Minecraft won't run on Toshiba A105-S2236
Minecraft PC Toshiba Software Drivers Video Cards help please ATI Radeon Xpress 200M AMD
9 replies to this topic
#1 TheTIGuy OFFLINE
TheTIGuy
    Dragonstomper
  • 556 posts
  • keki wa usodesu!
  • Location:At the bus-stop, waiting for a bus that will likely not come...
Posted Sat Jul 29, 2017 10:41 PM
For some reason, Minecraft won't run on my near stock (RAM upgraded to 2 gigs from 512MB stock, windows vista stock now win7), it says this: (full error report)
      Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 29/07/17 23:38
-- System Details --
Details:
    Minecraft Version: 1.5.2
    Operating System: Windows 7 (x86) version 6.1
    Java Version: 1.8.0_141, Oracle Corporation
    Java VM Version: Java HotSpot™ Client VM (mixed mode), Oracle Corporation
    Memory: 450538920 bytes (429 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
    JVM Flags: 2 total; -Xms512m -Xmx1024m
    AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
    Suspicious classes: No suspicious classes found.
    IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
    LWJGL: 2.4.2
    OpenGL: ~~ERROR~~ NullPointerException: null
    Is Modded: Probably not. Jar signature remains and client brand is untouched.
    Type: Client (map_client.txt)
    Texture Pack: Default
    Profiler Position: N/A (disabled)
    Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
    at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
    at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
    at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
    at org.lwjgl.opengl.Display.createWindow(Display.java:311)
    at org.lwjgl.opengl.Display.create(Display.java:856)
    at org.lwjgl.opengl.Display.create(Display.java:784)
    at org.lwjgl.opengl.Display.create(Display.java:765)
    at net.minecraft.client.Minecraft.a(SourceFile:235)
    at avv.a(SourceFile:56)
    at net.minecraft.client.Minecraft.run(SourceFile:507)
    at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT c8ed6f9e ----------
As said, i have a Toshiba Satellite A105-S2236 laptop compuyter with a ATI Radeon Xpress 200M with vista drivers as i can't find win7 drivers.
#2 RodLightning OFFLINE
RodLightning
    Dragonstomper
  • 757 posts
Posted Sat Jul 29, 2017 11:36 PM
Someone on Minecraft forum suggests that previous version of ATI Catalyst driver, 9.12 supports the proper version of OpenGL which was dropped for some reason in later release.  It's worth a try.  Which Catalyst version do you have currently?
http://www.oldapps.c...php?old_ati=102
#3 TheTIGuy OFFLINE
TheTIGuy
    Dragonstomper
  • 556 posts
  • keki wa usodesu!
Posted Sat Jul 29, 2017 11:57 PM
2.0.2519.38216, thats what it says at least.
STATUS: downloading it now....
STATUS: tried it, still won't work. =(
STATUS: apparently, somehow tried a different version instead of the x32 version, gonna try again.
Edited by TheTIGuy, Sun Jul 30, 2017 12:53 AM.
#4 TheTIGuy OFFLINE
TheTIGuy
    Dragonstomper
  • 556 posts
  • keki wa usodesu!
Posted Sun Jul 30, 2017 1:05 AM
So as you can see, i tried several different videocard drivers, so i think my ancient videocard and Java 8 don't like each other.
And nor does Java 7. So im gonna give up playing MC. This saddens me, as that is one of the rather few things i can enjoy myself with.
Well, it seems that MC won't run under ANY version of the driver that bundles catalyst, so i'm gonna try the XP driver that i use that MC used to run on, then find a newer version with a 1/2 decently recent version of openGL.
Edited by TheTIGuy, Sun Jul 30, 2017 1:33 AM.
#5 -^CrožBow^- ONLINE
-^CrožBow^-
  • 7,128 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Wed Aug 2, 2017 2:38 PM
I could have sworn that Minecraft can run in an software 3d mode? I know that in its very early days I could play MC on even a netbook with some decent speed. Few things to try, but I would look up how to change the default render method the game is trying to use and see if you can switch to something else?
In fact, I thought MC supported software rendering, DirectX, as well as OpenGL? Isn't there a selector to choose within the main menu? So if you can't even get it to load up to the initial menu to begin playing, then that is where you have to research where to edit whatever config file it might rely on and see where to manually change the render method to at least get it back to that point.
Now it has been a very long time since I messed with MC but I do recall it having such options way back when?
#6 TheTIGuy OFFLINE
TheTIGuy
    Dragonstomper
  • 556 posts
  • keki wa usodesu!
Posted Sat Aug 5, 2017 2:55 AM
I don't see this menu in the launcher, and i can't get to the game to get to the menus.
#7 Serguei2 OFFLINE
Serguei2
    Dragonstomper
  • 785 posts
Posted Sat Aug 5, 2017 1:18 PM
The best way to help you is to go to Minecraft messageboard and explain your problem.
http://www.minecraftforum.net/forums
Someone can help you.
#8 TheTIGuy OFFLINE
TheTIGuy
    Dragonstomper
  • 556 posts
  • keki wa usodesu!
Posted Mon Aug 7, 2017 3:54 AM
Well, just confirmed my computer isn't powerful enough to play MC. :mad: :_(
#9 Serguei2 OFFLINE
Serguei2
    Dragonstomper
  • 785 posts
Posted Mon Aug 7, 2017 7:31 AM
Maybe the last version takes more resources for your computer.
Try 1.5 or 1.0. It might work but it's very slowly.
I have a computer with 2G and I can play Minecraft.
Both Old_Alpha 132211 and Old_Alpha 132328  play just fine.
Those versions are very basic.
#10 TheTIGuy OFFLINE
TheTIGuy
    Dragonstomper
  • 556 posts
  • keki wa usodesu!
Posted Mon Aug 7, 2017 4:13 PM
I have a 1.6 celron that played up to 1.6.1 on winXP, so I'm afraid I'm toast.
OK, i tested the oldest alpha available, but alas, t'was fruitless.
Edited by TheTIGuy, Mon Aug 7, 2017 4:31 PM.
Also tagged with one or more of these keywords: Minecraft, PC, Toshiba, Software, Drivers, Video Cards, help please, ATI, Radeon Xpress 200M, AMD
