MIDI Interface
458 replies to this topic
#26 skr OFFLINE
skr
    Dragonstomper
  • 674 posts
  • Ready
Posted Mon Aug 28, 2017 11:52 AM
I think i've read Midimaze on the 8bit can network with the ST via midi?  or only other 8bits?
Yes, we´ve actually played it in a mixed network (XLs and STs). An eight bit machine has to be the master, no matter how many and which computers are in the ring.
#27 Sikor OFFLINE
Sikor
  • 1,476 posts
Posted Mon Aug 28, 2017 1:05 PM
Price is ok for me. I'll be wait...
#28 StaxX28 OFFLINE
StaxX28
    Chopper Commander
  • 203 posts
Posted Mon Aug 28, 2017 1:44 PM
same for me. If i could have 2 it would be perfect :)
#29 Stormtrooper of Death OFFLINE
    Moonsweeper
  • 455 posts
Posted Wed Sep 13, 2017 4:05 AM
Ivo, since I bought a Roland R-70 drum machine. I now want to buy your midi interface. One question: Can i connect a standard SIO cable to your midi interface or is there some soldering involved ? (I cant solder....)
#30 ivop OFFLINE
ivop
    Dragonstomper
  • 923 posts
Posted Wed Sep 13, 2017 5:10 AM
There's no SIO port on the board, only a pin header which needs to be connected to the required lines of a cut-in-half SIO cable or salvaged jack.
update: It seems there's a package waiting for me which I can pick-up later today. I think it's the PCBs! Some other parts have not arrived yet, though...
#31 mytek OFFLINE
mytek
  • 3,416 posts
Posted Wed Sep 13, 2017 9:08 AM
What does the header pin-out look like? Curious if it'll work with the one on the XEL (J5).
Be nice to add MIDI functionality in a Mini-ITX cased computer.
- Michael
#32 ivop OFFLINE
ivop
    Dragonstomper
  • 923 posts
Posted Wed Sep 13, 2017 10:25 AM
The pin header is as follows:
Pin    SIO
1      5    Data Output
2      4    GND
3      3    Data Input
4      6    GND
5      8    Motor Control
You could connect pin 5 to +5V with a manual switch in between, but then you'd need to enable/disable the MIDI device manually.
#33 orpheuswaking OFFLINE
orpheuswaking
  • 5,833 posts
  • 1088XLD in progress
Posted Thu Sep 14, 2017 9:13 AM
I mentioned 1 plus parts, If there are enough I would actually go for 2.
#34 ivop OFFLINE
ivop
    Dragonstomper
  • 923 posts
Posted Thu Sep 14, 2017 11:06 AM
Update: PCBs have arrived, as have all other parts except for the 50 DIN5 jacks. I got 10 PCBs, no extras this time. Sometimes I get 11 or 12.
#35 ivop OFFLINE
ivop
    Dragonstomper
  • 923 posts
Posted Sat Sep 23, 2017 6:59 AM
Rummaging through my boxes of spare parts, I found a few old DIN5 sockets, which enabled me to build a prototype!
#36 ivop OFFLINE
ivop
    Dragonstomper
  • 923 posts
Posted Sat Sep 23, 2017 9:27 AM
Results so far:
MIDI-Thru was broken (by design), but the fix was easy. One cut trace and one jumper wire and it worked!
Some of my keyboards did not work when connected to MIDI-IN. Turned out my CNY17-2 was broken. Swapped for a good one and now it works with all keyboards I own.
As for the software, I tried MIDI Sequencer (SEQ.COM) which works perfectly, has a kind of tracker-like interface, but is MIDI-OUT only (no recording).
MIDIREC, which was specifically written for this interface, plays back OK, but recording seems to miss the timing information. Replaying what I just recorded just dumps all events to the interface, w/o any timing, which sounds like a burp of all the notes played at once :)
So, basically, recording sort of sucks, replay is fine, thru is fine.
Going to try other MIDI software later (and also see if it needs patching for this interface).
#37 Kyle22 OFFLINE
Kyle22
  • 4,096 posts
  • broadway1.lorexddns.net 10001
Posted Sat Sep 23, 2017 5:21 PM
Can you test it with MIDI Track III?
#38 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 887 posts
Posted Sun Sep 24, 2017 1:12 AM
Any one havemanual for this?
James
#39 Matej OFFLINE
Matej
    Moonsweeper
  • 429 posts
Posted Sun Sep 24, 2017 2:34 AM
Nice!Cant wait to have 2x at home!
#40 ivop OFFLINE
ivop
    Dragonstomper
  • 923 posts
Posted Sun Sep 24, 2017 6:43 AM
Currently, it doesn't work. It tries to detect a MIDI Mate. I think it looks if there's an external SIO clock signal. I'm going to try to feed it a 31250 baud clock and see if that's enough.
First time ever I have a crystal running:
Plus clock divider:
It's also the first time I have a use for the frequency counter I built a while ago. I was amazed to find a 74LS590 in my collection :) The other IC is a 74LS04. The Arduino Nano is only used as a simple way to get 5V.
