JamesD Posted November 22, 2017 Share Posted November 22, 2017 (edited) I think this fixes the Plus/4 version, and the loops should be similar on the Apple II.It has not been verified against other versions though. Run time was 4.2 seconds. 20 K=0:T=0:P=0:I=0 30 SCNCLR 100 PRINT "Prime Number Generator" 110 INPUT "Upper Limit";N 120 eTime=TIME 130 T = (N-3)/2 140 DIM A(T+1) 160 FOR I=0 TO T:A(I)=1:NEXT I 200 FOR I=0 TO T 220 IF A(I)=1 THEN P=I+I+3:PRINT P;".";:K=I+P:GOTO 250 240 PRINT "..";:NEXT I:GOTO 330 250 IF K<=T THEN FOR K=K TO T STEP P:A(K)=0:NEXT K 260 NEXT I 330 eTime = (TIME - eTime)/60 340 PRINT 350 PRINT "Total: ";eTime 360 END *edit*I forgot, the Plus/4 supports ELSE. This is cleaner and if you remove the spaces from the loops it runs in 4.1 seconds.I vaguely remember something about Commodore being faster if you leave the variable off of the NEXT statement, but I'm not messing with it. 200 FOR I=0 TO T 220 IF A(I)=1 THEN P=I+I+3:PRINT P;".";:K=I+P:ELSE PRINT "..";:NEXT I:GOTO 330 250 IF K<=T THEN FOR K=K TO T STEP P:A(K)=0:NEXT K 260 NEXT I Edited November 22, 2017 by JamesD Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 22, 2017 Share Posted November 22, 2017 Okay, I messed with it. The Plus/4 turned in a time of 3.76666667 with this section of code.This may speed up other Microsoft versions as well but I haven't tried it yet. 160 FORI=0TOT:A(I)=1:NEXT 200 FORI=0TOT 220 IFA(I)THENP=I+I+3:PRINTP;".";:K=I+P:ELSEPRINT"..";:NEXT:GOTO330 250 IFK<=TTHENFORK=KTOTSTEPP:A(K)=0:NEXT:NEXT Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 22, 2017 Share Posted November 22, 2017 Hand timing sucks, but here is the latest.The MC-10 with the enhanced ROM benchmarks around 2.5 seconds with this loop configuration. 160 FORI=0TOT:A(I)=1:NEXT 200 FORI=0TOT 220 IFA(I)THENP=I+I+3:PRINTP;".";:K=I+P:IFK<=TTHENFORK=KTOTSTEPP:A(K)=0:NEXT:ELSEELSEPRINT "..";:NEXT:GOTO340 320 NEXT Apple II just over 3 seconds 160 FORI=0TOT:A(I)=1:NEXT 200 FORI=0TOT 220 IFA(I)=1THENP=I+I+3:PRINTP;".";:K=I+P:IFK<=TTHEN226 225 PRINT"..";:NEXT:GOTO340 226 FORK=KTOTSTEPP:A(K)=0:NEXT:NEXT Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 22, 2017 Share Posted November 22, 2017 The CoCo parser is temperamental about spaces. To get the rest out, you'd need to remove them with a crunch utility..But, like this, the CoCo says 1.71666667 seconds. Every space removed seems to cut off 0.05 seconds, which suggests it could run in 1.5666667 seconds if you run a crunch utility on it, but I make no promises.. 160 FORI=0TOT:A(I)=1:NEXT 200 FORI=0TOT 220 IFA(I)THENP=I+I+3:PRINTP;".";:K=I+P:IFK<=T THENFOR K=K TOT STEPP:A(K)=0:NEXT:ELSEELSEPRINT"..";:NEXT:GOTO340 320 NEXT Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 23, 2017 Share Posted November 23, 2017 The VZ200 takes about 6 seconds.It would do better if the editor supported longer lines, but it would require an external tokenizer and loading if from a cassette or disk image to do that.Some other BASICs may benefit by doing that as well since the only part of many BASICs that cares is the tokenizer.. 160 FORI=0TOT:A(I)=1:NEXT 200 FORI=0TOT 220 IFA(I)THENP=I+I+3:PRINT P;".";:K=I+P:IFK<=TTHEN226 225 PRINT "..";:NEXTI:GOTO340 226 FORK=KTOTSTEPP:A(K)=0:NEXT:NEXT Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 23, 2017 Share Posted November 23, 2017 I'm not going to write a version for the TI or Atari. Atari Microsofo BASIC should work pretty well based on the enhanced MC-10 BASIC, or CoCo code unless the lines are too long..The Plus/4 code would probably work if neither of those do.The other BASICs, are different enough It would take longer to figure out than I want to mess with. Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 24, 2017 Share Posted November 24, 2017 (edited) I had a little time to mess with Atari Microsoft BASIC.Atari Microsoft BASIC is pretty picky which prevents using many of the optimizations I used on other versions.It doesn't seem to like lines longer than one screen line, it had issues with multiple NEXT statements for the same loop, it barfs on lines when I delete spaces, and that's just what I remember. This seems to work but someone that has used it more might be able to shave some time off of this.If Microsoft BASIC uses the Atari math library ROM then a faster version of that should also make a difference.The time here is 3.26667 on Altirra. *edit* There also appears to be a bug in the print. Use 10000 and you'll see what I mean. FWIW, the difference between this and the CoCo/MC-10 is worse when you use larger values that require scrolling the screen. The MC-10 uses a 16 bit screen scroll and the CoCo probably does as well... unless that was one of my optimizations to the MC-10 ROM, I've forgotten. 10 DEFINT A,K,I,T 20 K=0:T=0:P=0:I=0 30 CLS 100 PRINT "Prime Number Generator" 110 INPUT "Upper Limit";N 120 TIME=0 130 T = (N-3)/2 140 DIM A(T+1) 160 FOR I=0 TO T:A(I)=1:NEXT I 200 FOR I=0 TO T 210 IF A(I)=0 THEN 255 211 P=I+I+3:PRINT P;".";:K=I+P 250 IF K>T THEN 256 251 FOR K=K TO T STEP P:A(K)=0:NEXT K 254 GOTO 256 255 PRINT".."; 256 NEXT I 330 ETIME = TIME/60 340 PRINT 350 PRINT "Total: ";ETIME 360 END This gave the same result. 10 DEFINT A,K,I,T 20 K=0:T=0:P=0:I=0 30 CLS 100 PRINT "Prime Number Generator" 110 INPUT "Upper Limit?";N 120 TIME=0 130 T = (N-3)/2 140 DIM A(T+1) 160 FOR I=0 TO T:A(I)=1:NEXT I 200 FOR I=0 TO T 210 IF A(I)=1 THEN 240 212 PRINT".."; 213 GOTO 256 240 P=I+I+3:PRINT P;".";:K=I+P 250 IF K>T THEN 256 251 FOR K=K TO T STEP P:A(K)=0:NEXT K 256 NEXT I 330 ETIME = TIME/60 340 PRINT 350 PRINT "Total: ";ETIME 360 END Edited November 24, 2017 by JamesD Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 25, 2017 Share Posted November 25, 2017 (edited) I pasted the first Atari Microsoft BASIC version into Altira BASIC..It ran after changing the INPUT line, so I google "Atari BASIC timer" and "Atari BASIC clear screen" and here we are..So Altirra BASIC runs it in 1.15 seconds if I did this right.*edit* You'll need to use more digits of the timer for larger numbers. 20 K=0:T=0:P=0:I=0 50 PRINT CHR$(125) 100 PRINT "Prime Number Generator" 110 PRINT "Upper Limit";:INPUT N 120 POKE 20,0 130 T = (N-3)/2 140 DIM A(T+1) 160 FOR I=0 TO T:A(I)=1:NEXT I 200 FOR I=0 TO T 210 IF A(I)=1 THEN 240 212 PRINT".."; 213 GOTO 256 240 P=I+I+3:PRINT P;".";:K=I+P 250 IF K>T THEN 256 251 FOR K=K TO T STEP P:A(K)=0:NEXT K 256 NEXT I 330 ETIME=PEEK(20)/60 340 PRINT 350 PRINT "Total: ";ETIME 360 END 120 POKE 19,0:POKE 20,0 330 ETIME=(PEEK(19)*256+PEEK(20))/60 Edited November 25, 2017 by JamesD 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted November 25, 2017 Share Posted November 25, 2017 (edited) I suggest you test all the computers in that video on Assembly for speed and for highest number of digits accuracy. You will find the TI99/4A does 10 digits and the rest top out at 6 to 8 at best. The reason TI99/4A would win hands down is 16 bit CPU vs the rest are all 8 bit CPU's. Edited November 25, 2017 by RXB Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 25, 2017 Share Posted November 25, 2017 I suggest you test all the computers in that video on Assembly for speed and for highest number of digits accuracy. You will find the TI99/4A does 10 digits and the rest top out at 6 to 8 at best. The reason TI99/4A would win hands down is 16 bit CPU vs the rest are all 8 bit CPU's. At this point, we are using the Sieve of Sundaram algorithm which doesn't even require floating point. The latest code is more about looping, indexing arrays, finding variables, and finding line numbers quickly. Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 25, 2017 Share Posted November 25, 2017 I pasted the first Atari Microsoft BASIC version into Altira BASIC.. It ran after changing the INPUT line, so I google "Atari BASIC timer" and "Atari BASIC clear screen" and here we are.. So Altirra BASIC runs it in 1.15 seconds if I did this right. *edit* You'll need to use more digits of the timer for larger numbers I'm getting the same numbers with and without the Fast FP Math option set. Did Altirra 2.71 actually use 6502 math libraries when this option is turned off? Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 25, 2017 Share Posted November 25, 2017 The TI version care of sometimes99er from the TI group. The TI can't dynamically allocate arrays so the code has to be modified to run with different a limit.Also, the TI can only print to the bottom of the screen, so it has to scroll after every line which slows it down.I added an input at line 111 so it would be easier to time and it takes bout 10.5 seconds. 50 call clear 100 PRINT "Prime Number Generator" 110 N=250 130 T=(N-3)/2 140 DIM A(123) 160 FOR I=0 TO T::A(I)=1::NEXT I 200 FOR I=0 TO T 210 IF A(I)=1 THEN 240 212 PRINT".."; 213 GOTO 256 240 P=I+I+3 241 PRINT P;"."; 242 K=I+P 250 IF K>T THEN 256 251 FOR K=K TO T STEP P::A(K)=0::NEXT K 256 NEXT I 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 26, 2017 Share Posted November 26, 2017 emulation is not always spot on in timing.. Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 26, 2017 Share Posted November 26, 2017 emulation is not always spot on in timing.. I think that's the least of the problems here given the fact that I'm trying to time most of these by hand. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted November 26, 2017 Share Posted November 26, 2017 At this point, we are using the Sieve of Sundaram algorithm which doesn't even require floating point. The latest code is more about looping, indexing arrays, finding variables, and finding line numbers quickly. So finding Primes only matters if it is very very small numbers? If the point was to find the least effective way to find least number of primes fast yea you are on the right track. It does point to a favored result as the only reason to do the test. Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 26, 2017 Share Posted November 26, 2017 Atari BASIC C returned a time of 3.18333333 when using a limit of 250. Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 26, 2017 Share Posted November 26, 2017 (edited) Just so people know, I've been privately running a lot of these with a limit of 10000.But if you try to DIM a large enough array on the TI-99/4A, it runs out of memory.The other machines handle it just fine.To make it handle different limits, I set out to DIM it to the largest array size I might use and then added the LIMIT input.That's when I discovered the issue. But it will handle 5000. I haven't tried to find exactly where it runs out of memory. 110 PRINT"LIMIT?";::INPUT N 140 DIM A(2500) Edited November 26, 2017 by JamesD Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 26, 2017 Share Posted November 26, 2017 I looked at the Ahl's benchmark thread, and OSS BASIC XE was much faster than BASIC XL.I couldn't get it to run on the emulator through. Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 26, 2017 Share Posted November 26, 2017 I thought I'd check a couple changes to the Plus/4 version since it might benefit the most from a small change, and it has a timer to use to compare differences in code.The new time is 3.7 which isn't far off of other standard 6502 BASICs even though it supports 60K of user RAM.I squeezed more of the main loops together, trimmed a few spaces from the timed area, and changed the order variables were defined in.Combining two lines made a slight improvement.The spaces didn't even register since they weren't in the loops.Just changing the order variables were defined on line 20 cut .01666667 off of the results.Without line 20, the results are 3.91666667, so it's quite an improvement for so little effort. I can't guarantee a different order wouldn't yield better results on larger numbers though.But such a simple change would really add up counting to 10000 and the same change should make other Microsoft BASIC versions faster.So, CoCo, MC-10, Apple II, VZ, etc... Not sure about other BASICs. 