I must be the last one to know this [detecting FCTN-4]
17 replies to this topic
#1 TheBF OFFLINE
TheBF
    Dragonstomper
  • 616 posts
Posted Fri Nov 17, 2017 2:57 PM
I was reading on the keyboard on the Nouspikel site and found this little gem that I had never noticed before.
* Calling the built-in Fctn-4 test in console ROM
TESTF4 BL   @>0020          R12 will be modified
       JEQ  CLEAR           Fctn-4 was pressed
       JNE  NOCLR           It wasn't
I coded up a version for my Forth system to time it. It puts a true/false  flag in R4 and it only takes 170 micro-seconds, measured using the 9901 internal timer.
Wow! that is a much better way to interact with the user while in a loop than anything I have coded and it's almost 7X faster than KSCAN.
I didn't look at FB-Forth code yet, but maybe that's how the ?TERMINAL routine is coded?
CODE: FNCT4? ( -- ?)    \ 170uS  16 bit ROM speed
           TOS      PUSH,
           TOS      CLR,
           0020 @@  BL,          \ R12 will be modified
           @@1      JNE,         \ It wasn't pressed
           TOS      SETO,
@@1:       NEXT,
           END-CODE
#2 Lee Stewart OFFLINE
Lee Stewart
  • 3,695 posts
Posted Fri Nov 17, 2017 8:11 PM
       JNE  NOCLR           It wasn't
           TOS      PUSH,
           TOS      CLR,
           TOS      SETO,
@@1:       NEXT,
           END-CODE
fbForth’s ?TERMINAL calls the following fbForth system routine (inherited from TI Forth) in low RAM:
;[*== ?TERMINAL routine                     CODE =  -8  =================
* scan for <clear> press
QTM    EQU  $LO+$-LLVSPT  <---NOTE: resolves to low RAM address of next instruction (>3424)
       LI   R12,>0024       Load CRU keyboard select
       CLR  R4              Column 0
       LDCR R4,3
       SRC  R12,7           Take time(?)
       LI   R12,>0006
       STCR R12,8           Fetch all of column 0 from CRU
       LI   R3,>1000
       CZC  R3,R12          Fctn key? (>1000)
       JNE  QTERM1
       LI   R12,>0024       CRU 2nd key
       LI   R4,>0300        Column 3 (left byte)
       LDCR R4,3
       LI   R12,>0006
       STCR R12,8           Fetch all of column 3 from CRU
       CZC  R3,R12          '4' key? (>1000)
QTERM1 STST R0              Store status in R0
       ANDI R0,>2000        EQU set?
       B    @BKLINK
This is pretty much the same code as what you called in the console ROM.  Except for a couple of the instructions in the console routine, I would think your FNCT4? faster due to its running on the 16-bit bus.
...lee
[EDIT: See note at QTM label in above code.  Other edits in this color.]
  • RXB likes this
#3 TheBF OFFLINE
TheBF
    Dragonstomper
  • 616 posts
Posted Fri Nov 17, 2017 8:19 PM
Ok. Well I am changing my name to ?Terminal to match yours. It was what I always used in old DOS Forths too.
I am removing my ^C? Word too. It was slower and bigger and not very TI99ish.
#4 Lee Stewart OFFLINE
Lee Stewart
  • 3,695 posts
Posted Fri Nov 17, 2017 8:29 PM
Here is the console code for checking for FCTN-4:
C020   B    @C4B2
C4B2   LI   R12,>24           POINT TO KBD
       LDCR @HX0008,3         PNT TO CTL/SHFT ETC
       SRC  R12,7             WAIT
       LI   R12,6             POINT TO KBD INPUTS
       STCR R12,8             READ ALL 8 I/PS
       CZC  @HX1000,R12       FUNCTION DOWN?
