Asteroids Deluxe from TNT
61 replies to this topic
#51 davyK OFFLINE
davyK
    Moonsweeper
  • 405 posts
Posted Tue Feb 13, 2018 8:19 AM
Power supply on its way - sent 1st class.
#52 davyK OFFLINE
davyK
    Moonsweeper
  • 405 posts
Posted Fri Feb 23, 2018 1:51 PM
Power supply delivered and I fitted it last night. Game working again - adjusted the pot to 5.02v.
The power supply is a different revision - the components look different and there is a 4th connector on the board (the original had 3) and I'm getting a different explosion sound - not sure if that is the reason. The board is also the amplifier. The sound of the explosions aren't as good which is a bit of a pity - but other sounds are just as before. Test mode reports all OK on the game board.
Thinking of getting the old board repaired now as a spare. Would be a shame to trash it.  If I get that done it would be interesting to see if the sound improves with it.
I was getting flicker on the display (was getting it before the power supply failed - the brightness was adjusting up and down momentarily. It seemed to settle down as the game "warmed up") - have twiddled the brightness and contrast pots on the display board and that seems to have resolved it - will look out for that - hoping that it is sorted.
Edited by davyK, Fri Feb 23, 2018 1:56 PM.
#53 davyK OFFLINE
davyK
    Moonsweeper
  • 405 posts
Posted Sat Mar 3, 2018 4:12 PM
Game working great now. The voltage is just over 5v as I set it a week ago and the display is nice and steady - just the explosion sound being distorted a bit. TNT have offered to repair the original failed board for free if I pay for the return postage so I've sent that off to them
It will be interesting to see if the sound is better with that when I get it back. Means I will have a spare power supply at any rate.
Edited by davyK, Sat Mar 3, 2018 4:12 PM.
#54 GoldLeader OFFLINE
GoldLeader
  • 2,020 posts
Posted Mon Mar 5, 2018 5:02 AM
Sounds like TNT Rocks!
#55 davyK OFFLINE
davyK
    Moonsweeper
  • 405 posts
Posted Mon Mar 5, 2018 5:00 PM
Yeah. I have had problems but they are responding really well. They respond to emails pretty quickly. I have spoken to them on the phone too. The owner, Todd, will come to the phone if you ring.
Edited by davyK, Mon Mar 5, 2018 5:01 PM.
#56 Keatah OFFLINE
Keatah
    Missile Commander
  • 20,358 posts
Posted Mon Mar 5, 2018 6:06 PM
They're sure doing right by trying to make it right. That's a plus on the report card. If I were them I would do a little bit of measuring, testing, and burn-in. Paying attention to things like if the CRT can maintain the image size over time, and if the voltages are rock solid as are the oscillators. And will the console/cab work in more extreme environments like a garage in summer or a cold basement in winter. Things like that.
It's just a thought. It's what I do when I build an emulation rig for someone. Even though it's all ordered-on-demand consumer parts, I do some checks and tests and purchase higher-quality parts. Understand that by default I have to make sure the hardware is 100%. Emulators can be finicky and tricky and even buggy, so I don't want hardware entering into the equation, hence the extra effort.
Regarding your sound, I don't know the specifics about the power supplies used or what it sounded like before, and now. If it was mine, and I was having a fit over sound quality changes I might plug in the original Pokey and make a scope measurement, then do the same with the new chip. And again with the old vs new power supply.
These electronics are 40 years old. They're going to age and do it at different rates depending on many factors. There's different models and revisions, too. All in all there's factors coming into play now, that were of no consequence when these things rolled off the assembly line. It's the nature of the hobby!
But again, looks like they're trying to make it right. And that's all one can ask for.
If brightness and contrast varied (in a random way) as the machine warmed up, it could be as simple as dirty adjustment pots. With a few degrees swing in temperature, the materials expand and contract. This can cause highly localized spot-wear on the substrate where the wiper contact moves. Like burning in a spot. Moving it, working it, cleaning, and lube, can fix this if it's not pitted across the whole band. Though that one minuscule spot will always be a problem if it's burned/corroded through, finding a fresh contact point next to it shouldn't be an issue. New resist material (carbon) can be deposited, but that's a specialty repair for rare parts.
#57 davyK OFFLINE
davyK
    Moonsweeper
  • 405 posts
Posted Tue Mar 6, 2018 2:18 AM
It's possible the image (size, brightness) pots were affected by the journey US to N.Ireland. Sitting in a cold container for a month wouldn't have helped. Tweaking the pots as you say seems to have sorted that.
I may have been just unlucky re the power supply - they rebuild them. It may have been the cold. Maybe I should have left the cabinet longer than I did before powering up. Hard to say.
They also run the cabinet for 24hrs before shipping it.
#58 davyK OFFLINE
davyK
    Moonsweeper
  • 405 posts
Posted Thu Mar 22, 2018 1:52 PM
TNT have received my original power supply now. When they repair it they are going to test in another Asteroids Dx they will be working on before returning it.
#59 davyK OFFLINE
davyK
    Moonsweeper
  • 405 posts
Posted Tue May 15, 2018 12:52 PM
Replacement power supply on its way back to me.  They had to wait for another Dx so they could test it.
#60 Keatah OFFLINE
Keatah
    Missile Commander
  • 20,358 posts
Posted Tue May 15, 2018 5:03 PM
All this time..
#61 davyK OFFLINE
davyK
    Moonsweeper
  • 405 posts
Posted Fri May 18, 2018 11:36 AM
I know!   :)   Don't mind too much since the game works OK with the replacement they sent me back in March. They had to wait on another Dx coming in to test it with.  They tested it for 5 days!
Will be interesting to see if it improves the sound I'm currently getting.
Edited by davyK, Fri May 18, 2018 11:37 AM.
#62 davyK OFFLINE
davyK
    Moonsweeper
  • 405 posts
Posted Mon May 21, 2018 1:10 PM
Board arrived today. Just swapped it into the cabinet and that gorgeous deep bass sound of the explosions and the ship thrust is back!!!!
I'm delighted.  It really does make a difference.  :)
Big thanks to Todd at TNT.
Edited by davyK, Mon May 21, 2018 1:10 PM.
