DISK DOC TO PDF
43 replies to this topic
#1 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
  • Status? I don't need no stinkin' status!
Posted Thu Aug 10, 2017 7:20 AM
COPY-C was to me probably the most powerful disk copy program that was put out for the TI.
Here is the manual in pdf form (English version).
I wonder if version 1.9 was ever released?
Attached File  COPYCDOC.pdf   76.23KB   39 downloads
#2 ti99iuc OFFLINE
ti99iuc
  • 1,256 posts
Posted Thu Aug 10, 2017 8:06 AM
I have v1.8a present in my database, thinking it is the same of 1.8
#3 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Thu Aug 10, 2017 8:28 AM
Me too Ciro.
The docs talk of a version 1.9 which talked if some additional features.
#4 Schmitzi OFFLINE
Schmitzi
  • 3,983 posts
  • ToXiC
Posted Thu Aug 10, 2017 10:40 AM
The latest version I ever found (or heard of) is v1.8a Rev1 27.02.1988
#5 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Fri Aug 11, 2017 12:38 AM
The Game Writers Tool Kit
Attached File  TGWTK.pdf   55.06KB   27 downloads
TI bulletin boards back in the old days - how many did you call? How high was your phone bill?
Attached File  TI_BBS_4_3_89.pdf   50.38KB   19 downloads
#6 digdugnate ONLINE
digdugnate
    Dragonstomper
  • 883 posts
Posted Fri Aug 11, 2017 5:00 AM
attachicon.gifTGWTK.pdf
attachicon.gifTI_BBS_4_3_89.pdf
i'm pretty sure my dad did one of the Dallas ones, but i would've been pretty small.
#7 Ksarul OFFLINE
Ksarul
  • 4,293 posts
Posted Fri Aug 11, 2017 9:07 AM
BTW, if you ever turn up a copy of a slight variant to this program, it is the same, but tuned to an Atronic Disk Controller. That one was titled Copy-A. . .
#8 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Sat Aug 12, 2017 4:04 AM
John Birdwells Disk Utilities 4.2
Attached File  Disk Utilities 42 Documentation.pdf   54.84KB   14 downloads
Attached File  Disk Utilities 42 reference.pdf   45.03KB   16 downloads
#9 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Mon Aug 14, 2017 5:40 AM
Attached File  Tennis.pdf   9.42KB   19 downloads
Attached File  TENNIS.dsk   90KB   10 downloads
While converting this DV/80 I read the part about serving the ball. It stated that by holding the joystick forward (or back depending on which side you're on) the serve would be faster. Also putting the stick to the left, center or right is where the ball would land. I never knew this so I tried it on the FinalGrom version(Databiotics) - it didn't seem to work. I tried it on the file I had on my Flashrom (Not databiotics) - it didn't seem to work. So I finally dug out the disk version from Nicesoft - E/A 5 conversion using Supersave - It worked.
Can someone else try this out and see if I'm right or just nuts? (no comments from the peanut gallery on my general mental ineptitude.)
Can the files on the dsk image be converted for use in the FinalGrom?
