what programming language was used for the hobbit (1982)
13 replies to this topic
#1 Jackel192 OFFLINE
Jackel192
    Star Raider
  • 94 posts
Posted Wed Sep 13, 2017 6:55 PM
just in case I want to port it to another system
#2 Stephen OFFLINE
Stephen
  • 6,636 posts
  • A8 Gear Head
Posted Wed Sep 13, 2017 7:03 PM
Doesn't matter.  If you don't have the source code, you'll be doing a disassembly and porting that way.
#3 tschak909 OFFLINE
tschak909
  • 1,986 posts
Posted Wed Sep 13, 2017 7:07 PM
We always get the bright ones, don't we?
-Thom
#4 Jackel192 OFFLINE
Jackel192
    Star Raider
  • 94 posts
Posted Wed Sep 13, 2017 7:14 PM
then can someone give the source code? i have no idea what to do with disassembled code
#5 tschak909 OFFLINE
tschak909
  • 1,986 posts
Posted Wed Sep 13, 2017 8:25 PM
tc4d13e_trek_double_facepalm_by_texanjoe
#6 TMR OFFLINE
TMR
  • 3,385 posts
  • Beeping the horn on the data bus
Posted Thu Sep 14, 2017 2:10 AM
To translate the facepalms... the source code was never released because it was, at the time, a commercial product and nobody in their right mind goes around distributing the source for something they're selling since it can be used to recreate said product or produce competing products.
You don't have the skills to port The Hobbit, it's Z80 machine code in it's original form or 6502 machine code for the C64 versions (there are two if memory serves) and, without a solid working knowledge of both the source and target platforms (because you'd have to understand how the source machine handles it's bitmapped screen just to start with), porting something just isn't going to happen.
A slight edit to add that porting code is significantly harder than writing something from scratch. The sensible thing to do as a beginner would be to pick one platform, learn to program it and write your own games. 6502 and the Atari 8-bit are a good starting point and, if you ask sensible questions people will be able to help... assuming you haven't annoyed them already with threads like this one to the point they won't. Then once you have something worth protecting you'll probably have a bit more knowledge of what that entails to actually do it.
Edited by TMR, Thu Sep 14, 2017 2:37 AM.
#7 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 5,446 posts
Posted Thu Sep 14, 2017 3:22 AM
The Hobbit was also launched for the Apple ][, BBC Micro and Oric 1, to mention a few 6502 based systems to run head first into. Actually the Beeb had two versions according to Wikipedia, the disc version with graphics and the tape version without graphics. Possibly the latter might be the "easiest" task to port to the Atari 8-bit, a text only adventure game.
Then again if someone is seriously interested and willing to learn something about converting binary code, there should be plenty of much easier games to practise on than a 32K+ adventure game.
#8 David_P OFFLINE
David_P
    Dragonstomper
  • 849 posts
Posted Thu Sep 14, 2017 2:15 PM
Or run the Apple emulator on your Atari...
#9 bob_er OFFLINE
bob_er
    Space Invader
  • 32 posts
Posted Thu Sep 14, 2017 3:59 PM
If you know/like/understand polish, and you know/like/understand C and LISP, you can port this version to your system: https://www.jfedor.o...dor/hobbit.html
As C/LISP are higher level languages than assembler, your task may be even simpler.
#10 slx OFFLINE
slx
  • 1,273 posts
Posted Fri Sep 15, 2017 10:04 AM
I wonder if Polish + C/Lisp is significantly easier to learn than Z80 assembly  :-D
#11 Kyle22 OFFLINE
Kyle22
  • 3,180 posts
Posted Sat Sep 16, 2017 6:13 PM
Personally, I would say Z80 Assembly. That's because I already know it.
Would an automated translator work with comments in code?
If so, it shouldn't be too difficult of a project. Both C and LISP are available for Atari.
#12 +Adam+ OFFLINE
+Adam+
    Moonsweeper
  • 422 posts
Posted Thu Sep 21, 2017 3:52 PM
Well, Polish really is quite hard  :)
Edited by +Adam+, Thu Sep 21, 2017 4:19 PM.
#13 drac030 OFFLINE
drac030
  • 1,836 posts
Posted Thu Sep 21, 2017 4:02 PM
Polish is hard for non-Poles, but if you learn it being a kid as your mother's tongue it is not so bad at all, right? ;)
But let us not go out of the scope of this thread. It was said that the game is available in C. The C language is something everyone knows or, if not, it is certainly something everyone can learn, as it is for sure about 100 times easier than Polish. ;)
#14 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 5,446 posts
Posted Fri Sep 22, 2017 1:51 AM
The question is which C compiler is suitable for the Atari 8-bit. I know about CC65, perhaps there is a version of LCC too that can be used. If the source code would contain complex constructs that need rewriting to get it to compile, perhaps having a go at hacking one of the existing 6502 versions of The Hobbit anyway would be less work. Supposedly you'd have at least 5-6 different versions of the game to choose from, counting different releases on the Beeb and the C64. It is not within my interests, but the text only version for the Beeb perhaps is most straightforward to work with as you don't have any graphics subsystem to worry about. How difficult it is to plug in graphics to the game afterwards is another matter.
Edited by carlsson, Fri Sep 22, 2017 1:52 AM.
