lucifershalo Posted December 11, 2017 Share Posted December 11, 2017 Help I have been able to load a cart game but cant happen the key on my laptop keyboard to select 1 Ti Basic 2 Ambulance can't find the key for that "2" any help? thanks Quote Link to comment Share on other sites More sharing options...
blackbox Posted December 17, 2017 Share Posted December 17, 2017 Key 2: - Use the key you usually use to place a 2 into a spreadsheet. - If you are using a numeric keypad be aware that some emulators start up apparently out of sync with your num lock key- if your num lock key is lit as active, you may need to toggle it twice to ensure the emulator reacts to it- press num lock and try 2, then press num lock again and try two again. One way should function, otherwise use the 2 on the top row of your keyboard. Worth noting- the TI99/4a was not sold with support for mice. Most input was keyboard based. Many inputs required capital letters only. However a few games were joystick only, some used either joystick, some used only joystick 1 and some only joystick 2. You will need to see if your emulator can "force" the use of keys instead of a joystick. Games which used either joystick or keyboard generally used keys ESDX for movement and Q or space for fire- but programmers often used other keys instead so look for documentation. regards Stephen Quote Link to comment Share on other sites More sharing options...