       JNE  C4DC              YES, EXIT
       LDCR @C074,3           POINT TO '4' LINE
       SRC  R12,7             WAIT
       LI   R12,6             POINT TO I/PS
       STCR R12,8             GET DATA
       CZC  @HX1000,R12       '4' DOWN?
C4DC   RT
Note that a label beginning with ‘C’ has the hex address of its line following the ‘C’, e.g., ‘C020’ is console address >0020.
...lee
#5 TheBF OFFLINE
TheBF
    Dragonstomper
  • 616 posts
Posted Sat Nov 18, 2017 6:33 AM
C020   B    @C4B2
       SRC  R12,7             WAIT
       JNE  C4DC              YES, EXIT
       SRC  R12,7             WAIT
       STCR R12,8             GET DATA
C4DC   RT
...lee
Thanks!
#6 TheBF OFFLINE
TheBF
    Dragonstomper
  • 616 posts
Posted Mon Nov 27, 2017 6:00 AM
C020   B    @C4B2
       SRC  R12,7             WAIT
       JNE  C4DC              YES, EXIT
       SRC  R12,7             WAIT
       STCR R12,8             GET DATA
C4DC   RT
...lee
By the way...
Is there a reason this console ROM routine is not used by TI-Forth/FB-Forth?
#7 Lee Stewart OFFLINE
Lee Stewart
  • 3,695 posts
Posted Mon Nov 27, 2017 9:13 AM
By the way...
That's a good question.  Not only would it save 40+ bytes, it should execute faster (16-bit bus and all).  H-m-m-m...perhaps I will change that with the upcoming fbForth 2.0:11.
...lee
#8 mizapf OFFLINE
mizapf
  • 3,273 posts
Posted Mon Nov 27, 2017 9:22 AM
One of the uglier things in KSCAN is this:
038E 1302 JEQ >0394
0390 06A0 BL @>0498
0498 020C LI 12,>04E2 Loop counter
049A 04E2
049C 060C DEC 12
049E 16FE JNE >049C
04A0 045B B *11
(taken from TI intern)
So the KSCAN routine deliberately burns cycles. And the delay subroutine is called from more than one position.
Edited by mizapf, Mon Nov 27, 2017 9:22 AM.
#9 senior_falcon OFFLINE
senior_falcon
  • 1,177 posts
Posted Mon Nov 27, 2017 9:50 AM
0366   MOV 1,3
0368   SLA  3,3
036A   DEC 3
036C   INC 3
036E   SLA 4,1
Here's another one from KSCAN.  Why the DEC followed by the INC?
#10 Lee Stewart OFFLINE
Lee Stewart
  • 3,695 posts
Posted Mon Nov 27, 2017 10:24 AM
038E 1302 JEQ >0394
0390 06A0 BL @>0498
049A 04E2
049C 060C DEC 12
049E 16FE JNE >049C
04A0 045B B *11
The delay loop is called in only two places in KSCAN and then only when a key press is detected.
...lee
#11 Lee Stewart OFFLINE
Lee Stewart
  • 3,695 posts
Posted Mon Nov 27, 2017 10:31 AM
0366   MOV 1,3
0368   SLA  3,3
036A   DEC 3
036C   INC 3
036E   SLA 4,1
Here is the TI source for that plus some surrounding code:
C354   SZC  R0,R4
       JEQ  C37A
       MOV  R1,R1            ON LAST STROBE ?
       JNE  C360             NO
       MOV  R5,R5            PLAYER 0?
       JNE  C37A             NO
C360   MOV  R2,R2            1ST TIME ROUND LOOP
       JNE  C37A             NO
       SETO R2               SET 'NOT FIRST TIME ROUND' FLAG
       MOV  R1,R3            MOVE LOOP (STROBE NO) TO R3
       SLA  R3,3             MPY BY 8
       DEC  R3               COMP FOR FOLLOWING INC
C36C   INC  R3
       SLA  R4,1
       JNC  C36C
* R3= 8*KBD STROBE+BIT POSITION
       MOV  R1,R1            LAST STROBE?