#10 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Fri Aug 18, 2017 1:55 PM
Attached File  dbm.pdf   46.19KB   14 downloads
Navarone Data Base Management
Attached File  DstationII.pdf   9.43KB   12 downloads
D-Station II
Attached File  errorcodes.pdf   7.55KB   17 downloads
Error Codes
Attached File  Galaxy.pdf   13.49KB   16 downloads
Galaxy by Avalon
#11 Schmitzi OFFLINE
Schmitzi
  • 3,983 posts
  • ToXiC
Posted Sat Aug 19, 2017 1:18 AM
Good Work ! thx
#12 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Tue Aug 22, 2017 7:21 AM
Attached File  Users Groups 1996.pdf   22.39KB   16 downloads
TI Users Groups circa 1996
Attached File  GUARDIAN.pdf   8.97KB   14 downloads
Guardian by Softmail Incorporated, Programmed by Kevin Crowder
#13 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Mon Aug 28, 2017 9:30 AM
Attached File  Airline.pdf   12.61KB   14 downloads
Attached File  Dtp.pdf   62.5KB   22 downloads
Thanks to Ksaruls text
Attached File  Console Debugging.pdf   31.82KB   31 downloads
#14 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Wed Aug 30, 2017 7:47 AM
Attached File  PeeksPokes.pdf   13.7KB   24 downloads
#15 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Fri Sep 1, 2017 9:56 AM
Attached File  GAME OF WIT.pdf   19.31KB   9 downloads
Attached File  NITWIT.pdf   16.19KB   8 downloads
Attached File  WIT OR WITOUT.pdf   21.25KB   9 downloads
Attached File  WITS END.pdf   35.21KB   9 downloads
Attached File  WITTLE TAGS.pdf   23.1KB   9 downloads
Attached File  WIT_SERIES.DSK   90KB   8 downloads
#16 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Sun Sep 10, 2017 8:16 AM
Attached File  Text to Speech.pdf   32.59KB   13 downloads
Attached File  GRAPH.pdf   21.93KB   14 downloads
A page full of teeny,tiny squares to help make your graphic masterpiece - printed from an xb program with about 10 lines of code.
#17 apersson850 OFFLINE
apersson850
    Moonsweeper
  • 445 posts
Posted Sun Sep 10, 2017 9:57 AM
attachicon.gifTennis.pdf
I'be played Tennis quite a lot, and yes, the serve is affected by how you hold the joystick. My version is on disk. I've only played it on a real TI.
Tennis is one of very few programs that don't work with 16-bit RAM for the expansion memory. The players split in two pieces, which run in different directions. This can be alleviated by turning on the VDP access wait state hardware I have, but then playing the game against the computer is pointless. You have no chance at all.
#18 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Thu Oct 5, 2017 7:10 AM
Attached File  Computer Center.pdf   52.63KB   21 downloads
Cleaned up and Converted from Paperport max file to pdf.
This is for all of you who are packing wood.
I'd love to see one of these built.
Attached File  Infocom Reference.pdf   105.7KB   16 downloads
Cleaned up and converted from Paperport max file to pdf.
Pretty much how to use and play an Infocom game.
#19 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Tue Oct 10, 2017 7:00 AM
Attached File  Aztec.pdf   19.43KB   10 downloads
Text conversion from PaperPort max file to pdf - Always liked this game - didn't like the teeny manual.
Attached File  Slinky.pdf   17.73KB   11 downloads
#20 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Tue Oct 10, 2017 7:04 AM
Attached File  TI RUNNER.pdf   79.33KB   10 downloads
Cleaned up PaperPort max file to pdf
Attached File  TI Speech Synthesis.pdf   2.01MB   21 downloads
Cleaned up PaperPort max file to pdf. Probably more than you'd ever want to know about Speech Synthesis..
Attached File  Picasso.pdf   119.71KB   12 downloads
Picasso Publisher 2.0 - Taken from dv/80 file to Word to pdf.
#21 --- Ω --- OFFLINE
--- Ω ---
    TI-Runner
  • 10,891 posts
Posted Tue Oct 10, 2017 8:03 AM
<< CLICK HERE FOR BLOG ENTRY >>
#22 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Tue Oct 10, 2017 9:13 PM
Thanks Omega.
The pleasures all mine.
I wonder if anyone out there has a scan of TI Artist+?
I have a really crappy one that I'm having a tough time converting to text.
#23 helocast OFFLINE
helocast
    Chopper Commander
  • 114 posts
Posted Tue Oct 10, 2017 10:15 PM
Probably not the best, but you're welcome to it:
#24 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 806 posts
Posted Tue Oct 10, 2017 11:35 PM
Thanks Helocast - I think that's for version 2.0. I am looking for the + version, I believe it was the last version put out.
#25 Schmitzi OFFLINE
Schmitzi
  • 3,983 posts
  • ToXiC
Posted Wed Oct 11, 2017 9:08 AM
yep
Attached File  TI Artist Plus manual.pdf   1.36MB   19 downloads
