Tiny Sprite Editor for Lynx
9 replies to this topic
#1 jum OFFLINE
jum
    Chopper Commander
  • 121 posts
Posted Thu Dec 14, 2017 2:43 AM
I have modified the online "Tiny Sprite Editor" ( http://tmtg.net/tinyspriteeditor/) made by Boris van Schooten, so that you can use it to create sprites for Atari Lynx.
Double-click the .html file in the attached zip to run it.
Currently you can export the sprite data as C code or ASM code (literal sprites only for now, can add RLE compressed sprites later).
Usage:
1. Run the .html file in Chrome (may work in other browsers too).
2. Set the "Palette" drop down to "Atari Lynx" BEFORE you draw anything.
3. Draw a pretty picture (background must be pen 0 (black))
4. In the "Text Format" dropdown, select "Lynx C code (literal)"
5. Click the "Export" button.
6. The C code will appear in the textbox at the bottom of the page.
Note: you cannot import C code at this stage. If you want to "Save" your sprites to work on later, then export as "Data URL".
Let me know how it works for you. I am sure many improvements can be made.
The main purpose is to make it easier to create Lynx sprites for your projects, without having to hassle with Gimp and PCX and sprpck/sp65 and bin2c...
Have fun!
Also have added to github as a fork of the original: https://github.com/j...inyspriteeditor
Edited by jum, Sat Dec 16, 2017 12:47 AM.
#2 karri OFFLINE
karri
  • 2,561 posts
Posted Thu Dec 14, 2017 2:53 AM
Such a nice editor. The literal sprites are ok for most purposes.
It works in Firefox too.
Edited by karri, Thu Dec 14, 2017 2:53 AM.
  • jum likes this
#3 jum OFFLINE
jum
    Chopper Commander
  • 121 posts
Posted Thu Dec 14, 2017 3:01 AM
Thanks for testing Karri. Has some impressive features for a "Tiny" editor (Copy/Paste/Sprite sheets/Animation preview).
#4 Turbo Laser Lynx OFFLINE
Turbo Laser Lynx
    Moonsweeper
  • 498 posts
Posted Thu Dec 14, 2017 2:21 PM
Very nice stuff, thanks for sharing man!
  • jum likes this
#5 LordKraken OFFLINE
LordKraken
    Chopper Commander
  • 144 posts
Posted Thu Dec 14, 2017 3:07 PM
Looks pretty cool but I haven't figure out how to modify the palette yet... or is it even possible? (having black for pen 0 is not optimal since pen 0 is also the transparent color).
#6 jum OFFLINE
jum
    Chopper Commander
  • 121 posts
Posted Fri Dec 15, 2017 12:46 AM
You can modify the palette in the HTML source code, or add your own palette. You can change pen 0 to pink if you prefer.
Probably would be nice to be able to import a Lynx palette, either from C file data or from .gpl palette file. Let me know what format(s) would be most useful.
Edited by jum, Fri Dec 15, 2017 1:33 AM.
#7 Bochum_Boy OFFLINE
Bochum_Boy
    Star Raider
  • 50 posts
Posted Fri Aug 17, 2018 6:19 AM
Classical noob question: How do I implement a C-Struct array in a Lynx programm? I read the tutorial on the sprite with .o objects, any idea how to implement a TinySprite?
#8 karri OFFLINE
karri
  • 2,561 posts
Posted Fri Aug 17, 2018 8:18 AM
The tiny sprite exports the bitmap as bytes.
unsigned char sprite_0_0[] = {
0x7,   0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
0x7,   0x0, 0x0, 0x0, 0xf, 0x0, 0x0,
0x7,   0x0, 0x0, 0x0, 0xff, 0x0, 0x0,
0x7,   0x0, 0x0, 0xff, 0xff, 0x0, 0x0,
0x7,   0x0, 0xff, 0xff, 0xf0, 0x0, 0x0,
0x7,   0x0, 0xff, 0xff, 0xff, 0x0, 0x0,
0x7,   0x0, 0xf0, 0xff, 0xff, 0x0, 0x0,
0x7,   0x0, 0xf, 0xff, 0xff, 0x0, 0x0,
0x7,   0x0, 0xff, 0xff, 0xf, 0x0, 0x0,
0x7,   0x0, 0x0, 0xf, 0x0, 0x0, 0x0,
0x7,   0x0, 0x0, 0xf, 0xf, 0xf, 0xf0,
0x7,   0x0, 0x0, 0x0, 0x0, 0x0, 0xf0, 0x00
In the cc65 library _suzy.h you have different type of sprite structs like:
typedef struct SCB_REHVST_PAL {             // SCB with all attributes
  unsigned char sprctl0;
  unsigned char sprctl1;
  unsigned char sprcoll;
  char *next;
  unsigned char *data;
  signed int hpos;
  signed int vpos;
  unsigned int hsize;
  unsigned int vsize;
  unsigned int stretch;
  unsigned int tilt;
  unsigned char penpal[8];
} SCB_REHVST_PAL;
static SCB_REHVST_PAL Sastonmartin = {
    BPP_4 | TYPE_NORMAL,REHVST|LITERAL,NO_COLLIDE,
    0,
    sprite_0_0,
    80, 100,
    0x100, 0x100,
    0x000, 0x000,
    {0x01,0x23,0x45,0x67,0x89,0xab,0xcd,0xef}
Then you can paint this on screen with:
tgi_sprite(&Sastonmartin);
tgi_updatedisplay()
#9 Bochum_Boy OFFLINE
Bochum_Boy
    Star Raider
  • 50 posts
Posted Tue Aug 21, 2018 2:04 AM
Thanks Karri - that made the trick!
#10 SlidellMan OFFLINE
SlidellMan
    Moonsweeper
  • 314 posts
Posted Mon Aug 27, 2018 5:11 PM
Not a bad tool, if I do say so myself.
