some more 15 pin gameport pc to 5200 adapters
104 replies to this topic
#26 ave1 OFFLINE
ave1
    Dragonstomper
  • 513 posts
Posted Thu Dec 7, 2017 10:21 PM
What pc controller did you find?
#27 0078265317 OFFLINE
0078265317
  • 6,522 posts
Posted Thu Dec 7, 2017 11:11 PM
I sent you a pm.
#28 bohoki OFFLINE
bohoki
  • 1,570 posts
Posted Fri Dec 8, 2017 6:47 PM
3 left
thanks 007 and other purchasers
i too would like to know of the controller you plan on using  just for statistical data
my favorite ones are the gravis joystick red buttons/grey buttons, the gravis gamepad ,mako pad ,interact pc powerpad pro ,pc propad ,pc propad4,wico merlin,quickshot warrior,pc raider,performance pc mission,micro innovation terminator
many other brands work
radioshack made a neat gamepad
zoltrix made a spiffy one
pc concepts
kraft
champ
logitec makes a sturdy joystick but like all flightsticks has such tremendous throw for flight control precision it is not fun to play any action games
Edited by bohoki, Fri Dec 8, 2017 6:49 PM.
#29 Swami OFFLINE
Swami
  • 2,703 posts
Posted Fri Dec 15, 2017 2:58 PM
PM sent. Do you make any adapter like this that goes from the old PC port to the atari 9-pin or know if they are available?
Thanks!
#30 0078265317 OFFLINE
0078265317
  • 6,522 posts
Posted Mon Dec 18, 2017 10:37 PM
Don't think 9 pin is possible.
As for the adapter came in the mail today.  Works great.  Best controller ever.  The analog is awesome.  Even for missle command, and super breakout.
#31 Swami OFFLINE
Swami
  • 2,703 posts
Posted Tue Dec 19, 2017 4:24 PM
I have seen them eBay with a built in A/D converter. It would be fine with old anolog PC controllers, but I don't know what would happen if you used a digital controller, like a D-pad, with an A/D converter to a 2600/7800/A8.
#32 bohoki OFFLINE
bohoki
  • 1,570 posts
Posted Tue Dec 19, 2017 10:35 PM
it is possible its just i don't want to make it it takes a bit more labor and parts and i do my best to make these as cheap as possible
thankfully it only takes 3 connectors which run about 50 cents each  2 capacitors that cost like 2 cents  a couple inches of solder a couple inches of network wire i got for free a little pushbutton i salvaged from broken electronics a half a stick of hot glue lately ive been putting on two plastic handles so those cost another 40 cents
the hassle of stripping 16 ends of wire is tedious  soldering all the wires in the right places cutting off the metal bits from one of the connectors
#33 ave1 OFFLINE
ave1
    Dragonstomper
  • 513 posts
Posted Tue Dec 26, 2017 12:26 PM
Thanks!
This should work:  https://rover.ebay.c...tm/272222183107
#34 0078265317 OFFLINE
0078265317
  • 6,522 posts
Posted Tue Dec 26, 2017 12:33 PM
Or maybe this.
https://www.ebay.com...FgAAOSwa51ZbkEg
#35 bohoki OFFLINE
bohoki
  • 1,570 posts
Posted Tue Dec 26, 2017 7:46 PM
wow that thing avi posted is basically a masterplay converter but calibrated for pc use it looks good although it needs a couple breakout boards to add a second fire button
the one 007 posted is a neat idea to be able to use a pc joystick with a 2600 i would like to experiment to see where the direction triggers or use a gravis gamepad which is basically a digital to analog converter then have it run through the analog to digital converter then use it with a masterplay
but then it gets so crazy and more complex than stolen identity 3
#36 0078265317 OFFLINE
0078265317
  • 6,522 posts
Posted Tue Dec 26, 2017 9:37 PM
What I posted is basically the same thing as ave 1 minus the wire isn't it.
#37 bohoki OFFLINE
bohoki
  • 1,570 posts
Posted Tue Dec 26, 2017 11:30 PM
i think you have a confusion about what adapts to what
one thing adapts a 2600 controller to a pcgameport
the other thing adapts a pc joystick to a 2600
so they are opposites
#38 0078265317 OFFLINE
0078265317
  • 6,522 posts
Posted Wed Dec 27, 2017 10:59 AM
ok
#39 tbb033 OFFLINE
tbb033
    Chopper Commander
  • 173 posts
Posted Wed Dec 27, 2017 12:09 PM
A bump on the adapter, potential Atari 5200 (PC Gameport) controllers pictured.
There are tons of inexpensive PC Gameport controllers at the thrift stores!
PC gameport joysticks are pretty much the ONLY gaming thing I ever see at goodwill.
Hey, look at that both the Flighsticks I have right there in the middle of that lower shelf. I also have an aforementioned Gravis pad, and an original sidewinder pad.
#40 bohoki OFFLINE
bohoki
  • 1,570 posts
Posted Wed Dec 27, 2017 2:19 PM
thanks for the shout out
all the ones i made are sold i have someone on a waitlist
i originally started making these to shut people up cause it was nothing but controller complaints
i have raised my price a bit since nearly 30% goes to the post office but i want to keep it so its not an expensive thing like a modded controller
i'm not saying i dont make money this last batch paid for a super overlay kit so i have that now yay
but the tediousness makes me feel like the simpsons with those guys that go to the north pole for ice and sell it for a dollar a bag
Edited by bohoki, Wed Dec 27, 2017 2:22 PM.
