looks like it has two little push tabs on either side, does this mean it can be popped out?
EDIT: ok it appears that the B key is intermittent, not broken.  Not sure how to fix that.  It works just fine for a while then stops for a few key presses, then works again.  Any ideas?
#8 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,024 posts
Posted Sun Jul 30, 2017 6:48 PM
Looks like some contact cleaner fixed the issue.
Does anyone know where I can get a replacement fuse thing?  The reason my power supply wasn't working was because the fuse had blown.
#9 arcadeshopper OFFLINE
arcadeshopper
  • 3,408 posts
Posted Mon Aug 7, 2017 9:26 AM
the external power supply?  I sell working ones if you decide it's not worth the effort, which power supply do you have? there were 3-4 different ones..
Greg
#10 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,024 posts
Posted Tue Aug 8, 2017 7:27 AM
Greg
Not sure.  IIRC it was black, didn't have the embossed TI logo, had a green 'checked' sticker, and of course that fuse thing.  It seems to be working just fine without the fuse pack though.
#11 arcadeshopper OFFLINE
arcadeshopper
  • 3,408 posts
Posted Fri Aug 11, 2017 9:32 PM
just put it on a power strip with a circuit breaker and you are fine