       JEQ  C37A             YES
       LI   R1,1
...lee
#12 TheBF OFFLINE
TheBF
    Dragonstomper
  • 616 posts
Posted Mon Nov 27, 2017 10:36 AM
...lee
I will send you my consultation invoice. Don't worry it's only Canadian dollars.  ;)
But for sure you could do a lot with 40 extra bytes I'm sure.
#13 Lee Stewart OFFLINE
Lee Stewart
  • 3,695 posts
Posted Mon Nov 27, 2017 11:49 AM
...lee
If I calculated it correctly for 0 wait states in 16-bit console ROM and scratchpad RAM, the delay loop takes 8.33 ms each time it is invoked—presumably for key debounce.
...lee
#14 OLD CS1 OFFLINE
OLD CS1
  • 5,318 posts
  • Technology Samurai
Posted Mon Nov 27, 2017 12:06 PM
I would charge per byte saved :)
#15 Lee Stewart OFFLINE
Lee Stewart
  • 3,695 posts
Posted Mon Nov 27, 2017 9:58 PM
By the way...
...lee
After changing the system code that ?TERMINAL calls to call the console routine, I found that both that code and the older, somewhat slower code copied from the console ROM are too fast.  The terminal input routine catches the <break> as an extra keystroke and displays it.  Upon checking the TI Forth source code, I find that I had changed it in fbForth from this:
*== ?TERMINAL ROUTINE CODE= -8  ============================
QTM    BLWP @KSCAN
       MOVB @KYCHAR,R0
       SRL  R0,8
       CI   R0,>2
       JEQ  QTERM1
       CLR  R0
QTERM1 B    @BKLINK
Obviously, calling KSCAN has sufficient delay (~8.33 ms) after detecting a keystroke to avoid the “extra keystroke”.  I guess I will need to add a debounce loop or go back to the old TI Forth code—plus, it is shorter.
...lee
#16 TheBF OFFLINE
TheBF
    Dragonstomper
  • 616 posts
Posted Tue Nov 28, 2017 6:40 AM
QTM    BLWP @KSCAN
       MOVB @KYCHAR,R0
       SRL  R0,8
       CI   R0,>2
       JEQ  QTERM1
       CLR  R0
QTERM1 B    @BKLINK
...lee
I didn't look at how you use it exactly, but I created a break word that calls the ROM routine once looking for key pressed and then waits in a loop until the key is released.  That works very reliably. If you don't like  the action to happen on key release, then the key release loop could include a countdown timer.  Since calling the routine is just one BL , you might still save space by including the fancy key release timer loop.
My 2 cents Canadian (only worth 1.6 cents USD ) ;-)
B
#17 Lee Stewart OFFLINE
Lee Stewart
  • 3,695 posts
Posted Tue Nov 28, 2017 1:45 PM
B
OK...Here is some pretty tight code with a debounce loop that calls the same 16-bit console code as the initial call:
       MOV  LINK,R5         save return
       BL   @>0020          branch to console's test for FCTN+4
       STST R0              store status in R0
       JNE  QTM2            exit if not <clear>
QTM1   BL   @>0020          check for <clear> again
       JEQ  QTM1            loop until not <clear>
QTM2   MOV  R5,LINK         restore return
       ANDI R0,>2000        keep only EQU bit
       B    @BKLINK         return to caller
I am tempted to BL directly to >04B2 in the console, thus avoiding the extra B to that address from >0020.  The only thing stopping me is remembering that there are a couple of minor variants of the console ROM code out there that could mess that up if there is an address offset before >04B2.  :-o
...lee
#18 TheBF OFFLINE
TheBF
    Dragonstomper
  • 616 posts
Posted Tue Nov 28, 2017 2:04 PM
...lee
That was quick.
So that is about 18..20 bytes ?
So you save 24 or so.
If it works like you need it to, that sounds like a winner.