20 K=0:I=0:T=0:P=0 30 SCNCLR 100 PRINT "Prime Number Generator" 110 INPUT "Upper Limit";N 120 eTime=TIME 130 T = (N-3)/2 140 DIM A(T+1) 160 FORI=0TOT:A(I)=1:NEXT 200 FORI=0TOT:IFA(I)THENP=I+I+3:PRINTP;".";:K=I+P:ELSEPRINT"..";:NEXT:GOTO330 250 IFK<=TTHENFORK=KTOTSTEPP:A(K)=0:NEXT:NEXT 260 NEXT 330 eTime=(TIME-eTime)/60 340 PRINT 350 PRINT "Total: ";eTime 360 END Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 26, 2017 Share Posted November 26, 2017 (edited) CoCo 1.68-1.71 MESS keeps giving different numbers. Without the high speed POKE... 3.41666667 The CoCo math library is like the original MC-10 math library. Strait 6800 code.Using 10000, the CoCo takes 67.75 seconds, but you must first type PCLEAR 1 on Extended BASIC machines to free up some of the RAM reserved for graphics in order to run with this large of number. MESS's inconsistent results may have impacted this.The MC-10 with the optimized BASIC takes about 55 seconds based on how much less time it took than the CoCo *WHEN CLOCKED AT THE SAME DOUBLE SPEED*About 100 seconds at normal speed. The Plus/4 takes 75.58333334Atari BASIC takes 138.659949 seconds. Altirra BASIC takes 48.95 seconds.. 20 K=0:I=0:T=0:P=0 30 CLS 100 PRINT "Prime Number Generator" 110 INPUT "Upper Limit";N 120 TIMER=0 130 T=(N-3)/2 140 DIM A(T+1) 160 FORI=0TOT:A(I)=1:NEXT 200 FORI=0TOT:IFA(I)THENP=I+I+3:PRINTP;".";:K=I+P:IFK<=T THENFOR K=K TOT STEPP:A(K)=0:NEXT:ELSEELSEPRINT"..";:NEXT:GOTO330 320 NEXT 330 ETIME=TIMER/60 340 PRINT 350 PRINT "Total: ";,ETIME 360 END Edited November 26, 2017 by JamesD Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 27, 2017 Share Posted November 27, 2017 The VZ makes it to 10000 in 3:15I altered the code 3 times trying to get a better result, and this was the best.I forgot to declare A as and integer on one try and it added 5 seconds to the run time.Swapping the order K and I are initialized didn't seem to matter. 10 DEFINT K,I,P,A 20 K=0:I=0:T=0:P=0 30 CLS 100 PRINT "Prime Number Generator" 110 INPUT "Upper Limit";N 130 T=(N-3)/2 140 DIM A(T+1) 150 FORI=0TOT:A(I)=1:NEXT 200 FORI=0TOT:IFA(I)=0THENPRINT"..";:NEXT:GOTO340 230P=I+I+3:PRINTP;".";:K=I+P:IFK<=TFORK=KTOTSTEPP:A(K)=0:NEXT 260 NEXT 340 PRINT 350 PRINT "DONE" 360 END Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 28, 2017 Share Posted November 28, 2017 I'm not sure what happened, but I'm getting different results for the Plus/4.Maybe with all the changes part of the program got deleted and it didn't run the full benchmark but I just didn't notice.The Plus/4 is turning in a time of 151.516667 seconds. The Apple II runs it in about 154 seconds.The VZ's 195 seconds clearly shows it's BASIC has lots of room for improvement through compiling or by optimizing the interpreter. The Plus/4 would perform significantly better if it can be patched so it doesn't use so much memory for programs. Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 28, 2017 Share Posted November 28, 2017 The Oric turns in a hand timed number around 175 seconds on Oricutron. How accurate that is I don't know. Like many machines that use a screen editor, it only allows BASIC code lines to be two screen lines in length, It supports ELSE but can't really take advantage of it here. So far Tandys are the only machines that handle really long lines. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 28, 2017 Share Posted November 28, 2017 (edited) are you remembering to poke 82,0 on zee ataree to get a couple more in per line but is it really needed? Yeah looks like you need to go back and verify your code and posted times.... Edited November 28, 2017 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 29, 2017 Share Posted November 29, 2017 are you remembering to poke 82,0 on zee ataree to get a couple more in per line but is it really needed? Yeah looks like you need to go back and verify your code and posted times.... I did not. The later times are 10000, not 250. It's easier to time by hand with large numbers. Quote Link to comment Share on other sites More sharing options...