#41 john_q_atari OFFLINE
john_q_atari
    Chopper Commander
  • 159 posts
Posted Fri Dec 29, 2017 6:16 PM
Well I appreciate your efforts bohoki. I found your earlier post and got me a interact pc makopad. That plus this adapter I recently got from you allows me to dust off my 5200 and get up and running with a few games. Someday I'll eventually get the time to work on my other 5200 projects: refurb my 5200 trakball, try my hand at rebuilding a 5200 controller with the Best Electronics rebuild kit, do the 5200 power mod, do the UAV video mod, etc. But at least for now I'm up and running with your adapter.
On a related note, I thought about what you said on how tedious the build was, I'm wondering if perhaps some version of the blue connector you use in your adapters can be found where through-hole pins could be used (instead of soldering wires to the plug connector), a PCB board made, and then perhaps the build could be: solder Atari 5200 connector to board, solder PC connector to board, solder 5200 controller connector to board, and perhaps solder a push-button switch to board. Materials cost might go up, but maybe installation could be as quick as 5 or 10 minutes per adapter. Or just skip assembly and ship as a kit and let the buyer do the soldering. Getting all that set up would be a lot of work so I am not volunteering you for the task, and I doubt I would have the time for the task, but I would be curious to know if anyone has located a suitable connector. All I can find are the standard shallow metal flange connectors on digikey, or the 8.95 cable from Console 5. (and its a cable so you aren't saving much, in fact its $8 more than a connector).
#42 bohoki OFFLINE
bohoki
  • 1,570 posts
Posted Fri Dec 29, 2017 8:51 PM
there are a few construction shortcuts companies have come up with but they generally require 3 injection molding machines
i guess back then they could outsource the "core" which is the 15 pin housing
one way they used was to crimp little grabers to the wires and then shove them onto the back side chromed headers then they would enrobe the whole shebang in a sort of polyproplene insulation block then mold the handle over that so no soldering on that end who knows maybe the cord (aka harness) could be oursourced i notice gravis has 2 types on the original pc gamepad some have the metal shield and screws the other is just plastic (with the 5200 type locking notches)
the problem ive noticed now is that the plug shrouds ive found (cheapest) are not chamfered so the controllers that have the thicker plastic plug wont slip under the wide fingers that hold the plug to the housing
also another thing is that i use pliers to bend the male end to allow the 5200 controllers locking lugs to fit into the metal socket
as to making a kit for someone to make was explored but anyone who can do that can easily buy the components from china to make a dozen of them for close to the shipping cost it would me for me to send it to someone a kit to make 1 via priority mail
shipping is fairly constant it costs approx $2.60 to send something first class in a padded envelope and i can get a 3 pack of padded envelopes for $1 at the dolla tree
i was thinking of trying these  but there is the plug depth problem again
https://www.ebay.com...epid=1486949891
Edited by bohoki, Fri Dec 29, 2017 8:56 PM.
#43 Swami OFFLINE
Swami
  • 2,703 posts
Posted Fri Dec 29, 2017 9:27 PM
Something like this works well for that type of problem in my experience, if you can find it in 15-pin, although I would prefer something more rugged than the ribbon extension for getting flopped around a lot.
https://www.ebay.com...872.m2749.l2649
#44 bohoki OFFLINE
bohoki
  • 1,570 posts
Posted Fri Dec 29, 2017 9:47 PM
yea i was going to post these as an option but once again plug depth issue
https://www.ebay.com...ue/310992366324
#45 john_q_atari OFFLINE
john_q_atari
    Chopper Commander
  • 159 posts
Posted Sat Dec 30, 2017 12:56 AM
So far this is the best I could find... If only they didn't put that metal casing around it it would be perfect. Cheap too in larger quantities. I suppose you could cut off the metal ends to fix the depth issue but I wouldn't want to hack each piece to do that. I guess if you ordered in volume maybe someone could just give you the blue center with the prongs.
https://www.ebay.com...5F/172972873858
#46 bohoki OFFLINE
bohoki
  • 1,570 posts
Posted Sat Dec 30, 2017 2:17 PM
yea if i had a autofeed crimping machine i could crimp on connectors to the wires shove them on the pins and just hotglue a glob
i was thinking about making a mold out of a controller plug with play dough and injection mold black hot glue for a handle but then i though these things are never going to look professional so whats the point
i cant just order the core (well i can but its actually more expensive) its the way they are assembled the plug has a front and back the metal holds everything together i cut off the metal and use my soldering iron to fuse the pieces together
they got this one in australia but i am not paying those rates for a plug
https://www.ebay.com...or/112675581677
#47 bohoki OFFLINE
bohoki
  • 1,570 posts
Posted Thu Feb 1, 2018 5:27 PM
everyone waiting for another batch hang in there i got the parts (well supplier screwed up i ordered 10 m and 10 f they sent me 12 m and 8 F)
sPQxDtU.jpgi'll pm people in order when i get them built but i am slow and lazy and do them in stages cause its a bunch of wire stripping and tining
#48 DrVenkman OFFLINE
DrVenkman
  • 3,861 posts
  • Back off, man! I'm a scientist.
Posted Sat Feb 10, 2018 1:56 PM
If you're keeping a list, please add me to it. I've been looking for a decent controller solution for my 5200 since I got it.
#49 K-Rod 13 OFFLINE
K-Rod 13
    Space Invader
  • 25 posts
Posted Sat Feb 10, 2018 2:58 PM
If a new batch comes out in the near future, I would like to be added to the list please.      Thanks.
#50 alortegac OFFLINE
alortegac
    Chopper Commander
  • 198 posts
Posted Thu Feb 22, 2018 9:05 PM
Hi again,
Would you know whether the Saitek Cyborg 3d will work?
Thanks!
Al
Edited by alortegac, Thu Feb 22, 2018 9:06 PM.
