AlyoshaTAS Posted August 9, 2017 Share Posted August 9, 2017 Hi, I noticed this really obvious tow line glitch occur in both my emulator and the newly released A7800 emulator. But, I can't determine anything that is wrong with emulation that would cause it. So I am wondering if maybe this occurs on real hardware as well? If anyone has this game and might be willing to confirm if this glitch happens on console I would be appreciative. Or, if this is already a known glitch and there is a reference as to what is happening that would be helpful too. Thanks! Quote Link to comment Share on other sites More sharing options...
+Mitch Posted August 9, 2017 Share Posted August 9, 2017 I do not recall seeing that on a real 7800 though it has been a while since I have played it. Mitch Quote Link to comment Share on other sites More sharing options...
Trebor Posted August 9, 2017 Share Posted August 9, 2017 I do not recall seeing that on a real 7800 though it has been a while since I have played it. So I am wondering if maybe this occurs on real hardware as well? It occurs on real hardware. This came up a few years ago while testing some hardware. Confirmed occurrence on an AT84, A1, and A3 serial. Quote Link to comment Share on other sites More sharing options...
AlyoshaTAS Posted August 10, 2017 Author Share Posted August 10, 2017 Ah ok thanks for the info. It seems strange that they would release a game with such an obvious bug, but if that is the case then so be it. At least I know I don't need to try to 'fix' it. Quote Link to comment Share on other sites More sharing options...
Trebor Posted August 10, 2017 Share Posted August 10, 2017 Ah ok thanks for the info. It seems strange that they would release a game with such an obvious bug, but if that is the case then so be it. At least I know I don't need to try to 'fix' it. Strange (or sloppy/rushed) to release the game with such an obvious bug, indeed, there is no need to try to 'fix' it: https://www.youtube.com/watch?v=Xp-2Sj78hnU Quote Link to comment Share on other sites More sharing options...
+Mitch Posted August 10, 2017 Share Posted August 10, 2017 Weird, I don't remember ever seeing that. Obviously my memory isn't what it once was... Mitch Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted August 10, 2017 Share Posted August 10, 2017 Crap, who knows, maybe he is running it from my MCP cart and it is causing it? I believe everything you tell me about the 7800 these days. LOL Quote Link to comment Share on other sites More sharing options...
Trebor Posted August 10, 2017 Share Posted August 10, 2017 Crap, who knows, maybe he is running it from my MCP cart and it is causing it? No, sir... The recent capture above is from a Water Ski cart playing back on an 'AT84 Serial' last night. However, the "testing" part I mentioned was when you were designing the multi-carts. It was noticed to occur on them, and then I double checked an original cart on the various original hardware consoles. 2 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted August 10, 2017 Share Posted August 10, 2017 Now see...I have an AT84 serial unit and do not recall ever seeing this before either. I will have to load up the rom on my Mateos cart later in addition to the Anniversary #2 cart to test this. Quote Link to comment Share on other sites More sharing options...
Trebor Posted August 10, 2017 Share Posted August 10, 2017 Now see...I have an AT84 serial unit and do not recall ever seeing this before either. I will have to load up the rom on my Mateos cart later in addition to the Anniversary #2 cart to test this. Interested to know the results; if it does not occur at all, it wouldn't be the first (or the last) time there are mixed results with consoles of the same serial line. It may be a tad surprising in the case of the glitch never happens though, considering the same effect is seen on an A1 and A3 serial console as well. *EDIT: Another capture to demonstrate the glitch under original real hardware; this time during The No Swear Gamer's video @1:17. It can also be noticed several other times throughout the playback: Quote Link to comment Share on other sites More sharing options...
Shawn Posted August 11, 2017 Share Posted August 11, 2017 Would it be very difficult to fix this glitch? Quote Link to comment Share on other sites More sharing options...
RevEng Posted August 11, 2017 Share Posted August 11, 2017 I think it would require a fair bit of disassembly and analysis. I took a quick look, and I don't believe it's a hardware timing glitch. I believe there's a condition that the game isn't correctly accounting for in the very first frame of a 0-angle transition. (negative to positive, and visa versa) The assembly code quality doesn't appear to be first rate. Lots of beginner type stuff like "and #$f0" followed by 4x "lsr" shifts, unnecessary register value reloads, and the like. I'm guessing the logic will wind up being a lot more spaghetti than usual, and I'm a bit overcommitted right now to take this on. If anybody is interested, the rope angle setting/drawing routine is at 9CAE. 1 Quote Link to comment Share on other sites More sharing options...
Jinks Posted August 18, 2017 Share Posted August 18, 2017 Hmm. Never noticed anything with this game with the real cart and also the concerto. Quote Link to comment Share on other sites More sharing options...
KevinMos3 Posted August 23, 2017 Share Posted August 23, 2017 There are a lot of things that are out of alignment in this game. I realigned parts of the shoreline in my color & title screen hack a few years ago, but I didn't notice the tow line. It may be fixable by just moving the tow-line sprites to the left or right by a pixel, without even addressing any coding. I'd like to look at it sometime, but maybe someone else can get to it before I do. :-) Quote Link to comment Share on other sites More sharing options...
