Boxcar RS232 DSR dump needed
26 replies to this topic
#1 atrax27407 OFFLINE
atrax27407
  • 1,011 posts
Posted Sun Aug 27, 2017 8:11 AM
I have what may be a DSR dump of a Boxcar RS232. However, it is very odd looking when viewed with a hex editor. I need a verified dump (i.e., one from a known Boxcar RS232) to compare it with. Can anyone help? Send the DSR dump to: Rmcarmany@aol.com with "Boxcar" in the subject field. Thanks.
#2 atrax27407 OFFLINE
atrax27407
  • 1,011 posts
Posted Sun Aug 27, 2017 3:44 PM
I got a verified dump of the DSR. Exactly how it works is a mystery. It doesn't look like any DSR I have ever seen!!
#3 mizapf ONLINE
mizapf
  • 3,271 posts
Posted Sun Aug 27, 2017 3:50 PM
Show us?
#4 atrax27407 OFFLINE
atrax27407
  • 1,011 posts
Posted Sun Aug 27, 2017 4:25 PM
OK --
#5 Stuart OFFLINE
Stuart
    Dragonstomper
  • 763 posts
Posted Sun Aug 27, 2017 4:39 PM
Is that read direct off the DSR EPROM? Do you see the same data if you look at the DSR using MiniMem EasyBug? (Wondering if the address/data lines to the EPROM are jumbled, so that it reads correctly in situ.)
#6 atrax27407 OFFLINE
atrax27407
  • 1,011 posts
Posted Sun Aug 27, 2017 6:34 PM
It is a direct read off the EPROM from a working unit. It is also identical to a file that I got 16+ years ago from the Lima UG library.
#7 Stuart OFFLINE
Stuart
    Dragonstomper
  • 763 posts
Posted Mon Aug 28, 2017 4:25 PM
The data lines to the EPROM are jumbled. If you re-order the bits in each byte as follows then it all makes sense:
Original data: D0-D1-D2-D3  D4-D5-D6-D7
EPROM data: D1-D5-D7-D0  D4-D6-D2-D3
For example, the first byte of the DSR header is AA (1010 1010), and this is 1E (0001 1110) in the EPROM.
#8 atrax27407 OFFLINE
atrax27407
  • 1,011 posts
Posted Mon Aug 28, 2017 6:56 PM
Bad engineering or attempted subterfuge?
#9 jedimatt42 OFFLINE
jedimatt42
  • 1,655 posts
Posted Mon Aug 28, 2017 10:14 PM
Well, sometimes it is easier to route the traces for a board if you can re-assign the pins on a device. The pin order on the sideport for these signals is in a pretty crazy order. That said, doing it on purpose to something like an eprom that requires a contract with another device, is evil.  If their goal was subterfuge, then it was clever. If their goal was to save a batch of pcboards that were designed wrong, then it was resourceful. If their goal was to just be easier, then I'd call it lazy, but that is me being judgmental, without any knowledge of 1980s EDA tools.
I just did this on my TIPI project, but that was a MISTAKE. Not intentional, will be corrected before release.
-M@
#10 apersson850 OFFLINE
apersson850
    Moonsweeper
  • 491 posts
Posted Tue Aug 29, 2017 4:21 AM
Do you have the unit in question? If so, disassembling from the device would give you the right listing. The memory chip doesn't care which data bit is used for what. It's only a problem if you read it, or write to it, in a different way.
#11 Swim ONLINE
Swim
    Chopper Commander
  • 136 posts
Posted Tue Aug 29, 2017 7:47 AM
Seems a nice project for this device would be to add higher baud rates than 2400.
#12 atrax27407 OFFLINE
atrax27407
  • 1,011 posts
Posted Tue Aug 29, 2017 10:16 AM
Go for it, Richard!
#13 acadiel OFFLINE
acadiel
  • 1,402 posts
  • www.hexbus.com
Posted Wed Aug 30, 2017 1:24 PM
I have one of these. Will need to find it. Maybe someone can in unobfuscate the order of the bits and "fix" the image.
#14 atrax27407 OFFLINE
atrax27407
  • 1,011 posts
Posted Sun Sep 3, 2017 11:07 AM
Due to the efforts of Richard Bell, we now have a dump of the Boxcar RS232 as seen through the scrambled address lines as seen from the console. However, to burn a replacement EPROM one would still have to use the one previously posted. Here is how it appears unscrambled.