I'm going to test adding this to the MIDI interface later. Need a little pause first...
#41 ivop OFFLINE
ivop
    Dragonstomper
  • 923 posts
Posted Sun Sep 24, 2017 7:22 AM
Wooohoo, it works! :party:
Now, how do I operate MIDI Track III ? Any other MIDI Mate compatible software?
Found this in Atari Classics April 1994:
Rest of the article isn't of much use...
Edited by ivop, Sun Sep 24, 2017 7:39 AM.
#42 k-Pack OFFLINE
k-Pack
    Star Raider
  • 59 posts
Posted Sun Sep 24, 2017 8:25 AM
I had downloaded some files from CompuServe and took a look at them a couple of months back.  One of the files is:
MIDIDR.DOC (MIDIDR.XMO)
MIDIMate Software Interface Documentation 5/21/1985
By Hybrid Arts, Inc.
If you haven't seen it,  the .atr holding this file  and can be downloaded from this blog entry.  There is also a MIDI handler that can be used with BASIC and should work with your interface.  In case someone wants to program the next MidiMaze game.
http://atariage.com/forums/blog/572/entry-13705-a8-midi-and-the-atari-age-of-rediscovery/
This file is also in the ATR.  It might be helpful.
MIDIDEMO.BAS
MIDITRACK III simulated DEMO
By Charles Faris
This is a tutorial program for the MIDITRACK III software.  It explains the screen data and most of the commands of the MIDITRACK software.
#43 ivop OFFLINE
ivop
    Dragonstomper
  • 923 posts
Posted Sun Sep 24, 2017 9:44 AM
Thanks! The Basic MIDI Handler has been very helpful in testing the MIDI Mate compatibility. With the clock disconnected, none of it works. With the clock connected, I can dump all MIDI events coming in with:
10 OPEN #1,13,0,"M:"
20 XIO 40,#1,0,0,"M:"
30 GET #1,A:PRINT A:GOTO 30
Output works in a similar way.
PUT#1,144:PUT #1,60:PUT #1,90 ----> Note On C5, velocity 90
PUT#1,144:PUT #1,60:PUT #1,0 ----> Note On C5, velocity 0, which is equivalent to Note Off
Next: connect my 140STE and try MIDI Maze. Luckily it is already on my desk. Just needs connecting and I need to put MIDI Maze on the Gotek.
#44 ivop OFFLINE
ivop
    Dragonstomper
  • 923 posts
Posted Mon Sep 25, 2017 12:40 PM
Status so far:
This is Revision B. Size went up to 5 x 10 cm.
Did not get to testing Midi Maze yet, but I did hack a seconds SIO port in my 800XL today. Removed the monitor port and RF modulator so there was plenty of room to drill holes and get busy with a hacksaw. 13 wires at the bottom, et voìla, second SIO port :) Also finally installed my Lotharek Simple Stereo board (had that lying around for over a year), connected everything through a u-switch and installed a 6.7mm audio jack. The plan is to eventually write a program which enables you to use the Atari 8-bit as a sound module over MIDI. For that, it's nice to have a second Pokey.
Edit: it just springs to mind that I forgot the power LED. Again. Will add that tomorrow.
Edited by ivop, Mon Sep 25, 2017 12:41 PM.
#45 Mathy OFFLINE
Mathy
  • 2,958 posts
Posted Mon Sep 25, 2017 1:13 PM
Hello Ivo
Have you looked at Freetz' (ABBUC's software contest guy) MIDIJOY?  It does exactly that.  (Except maybe for the second Pokey stuff)
Sincerely
Mathy
#46 ivop OFFLINE
ivop
    Dragonstomper
  • 923 posts
Posted Mon Sep 25, 2017 1:27 PM
Yes, I'm aware of MIDIJOY. Haven't looked yet if there's source code available for the Atari side of things. If so, it can probably be patched to support MIDI Mate/Max compatible devices. But thanks for mentioning MIDIJOY. There have been times in the past I missed various projects :)
#47 mytek OFFLINE
mytek
  • 3,416 posts
Posted Mon Sep 25, 2017 2:11 PM
Status so far:
Looks great, but I would suggest you remove the Atari Logo from the silk screen since that's a registered trademark. Although you could probably get away with using it, but why take the chance and get in trouble  ;) .
- Michael
#48 ivop OFFLINE
ivop
    Dragonstomper
  • 923 posts
Posted Tue Sep 26, 2017 3:28 AM
Agreed. Didn't think about that. I removed the logo and put the required power led in its place :) I had added it to my prototype already and it's really handy to have a visual indicator for when the device is turned on by the motor control line.
#49 Gandor OFFLINE
Gandor
    Moonsweeper
  • 407 posts
Posted Tue Sep 26, 2017 1:27 PM
I am interested in 2 build units
Sent from my iPhone using Tapatalk
#50 Kyle22 OFFLINE
Kyle22
  • 4,096 posts
Posted Tue Sep 26, 2017 2:00 PM
I am interested in one (depending on price).
