+Philsan Posted November 18, 2017 Share Posted November 18, 2017 Can someone please modify the attached Rastaconverter's "no_name.asq" so that Rastaconverter image xex exits after 5 seconds (instead of pressing fire, start or a key)? Here is the part to be changed //-------------------- // EXIT //-------------------- lda trig0 ; FIRE #0 beq stop lda trig1 ; FIRE #1 beq stop lda consol ; START and #1 beq stop lda skctl ; ANY KEY and #$04 bne skp Thanks! no_name.zip 2 Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 19, 2017 Share Posted November 19, 2017 (edited) Here's a bit of code that should be good for PAL and NTSC. rtclok = $12 pal = $D014 ldy #5 ; 5 seconds delay1 lda pal and #$0A ; gives 0 for PAL, 10 for NTSC clc adc #50 tax delay2 lda rtclok+2 delay3 cmp rtclok+2 beq delay3 ; delay single frame dex bne delay2 ; delay 1 second dey bne delay1 ; delay x 5 ; returns here It could be simplified a bit but for the sake of several bytes when an RC pic is about 16K, does it matter? If you wanted to incorporate manual exit like normal, put that stuff before the "dex" though if using X or Y you'd need to save/restore them. Edited November 19, 2017 by Rybags 5 Quote Link to comment Share on other sites More sharing options...
twh/f2 Posted November 19, 2017 Share Posted November 19, 2017 yes. good idea. had the same thing in mind when I saw all these wonderful G2F pictures. It would make a great slideshow when e.g. using it with SDX batch files and a SIDE and alike. 3 Quote Link to comment Share on other sites More sharing options...
pps Posted November 19, 2017 Share Posted November 19, 2017 (edited) As the standard file of rasterconverter switches off the os. using rtclock won't work. For the 5 sec Philsan wants, you can simply use a byte and increment it every vbl and if reaches 250 you can quit after around 5 sec with PAL a bit less when NTSC. //-------------------- // EXIT //-------------------- lda tmer cmp #250 beq stop inc tmer lda trig0 ; FIRE #0 beq stop lda trig1 ; FIRE #1 beq stop Don't forget to set tmer to zero at start and then use 'ini main' instead 'run main' if you want to load next part of multi linked file. If you want to have more or correct waiting time use real timer interrupt instead. Edited November 19, 2017 by pps 6 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted November 19, 2017 Author Share Posted November 19, 2017 Thank you very much for the quick help friends! 1 Quote Link to comment Share on other sites More sharing options...
pps Posted November 19, 2017 Share Posted November 19, 2017 (edited) Here we go with the "final" solution of this problem: We use 2 bytes to determine what time's gone by - tmer and tmer2 lda tmer cmp #50 bne go_further mva #0 tmer inc tmer2 lda tmer2 cmp #10 beq stop go_further inc tmer This is PAL version. For NTSC use 'cmp #60' instead 'cmp #50'. Imho we don't need to check if we have pal or ntsc, as the pictures look very strange when not converted with the corresponding pallette for the machine. tmer2 is used for the exact amount of time in sec you want to display the picture. EDIT: There must be some work done to have a nice screen when loading the next picture. If not you might get screen garbage on ATARI screen (Emulator has sio patch, so you don't recognize it.). Edited November 19, 2017 by pps 2 Quote Link to comment Share on other sites More sharing options...