#15 acadiel OFFLINE
acadiel
  • 1,402 posts
  • www.hexbus.com
Posted Mon Sep 4, 2017 6:55 AM
Awesome!  Glad he got to the unscrambled one.  I was about to do a mini memory dump :)
I dumped mine for comparison too, it has "V1.1" on it.
#16 acadiel OFFLINE
acadiel
  • 1,402 posts
  • www.hexbus.com
Posted Mon Sep 4, 2017 6:58 AM
In case anybody be wants to see this.
The AC adaptor is 9V, 200ma, positive tip.
#17 Schmitzi OFFLINE
Schmitzi
  • 4,330 posts
  • ToXiC
Posted Mon Sep 4, 2017 2:02 PM
thanks for the PSU info. "tip" means the pin insight, I think.
(Have 80 PSU´s in the list now, there in 44 for the console)
#18 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,122 posts
Posted Mon Sep 4, 2017 2:18 PM
Wrote a quick and dirty Geneve program to scramble/unscramble the EPROM.
Acadiel's v1.1 appears to be the same as what Swim dumped.
If you update the baud rate table, I can scramble the binary so that you can burn it.
To unscramble the EPROM contents, the bits are re-ordered as follows:
EPROM[abcd efgh] -> [dagh ebfc]
Attached File  gene0039.png   6.05KB   4 downloadsAttached File  gene0040.png   5.92KB   4 downloads
#19 acadiel OFFLINE
acadiel
  • 1,402 posts
  • www.hexbus.com
Posted Mon Sep 4, 2017 3:55 PM
Tip is literally tip in this case. It's a standard mini 3.175mm tip/sleeve connector.
#20 atrax27407 OFFLINE
atrax27407
  • 1,011 posts
Posted Mon Sep 4, 2017 4:00 PM
Insane Multitasker and I "double teamed" the Boxcar RS232 file. I took the existing "clear" file that we got with the DSR dump through the console which was unscrambled and altered the baud rates. The original went from 110 bps to 9600 bps. The table had been truncated by one value. I changed the baud rates to go from 300 bps to 19.2K bps I sent the file back to him and he re-scrambled it so the it could be burned directly into an EPROM (TMS2532).
Remember, this file is completely untested. Someone with a Boxcar RS232 will have to try the new baud rate table out. There are no guarantees that it wll work properly. Pleaae post your results (and system configuration) so everyone can share in the "fun"
#21 Swim ONLINE
Swim
    Chopper Commander
  • 136 posts
Posted Mon Sep 4, 2017 9:55 PM
Nice work guys. :)
Of course I am working dawn to dark this week on the real job so unless it rains I will not be able to burn an EPROM with this new .bin until later in the week. :(
#22 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,122 posts
Posted Tue Sep 5, 2017 3:52 PM
Once the changes (and scrambling) are confirmed, I'll post a disk image with the program source/executable and the DSR images.
#23 Swim ONLINE
Swim
    Chopper Commander
  • 136 posts
Posted Thu Sep 7, 2017 4:09 AM
Hmmm? I don't see a wire tying pin 21 and 24 of your EPROM acadiel? Is your pin 21 lifted from the socket or trimmed off? Ah, you have a revision "A" board maybe that's why.
#24 acadiel OFFLINE
acadiel
  • 1,402 posts
  • www.hexbus.com
Posted Thu Sep 7, 2017 5:00 PM
Nope, no wire that I can see.
Sent from my Moto G (5) Plus using Tapatalk
#25 Swim ONLINE
Swim
    Chopper Commander
  • 136 posts
Posted Thu Sep 7, 2017 10:47 PM
Perhaps the black case could indicate earlier board versions.
IMG 2658
Album: Box Car Peripherals
3 images
0 comments
This didn't go well. I just learned "My Media" reduces the size of pics. This board has hand wiring and the EPROM has pins 21 and 24 strapped with the leg of pin 21 bent out so it doesn't make contact with the socket. acadiel's board is a version "A" and shows no hand wiring or strapping of the EPROM.
So far, I'm unable to successfully test atrax27407s high speed .bin. I can program the EPROM successfully but the EPROM does not function as expected when connected to the 99/4a console. Will investigate further as time allows.
