+DrVenkman Posted August 11, 2017 Share Posted August 11, 2017 Looks like some soldering/wire work : http://atariage.com/forums/topic/212773-incognito-install-a-collectors-perspective/ Maybe Incognito 2 needs less? Also, does anyone know what the bus/edge connector on the back of the 800 main board is for ? the inaccessible one? A bit of soldering work doesn’t bother me in the slightest. That edge connector, I understand, was used for factory testing assembled systems before they were cased up. Someone will no doubt correct me if I’ve conflated recollections here. Quote Link to comment Share on other sites More sharing options...
Bryan Posted August 11, 2017 Share Posted August 11, 2017 I believe that's correct. Quote Link to comment Share on other sites More sharing options...
DavidMil Posted August 11, 2017 Share Posted August 11, 2017 That edge connector, I understand, was used for factory testing assembled systems before they were cased up. Someone will no doubt correct me if I’ve conflated recollections here. They put those machines on large carrousels and ran 'burn in tests' for a company specified time before adding the outer plastic cases. This was still the standard all the way into 2000's for just about every computer company in the US. The holes in the case may have been for bypass switches or other modifications. DavidMil Quote Link to comment Share on other sites More sharing options...
Xebec Posted August 12, 2017 Author Share Posted August 12, 2017 Very cool background on the edge connector -- I assume it's never been used for any upgrades or modifications then? Quote Link to comment Share on other sites More sharing options...
Bryan Posted August 12, 2017 Share Posted August 12, 2017 Very cool background on the edge connector -- I assume it's never been used for any upgrades or modifications then? Although you could use it for some things, it's not in a very useful place once the machine is assembled. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted August 19, 2017 Share Posted August 19, 2017 The original Incognito requires a little soldering, but it's easy. The most difficult part is removing and replacing the RD4/5 resistors. The connector is for factory diagnostics. It provides lots of useful signals. Not really necessary to use them if you have Incognito because its PBI has most of them and more. Quote Link to comment Share on other sites More sharing options...
