bradhig1 Posted September 22, 2017 Share Posted September 22, 2017 are there any cheats for alfred challenge that turn off the time limit and give infinite lives? The last level sped up for no reason and the stupid jumps are broken cause there is no room for error which there should be cause humans are not perfect. Quote Link to comment Share on other sites More sharing options...
Kiwi Posted September 22, 2017 Share Posted September 22, 2017 Start the game. If you hit the ~ key. It'll stop the game and bring up the debugger menu. From there you can edit the RAM address. What is the RAM for the time and lives? Trial and error. Normally the game starts out at 3 lives so the number 3 in the RAM could be the live counter address. Click the address, input new number and then press enter. Press Frame +1 will advance the game one frame and a new screen will be drawn. Did the lives counter change, did something other than live counter change, or did it do nothing. Quote Link to comment Share on other sites More sharing options...
+stephena Posted September 22, 2017 Share Posted September 22, 2017 There's a better way of doing this: Enter the debugger with ~ In the RAM area, click "Search" and then "OK", without specifying anything to seach for Exit the debugger, play the game and lose a live Re-enter the debugger, and in the RAM area click "Compare" and then enter '-1' (indicates to search all previous values for ones that decreased by 1) If any memory cells are highlighted, then those decreased by 1; they are good candidates for the one you're looking for Either repeat the process, or manually change those cells to something else and see what effect it has. Note that this doesn't always work, since lives are sometimes stored in different ways. But in most cases it's just by 1, and the process will work fine. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted September 22, 2017 Author Share Posted September 22, 2017 How would I stop the disappearing platforms from disappearing? Quote Link to comment Share on other sites More sharing options...