pps Posted November 26, 2017 Share Posted November 26, 2017 (edited) If you want to have a clean screen between the pictures you can't just reinitiate the OS and then rts as in the original source. You'll get screen garbage of the "old" picture while loading. To prevent this best way is to show up a little info that more is coming and - that's the important thing - wait till vbl is set and the "loading screen" is shown. Then do the rts. snap shot of no_name.asq: //-------------------- // EXIT //-------------------- //-------------------- // Timer //-------------------- lda tmer cmp #50 bne go_further mva #0 tmer inc tmer2 lda tmer2 cmp #10 beq stop go_further inc tmer //-------------------- lda trig0 ; FIRE #0 beq stop lda trig1 ; FIRE #1 beq stop lda consol ; START and #1 beq stop lda skctl ; ANY KEY and #$04 bne skp stop mva #$00 pmcntl ;PMG disabled tax sta:rne hposp0,x+ mva #$ff portb ;ROM switch on mva #$40 nmien ;only NMI interrupts, DLI disabled cli ;IRQ enabled mwa #ant_scr 560 lda:cmp:req $14 ;wait 1 frame rts ;return to ... DOS skp //-------------------- jmp LOOP ;--- wait54cycle :2 inc byt2 wait44cycle inc byt3 nop wait36cycle inc byt3 jsr _rts wait18cycle inc byt3 _rts rts byt3 brk //-------------------------- org $0600 ant_scr .he 70 70 70 70 70 70 70 .he 42 dta a(ld_scr) .he 41 dta a(ant_scr) ld_scr dta d" please wait for next " //-------------------------- This should work fine now. btw. you can left out the disable basic code in the second picture file, as it is switched off by the first picture. * --- BASIC switch OFF org $2000\ mva #$ff portb\ rts\ ini $2000 Edited November 26, 2017 by pps 3 Quote Link to comment Share on other sites More sharing options...
Sheddy Posted December 23, 2017 Share Posted December 23, 2017 (edited) Thanks to pps for pointing me here. Not sure how I missed it before. I'm not sure how beneficial it would be, but there should be enough memory to leave DOS on in a 48K machine with a bit of reorganizing of the no_name memory space: I suppose the biggest Rasterconverter picture could stuff registers on every line in 54 of the 57 available cycles. 9x5* bytes=45 + the 2 filler bytes for the 3 remaining cycles = 47. *Corrected* For full 240 height: program: 240x47=11280 (ouch) bitmap: 240x40=9600 plus some alignment bytes players: 1024 DLIST: 720 +Viewer code total: <23k Still doable with DOS Edited January 7, 2018 by Sheddy Quote Link to comment Share on other sites More sharing options...
kenjennings Posted December 24, 2017 Share Posted December 24, 2017 How exact does the pause need to be? This is good for about 5-ish seconds long_pause lda #0 sta RTCLOK+2 ; increments every jiffy sta RTCLOK+1 ; increments every 255 jiffies pausing cmp RTCLOK+1 beq pausing rts . Quote Link to comment Share on other sites More sharing options...
pps Posted December 24, 2017 Share Posted December 24, 2017 Ken, this doesn´t work here, as the OS is switched off by the programme and no one does the clock work. Quote Link to comment Share on other sites More sharing options...
Sheddy Posted December 24, 2017 Share Posted December 24, 2017 Referring back to the RasterConverter picture thread, there is a small amount of interest in a slideshow program for RastaConverter pictures. Although people have found it is just about possible with some DOSes to chain load the xex files without them crashing on exit, as suggested, it would be nice to be able to rely on an already running VBI to pick up the real time clock and to do other slideshow things. I would personally want them to work as stand alone pictures as well, which I think ought to be possible. I am working on a decompiler/optimiser script that should help make existing xex pictures more amenable to tweaks of the default build program. Working on that, I only recently realised it would ideally need to be able to decompile the more optimised program kernel too (Doh!). That is a bit harder to parse. At that stage a better way would need a proper format for RastaConverter, at least for the program kernel. Maybe a bytecode that gets compiled at run time? Maybe that isn't needed if just a general compressor is used. The bitmap and sprites could certainly benefit from that. Will probably post a new topic asking about that some more. 3 Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted December 24, 2017 Share Posted December 24, 2017 (edited) I can program a little, even a little assembler, but it's something I do only a few times each decade (yes, 'decade'). I would like my system to return to the mypicodos (v4.06) menu after displaying a picture. I realize this is not a real DOS. An RTS is not going to work. Would modifying NO_NAME.ASQ with a JMP $E477 be good enough? p.s. The current code at exit does some housekeeping and then PLA, PLA, JMP ($0A) [DOSVEC?], RTS. Why does it crash? Edited December 24, 2017 by a8isa1 Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted December 25, 2017 Share Posted December 25, 2017 (edited) Well, I simply use the method Reset=reboot (coldstart) and since I am still using disks and disk-images (and most of them are 90k/130k/180k), such a reboot does not take that long... DOS needs "many" seconds to boot (or to return to when it is not in RAM anymore, e.g. with DOS 2.0 or DOS 2.5 the DUP.SYS with 42 sectors has to be reloaded), MypicoDOS is somewhat faster (still some 30 sectors to load), NanoDOS/MicroDOS/PicoDOS are still faster (boot sectors + dir sectors have to be loaded), Bootloaders are even faster (only 3 bootsectors to boot/load, e.g. Fender's 3 sector bootloader)... Most of the time I use Superpacker/Exomizer by TeBe to pack a Rasta pict. so its length is somewhere in the 8k-16k range and I also add a Basic-off routine and a Reset=coldstart routine to it. But that has to be done manually then to every Rasta pict. Afaik, Fender's 3-sector bootloader also includes an option to set Reset to reboot, have not tested if it works successfully with the Rasta pics (if so, I only need to write the bootloader to the 90k/130k/180k disk and there would be no need to modify the Rasta pics for a coldstart)... But if you need a reboot for a 16MB "disk", you should use MyPicoDOS, it switches Basic off automatically, afaik also does a reboot on Reset (if the program is not reset-proof) and supports MyDOS subdirs (so you can sort your Rasta pics from A-Z). Use a joystick to choose and firebutton to load a Rasta pict. and press Reset to reboot the HDD partition or ATR-image. BASOFF.xex COLDSTA.XEX MENUMAKE.xex Rasta25.atr Edited December 25, 2017 by CharlieChaplin 3 Quote Link to comment Share on other sites More sharing options...
pps Posted December 31, 2017 Share Posted December 31, 2017 ...Most of the time I use Superpacker/Exomizer by TeBe to pack a Rasta pict. so its length is somewhere in the 8k-16k range and I also add a Basic-off routine and a Reset=coldstart routine to it. But that has to be done manually then to every Rasta pict. Afaik, Fender's 3-sector bootloader also includes an option to set Reset to reboot, have not tested if it works successfully with the Rasta pics (if so, I only need to write the bootloader to the 90k/130k/180k disk and there would be no need to modify the Rasta pics for a coldstart)...... As far as I see, 'BASIC off' isn't needed, as the rastaconverter default no_name.asq has this bult in at the front of it. for having a coldstart after pressing console, trigger or key simply search (in no_name.asq) for: rts ;return to ... DOS and replace it with. jmp $e477 ;perform a reset From now on every rastapic you create will end performing a reset call. Then use the Superpacker to compress the pic, if aou want shorter file size. For me Superpacker works best in Exomizer mode - depacker start $0400, decrunch disable screen, so you can use $bc40 for buffer. PS: Superpacker in latest version (5.9) has some error when overwriting a file. In W10FCU the 'overwrite warning messagebox' is not shown full, so you only can leave it (and have to choose a different filename instead) by pressing enter for abort/cancel this box. Superpacker 5.6 works fine there as it uses windows standard message box. 2 Quote Link to comment Share on other sites More sharing options...
pps Posted January 4, 2018 Share Posted January 4, 2018 Maybe someone just recognized it, I did a small picture at last disc of nyd2018 and it uses rastaconverter pics and this timing to worg. The source will be available in a minute or so over at github: https://github.com/ppsberlin/historic-trucks 3 Quote Link to comment Share on other sites More sharing options...
