Jr. Pac-Man - power pills & toy-candy behavior
4 replies to this topic
#1 Tidus79001 OFFLINE
Tidus79001
    Star Raider
  • 130 posts
  • I will not comply
Posted Mon Oct 9, 2017 12:39 PM
I have noticed that in Jr. Pac-Man for the Atari 2600 that the toy-candy only destroys the power pills located in the 4 corners of the maze.  The 2 power pills in the center sections of the maze are not affected when touched by the toy-candy.  Is the behavior the same in the arcade, or did someone just miss this when programming the 2600 version?
Edited by Tidus79001, Mon Oct 9, 2017 12:42 PM.
#2 Tidus79001 OFFLINE
Tidus79001
    Star Raider
  • 130 posts
  • I will not comply
Posted Mon Oct 9, 2017 7:59 PM
Here are my findings after doing tests on the arcade version VS the 2600, 5200 and 7800:
Arcade (tested via MAME) - 2 center power pills are not destroyed when the toy-candy touches the power pill
2600 (as seen on actual 2600 hardware & via emulation) - 2 center power pills are not destroyed when the toy-candy touches the power pill
5200 (tested with emulation) - 2 center power pills are destroyed when the toy-candy touches the power pill
7800 (tested with emulation)- 2 center power pills are destroyed when the toy-candy touches the power pill
Interesting to know that the 2600 was programmed to match the arcade in terms of behavior of the power pill & toy-candy interaction.
*I did find an interesting glitch in the Atari 5200 ROM while testing tonight.  I died as the upper right power pill was destroyed by the toy-candy.  After respawning the destroyed image of the power pill was still there.  No response from the destroyed power pill when moving over it.
Edited by Tidus79001, Mon Oct 9, 2017 8:03 PM.
#3 imstarryeyed OFFLINE
imstarryeyed
    Moonsweeper
  • 349 posts
Posted Mon Oct 16, 2017 11:42 AM
In the arcade the prizes seem to destroy with center pills if the prize has gone the requite number of steps.  I often have seen the prize not destroy the center pills if the prize is early on its journey, but given enough time whatever pill it has its sights set on gets destroyed.
The prizes kill the power pill at the end of its journey as its way of leaving the maze if there are pills still available.
Can you try eating the corner pills first and leaving the center ones?  I wonder if you can make it happen?
#4 Tempest OFFLINE
Tempest
    Jonboi Waltune Groupie
  • 26,773 posts
Posted Mon Oct 16, 2017 11:59 AM
Yeah that's a well known bug.
#5 KaeruYojimbo ONLINE
KaeruYojimbo
  • 1,495 posts
Posted Mon Oct 16, 2017 3:53 PM
Has anyone ever tried eating all of the energizers before the prize can destroy one? Does the prize then become trapped in the maze?
